Cold start is fine, but after a few minutes there's blue smoke
carstenAFN
Post06-10-2003, 23:06    Subject: Cold start is fine, but after a few minutes there's blue smoke Quote
Hi there,
I've recently converted my vehicle to run on alternative fuels and now consider myself a newbie in this area, but I need some help.
The engine received a new timing belt during the rebuild and runs very well when cold, with absolutely no smoke.
After a while, the smoke starts and only stops briefly from time to time during certain ventilation cycles.
I haven't had the opportunity for a diagnosis yet, and therefore I haven't been able to make any dynamic adjustments.
I now have one weekend left to get the bus roadworthy for the move, either by myself using a VAG-COM diagnostic tool or by scheduling an expensive appointment at a workshop.
A question for the experienced: Is it worth trying to adjust the saving settings myself, even though the matter seems relatively straightforward, or should I just give up on the attempt?
What possible causes could there be for the error?
Thank you.
Carsten.
Translated on 18-07-2026, 6:27.
Post06-10-2003, 23:27    Subject: Cold start is fine, but after a few minutes there's blue smoke Quote
The control of the injection start is described in the relevant article under "Troubleshooting & Instructions."
A diagnostic system is needed.
Translated on 18-07-2026, 6:29.
carstenAFN
Post07-10-2003, 11:52    Subject: Cold start is fine, but after a few minutes there's blue smoke Quote
I'm not yet aware of the oil consumption, as it's essentially a new installation. However, the engine should be mechanically sound.
I had hoped that the excessive smoking that starts when the part gets hotter was a typical and well-known behavior associated with a specific type of failure. (Normal diesel exhaust, I think).
"Well, of course, I don't think much can be done without a diagnosis."
Carstrn
Translated on 18-07-2026, 6:30.
Post07-10-2003, 13:04    Subject: Cold start is fine, but after a few minutes there's blue smoke Quote
Try searching in this forum.
I seem to recall reading somewhere that someone had problems installing a TDI engine into a T3 and, I don't want to spread misinformation, but they modified something related to the breather system for the crankshaft because oil was leaking out of it.
Translated on 18-07-2026, 6:31.
No new posts Audi A4 B7/8E 1.8T BFB - Shaking/Vibration after cold start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Golf 1J, from week 48/98, Clattering noise afte... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Lupo 6X1 MJ 2001, Clattering noises after cold start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts White smoke after cold start Diesel Engine Technology
No new posts 14V Charging: Why It Takes 3 Minutes? Transmission, Chassis, Body & Interior
No new posts A4 Cabrio 2.5TDI BDG: grauer Rauch bei Kaltstart Diesel Engine Technology
No new posts Absterben nach 5 Minuten Lauf bei Kälte! Diesel Engine Technology
