Disable fuel pump activation at door opening for Lupo 1.0 AUC
Karma: +645 / -0   Thank you, like it!
Post02-02-2016, 13:47    Subject: Disable fuel pump activation at door opening for Lupo 1.0 AUC Quote
Hi.
I'm currently restoring a 2004 Lupo to be my daughter's first car, and I've noticed that whenever I open either of the doors (driver or passenger side), the fuel pump briefly activates. It seems like a feature similar to the automatic pre-glow function when opening the door on a T4 with an ABL engine.
Can this feature be disabled using a VAG 1551 device, or do I need to obtain a wiring diagram and manually resolve it?
Thank you, Rüdi.
Translated on 18-07-2026, 4:26.
Post02-02-2016, 14:07    Subject: Disable fuel pump activation at door opening for Lupo 1.0 AUC Quote
To the best of my knowledge, this cannot be solved through coding. As always in such cases, a full system scan is absolutely necessary to determine which control units are involved.
Translated on 18-07-2026, 4:28.
DieselBär30x
Avatar-DieselBär30x
Post02-02-2016, 14:43    Subject: Disable fuel pump activation at door opening for Lupo 1.0 AUC Quote
Hello everyone!
Alternatively, and quite unconventionally, you could remove the fuse or relay for the fuel pump. icon_cool.gif
There's probably a mistake somewhere, but it will definitely be easier to delete than accidentally changing something due to coding errors.
Best regards from Munich!
Post08-02-2016, 14:47    Subject: Disable fuel pump activation at door opening for Lupo 1.0 AUC Quote
Well, it doesn't really matter now. My car, "Schüsselchen," just passed the new technical inspection, so hopefully I won't have to worry about it for a while.
Sure, no problem. Here's the translation:
"Thank you very much."
Rüdi.
Translated on 18-07-2026, 4:29.
No new posts Documentation Lupo MKB AYZ, problems with driving behavior Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Occasional starting problems with the Lupo 1.4 TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Workshop Action: Software Adjustment, Gearbox, 3L Lupo Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Disable ABS: How to Turn Off Anti-Lock Brakes Transmission, Chassis, Body & Interior
No new posts Disable Seatbelt Alarm: How-to Guide On-Board Diagnostics (OBD)
No new posts VAGCOM: Disable Museum Warning? On-Board Diagnostics (OBD)
No new posts Deactivate Cooling Water Glow Plugs Diesel Engine Technology
