Wäre es möglich, den GRA Hebel vom neuen Passat mit... | Posts 16+
Go to page: Previous  1, 2
Post06-10-2003, 9:53    Subject: Quote
Rudi wrote:
By the way, RES does not stand for "reset," but for "resume," meaning "continue."
Translated on 05-07-2026, 0:33.
dieter
Karma: +13 / -0   Thank you, like it!
Post06-10-2003, 10:27    Subject: Quote
to completely confuse things...
By the way, the G4 has the "+" function on the "RES" key and the "-" function on the "SET" key, while on the G3 it's the opposite ("SET"="+").
"How did you come to that conclusion? I have an ABN (automatic gearbox) from a Golf III in my T3 bus, and the shifter is the same as the original."
slider 1. level (switch): on/off
Level 2 (button): "Resume" and "+" increase speed in approximately 1 km/h increments with each press. Holding the button down will accelerate to the maximum speed.
SET (button): Sets the speed, in increments of approximately 1 km/h with each press. Holding the button down decreases the speed, likely until the GRA (presumably a safety system) shuts off due to falling below the minimum speed. This function only works with a delay of approximately 2 seconds.
That's exactly how it works for all TDIS, and the speed control on industrial motors works the same way.
greetings
dieter
Translated on 05-07-2026, 0:35.
Post06-10-2003, 11:00    Subject: Quote
Level 2 (buttons): Resume and +.
Well Dieter, then someone ripped you off! icon_biggrin.gif icon_wink.gif The engine is possibly from a G3, but the control unit is very likely from a G4 or A3!
The "-" function did not exist in the Golf 3, at least not until production ended in MJ97.
Are there later G3 models that have this feature?
No, there are definitely differences.
Take a look inside.
http://www.tdi-umbau.de/Technik/Tempomat/tempomat.htm
"There, someone built their own GRA (Gravitational Repulsor Array) and is also accelerating it using 'SET' (see description)."
"Quote:"
After activating the cruise control, the speed can be increased in small increments using the buttons (Set), but unfortunately, unlike many other manufacturers, Volkswagen does not allow the speed to be decreased using the same controls.
By the way, I've driven my G3 1Z long enough to know that it could only accelerate using the GRA (acceleration) function, and that was controlled via the "SET" button. After exactly one year of using the G4, I still have problems with the GRA (Graphical User Interface) because it functions in the opposite way compared to what I'm used to.
Translated on 05-07-2026, 0:38.
dieter
Post06-10-2003, 11:33    Subject: Quote
You're right, I had completely forgotten that my steering wheel had been replaced.
is probably from a Passat, but I'm not going to confirm that right now. icon_confused.gif
greetings
dieter
Translated on 05-07-2026, 0:40.
DocSnydor
Post06-10-2003, 14:39    Subject: Quote
See, I learned something new again.
I upgraded my GRA myself, and I didn't even know you could use SET for nitrous. Not bad either. icon_rolleyes.gif
Translated on 05-07-2026, 0:41.
No new posts Lupo 6X1 MJ 2002: Broken Flap Lock Lever Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A4 8E2/8E5 - Possible various error memory messages Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Is it possible to install a G40 engine without replacing ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 3B ABS FS reading not possible! On-Board Diagnostics (OBD)
No new posts GRA Lever: €86 - Is It Worth It? Diesel Engine Technology
No new posts 02J Gearbox Shift Lever: What is it for? Diesel Engine Technology
No new posts Cruise control in A3 8P using a Golf 5 lever Diesel Engine Technology
