A4 B6 Network Control Unit Malfunction? Is a test possible?
rockothepd
Post11-04-2016, 19:36    Subject: A4 B6 Network Control Unit Malfunction? Is a test possible? Quote
Hello everyone,
I am a beginner in the field of modern vehicle tax technology and would like help from those who are definitely experts!
Vehicle:
Audi A4 B6 1.9 TDI 98KW, Year 2002
Since Saturday, it's been essentially a complete failure...
Symptoms:
- ABS, ESP indicator lights do not turn off after engine start
- All steering functions (indicators, headlights, power windows, windshield wipers, etc. not functioning)
- Side windows cannot be opened/closed
- Side mirrors not adjustable
- Sliding roof not adjustable/openable
- Climate control unit with no function
What I did:
At the ignition switch (positive wire connected to the radio, negative wire disconnected).icon_cool.gif
I have switched on a relay because I don't know what power the car radio draws through this connection.
All fuses have been checked. Status: OK
Question:
- Am I right in suspecting a faulty central control unit?
- How can I specifically find this specific tax device?
- Can I use VCDS to check the functionality of the device, and if so, how?
Hoping you can help me!!!!
Thank you in advance for your support.
Log-KA-ZO 1234-WAUZZZ8E62A254808-246430km.txt
 AutoScan-Datei
AutoScan-Datei
 File name:  Log-KA-ZO 1234-WAUZZZ8E62A254808-246430km.txt
 File size:  3.06 KB
 Downloaded:  880 times
Post11-04-2016, 21:32    Subject: A4 B6 Network Control Unit Malfunction? Is a test possible? Quote
Do you have an old scan?
The vehicle should have significantly more airbags, or is it really that bare?
Motor reports missing climate control unit. Climate-STG doesn't even appear on the list.
I'm not familiar with that particular vehicle, but I assume you're referring to a central fuse. The most likely candidates would be one of the main fuses or the Maxi fuses. Does a 2002 model have a fuse box next to the battery in the engine compartment? If so: Have you also checked the fuses that were screwed in from the front?
Greetings
Guste
rockothepd
Post11-04-2016, 22:29    Subject: A4 B6 Network Control Unit Malfunction? Is a test possible? Quote
First of all, thank you for the feedback, Guste!
I bought this great piece last year in September and then checked the error memory to see what was stored there. So, there's still something!
Regarding the errors that occurred, such as:
1 Error found:
01331 - Driver's Side Door Actuator (J386)
49-00 - No communication ... etc.
I didn't spend much time considering different {SSL/TLS} options back then (naive, ignorant?), since everything had been working fine so far.
The seller was a young guy (not meant to be malicious!), who probably used the car as a DIY project. This means he probably installed illuminated strips in the doors and dashboard (like in high-end cars) and the problems might be due to this, along with many other minor issues. But, as I said, everything was fine.
In the attachment, you will find the scan from September...
Fuse boxes? Hmm, I'm not sure where these should be located. I've checked all the 40, 50, and 60-amp fuses in the fuse box located in the driver's footwell. They are all in good condition. Besides the battery, I haven't checked the fuses yet; I haven't seen any fuses there before, but I will check again tomorrow.
Unfortunately, I do not have a wiring diagram for the vehicle's electrical system.
I will be able to say more about the fuses tomorrow.
Greetings. Jürgen
Log-KA-ZO 1234-WAUZZZ8E62A254808-233620km.txt
 File name:  Log-KA-ZO 1234-WAUZZZ8E62A254808-233620km.txt
 File size:  4.57 KB
 Downloaded:  713 times
Post12-04-2016, 8:30    Subject: A4 B6 Network Control Unit Malfunction? Is a test possible? Quote
Out of the nine Steuergeräte from the old scan, four STGs are now found. Obtain the wiring diagrams for your vehicle (which can be downloaded for a one-day fee directly from Audi / ERWIN). Then, check the five STGs for similarities. I am quite certain that everything is converging at a single point.
Edit: Since you've been messing with the ZAS, it would probably be helpful to check there first, while the engine is running, to see if there's actually voltage on all the pins (except the starter contact). If there is no voltage on a pin, I could imagine a similar error scenario.
If I haven't fallen in love while flying over it, then it might be that contact 75 or the X-contact is broken.
Greetings
Guste
rockothepd
dieselschrauber likes this.
Post12-04-2016, 22:02    Subject: A4 B6 Network Control Unit Malfunction? Is a test possible? Quote
Okay, I've just tested the ZS, and guess what... Is everything okay?
I obtained the schematics from Audi, but I have little experience in reading electrical diagrams. It's not that difficult, except for a few fundamental symbols and representations that I'm not familiar with.
However, to my understanding, at least, it seems that the STGs are more or less serially connected. ZS - Steering Column Module - Bus Network - Comfort and including Climate Control and Doors.
After everything was okay at the ZS, I tried to measure something on the LSM connectors (if that was even possible), and to my surprise, the connector for the LSM was loose and had no contact!!!
icon_eek.gif icon_eek.gif icon_redface.gif May ashes fall on your head!! Sorry, absolutely embarrassing!!
I definitely didn't have it in my hand, and besides, this plug doesn't have a locking function.
Stuck in and everything is back to normal.
I would like to thank you, Guste, for taking on the problem. Without your advice to check the ZS, I would never have found the issue with the plug!! The mechanics would probably have just replaced all the STGs for me first. Okay, thank you again...
@Admin: Maybe delete this thread, it's actually a disaster icon_dustbin.gif
Post13-04-2016, 6:32    Subject: A4 B6 Network Control Unit Malfunction? Is a test possible? Quote
Why delete? You described an error and found a solution. Maybe it will help someone else someday too. No locking mechanism? Is the plug damaged?
rockothepd
Post13-04-2016, 8:39    Subject: A4 B6 Network Control Unit Malfunction? Is a test possible? Quote
I have to admit, I didn't really look closely at the plug to see if it was damaged...
... only to the extent that, plug in - no problems icon_question.gif - unplug icon_exclaim.gif without any issues! and then plug it back in.
However, the seat is "sucking". For further review, the feeling of euphoria was too intense icon_angel.gif.
Along the steering column mechanism, there is a "cable collecting" plastic strip that is attached to the adjustment unit of the steering column. I removed this to be able to correctly identify the cable 86s Pin8 Red (Switched Plus when the key is still inserted!! for the Nix-Audi radio installers). By the way, I probably unplugged the LSM, BECAUSE NOTHING WAS COMPROMISED icon_evil.gif.
"In any case, all STGs reappear in my Autoscan file, and all the error codes have disappeared!!"
Greetings to everyone...
No new posts General information about PD testing for troubleshooting ... Troubleshooting & Guides
No new posts VW T5 Interior Light/Onboard Computer Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A4 8E2/8E5 - Possible various error memory messages Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Injector Failure: VW 2.5 TDI AKN Repair Possible? Diesel Engine Technology
No new posts Body control module, Polo 9N On-Board Diagnostics (OBD)
No new posts Audi Q7: Install Body Control Module from Another Car Electrical Systems, Vehicle Electronics, Multimedia
No new posts Bordnet Steuergerät: Troubleshooting After Upgrade Electrical Systems, Vehicle Electronics, Multimedia
