Audi A4 2.4 1999, EPC light on, 18084
berger20000
Post19-02-2016, 15:02    Subject: Audi A4 2.4 1999, EPC light on, 18084 Quote
Hello everyone.
"On my 1999 A4 2.4 30v, the EPC light is constantly illuminated white, and I'm not sure where to look or how to proceed." The car turned out to be a bit of a bad purchase as a winter car for this winter.
18084 P 1676 Indicator lamp for electrical systems. Gas-actuated valve - K132.
- Wiring checked.
- MSG swapped.
- The engine was completely rebuilt with all attachments (due to engine damage), and it was already malfunctioning before the rebuild.
Where should I continue searching? Should I try a different combination or a different gas pedal? What do you think?
With EPC, I can't get a TÜV inspection.
Sure, here's the translation:
"Thank you in advance."
Michael.
Audi A4 B6 2.5TDI Quattro
Skoda Superb 4x4 TDI CR2
Polo 6N 1.8T AUQ
Post19-02-2016, 15:14    Subject: Audi A4 2.4 1999, EPC light on, 18084 Quote
As usual, a diagnostic scan of the entire vehicle can help in this case. Please post here.
*Nichts ist einfacher, als sich schwierig auszudrĂźcken......*
berger20000
Post22-02-2016, 22:57    Subject: Audi A4 2.4 1999, EPC light on, 18084 Quote
Attached is an Autoscan.
Log-176070km.txt
 Autoscan
Autoscan
 File name:  Log-176070km.txt
 File size:  4.36 KB
 Downloaded:  1226 times
Polo 6N 1.8T AUQ
DieselBär30x
Avatar-DieselBär30x
dieselschrauber likes this.
Post23-02-2016, 2:55    Subject: Audi A4 2.4 1999, EPC light on, 18084 Quote
"Electronic throttle control" is not just the accelerator pedal, but the entire system as a whole, including the throttle body, engine control unit (ECU), brake light switch, etc.
The error you have recorded actually only relates to the MIL (Malfunction Indicator Lamp) with the code "EPC".
The vehicle scan indicates that the kidney (component) has been replaced before; part number "X".
Therefore, I would start by checking and cleaning various power strips here. Similarly, regarding the German Trade Tax Act (MStG), but you were already familiar with that.
By the way, when replacing the engine or performing other work in the area of the throttle body, a basic adjustment must also be carried out!
...you definitely didn't do that, because that's not possible with a memory error icon_wink.gif.
Therefore, let's first eliminate the error in the VAT law. If it doesn't work with just the ignition on, warm up the car, DO NOT turn it off, and then try to extinguish the fire again.
If that worked, immediately proceed to perform a basic adjustment on the throttle body unit.
Please check the values in modules 060-066 for plausibility (including both brake light switches, clutch switch, GRA, etc.).
After that, you can start looking for the actual error, assuming it hasn't already disappeared as if by magic along with the learned DK.
Best regards from Munich!
No new posts Audi A8: Brake Pad Wear Indicator Light On? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Temperature Difference in Passenger Compartment (A6) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Window Repair: Audi A4 (1999) - Fix Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Haldex failure - Audi S3 8L, year 1999 Transmission, Chassis, Body & Interior
No new posts Audi A4 8D GRA: ECU Location - AVG Engine On-Board Diagnostics (OBD)
No new posts TDI Engine Problems: Black Smoke & Power Loss On-Board Diagnostics (OBD)
No new posts VW T4 CLIMAtronic: 1999 Model On-Board Diagnostics (OBD)
