Fuel Gauge Issues: Octavia III 2.0 TDI Range Problem
Blackfrosch
Post13-04-2016, 20:22    Subject: Fuel Gauge Issues: Octavia III 2.0 TDI Range Problem Quote
Hello everyone,
"Like many others in the Octavia/Skoda forum, I am experiencing problems with the fuel level sensor or range indicator on my Octavia III 2.0 TDI."
In short:
The vehicle has a 50-liter fuel tank. If you drive it until the range indicator shows 0 km with an average fuel consumption of 4.5 liters, you can typically add approximately 42-43 liters to refill the tank. The combination instrument includes an adjustment channel for the fuel level sensor, but accessing it requires a login code, which I would like to know.
I once had some fun and filled the tank with 15 liters of fuel remaining, marking every 5 liters. (See log). The fuel gauge shows 5 liters less when the tank is empty, and at least 3 liters more when it's full.
Who has any ideas here? (besides testing the adaptation channel?)
LOG-18-361_tanken.CSV
 Log vom Tankgeber beim Tanken
 File name:  LOG-18-361_tanken.CSV
 File size:  19.44 KB
 Downloaded:  527 times
Log-ERGDG59-TMBJJ7NE8G0178537-313km.txt
 Autoscan
Autoscan
 File name:  Log-ERGDG59-TMBJJ7NE8G0178537-313km.txt
 File size:  13.42 KB
 Downloaded:  898 times
Translated on 27-07-2026, 20:31.
bloesch
dieselschrauber likes this.
Post14-04-2016, 0:22    Subject: Fuel Gauge Issues: Octavia III 2.0 TDI Range Problem Quote
We've encountered this problem with one or two Octavias before. I seem to recall there's a technical bulletin (TPI) about it.
Conclusion: State of the art! Safety margins, avoiding unnecessary operation, etc.
Let me see if I can find anything; unfortunately, I have very little time during work hours...
Translated on 27-07-2026, 20:33.
Post14-04-2016, 8:17    Subject: Fuel Gauge Issues: Octavia III 2.0 TDI Range Problem Quote
VCDS directly displays the login for the instrument cluster (IC). For each individual customization option, VCDS usually also provides suggestions. Otherwise, you can find a lot of information online by searching for terms like "VCDS," "adjust fuel gauge," etc., although not necessarily specifically related to the Octavia.
Translated on 27-07-2026, 20:34.
Blackfrosch
Post14-04-2016, 9:51    Subject: Fuel Gauge Issues: Octavia III 2.0 TDI Range Problem Quote
If the login option were displayed directly, I wouldn't have asked such a silly question.
I'm aware that it's state-of-the-art according to Skoda, which is why I'm not even asking about that; instead, I'm taking the initiative myself. I also know what APKs are available, but I need the login credentials. That's why I've attached an Autoscan.
Hello.
Translated on 27-07-2026, 20:35.
Post14-04-2016, 10:13    Subject: Fuel Gauge Issues: Octavia III 2.0 TDI Range Problem Quote
Try 13861.
Translated on 27-07-2026, 20:36.
Blackfrosch
Post14-04-2016, 11:42    Subject: Fuel Gauge Issues: Octavia III 2.0 TDI Range Problem Quote
Thanks to you! I will test it as soon as I have access to the vehicle again. It might take until mid-next week.
Hello.
Blackfrosch
Post01-05-2016, 17:38    Subject: Fuel Gauge Issues: Octavia III 2.0 TDI Range Problem Quote
Access key not accepted icon_sad.gif.
Blackfrosch
Post10-05-2016, 21:03    Subject: Fuel Gauge Issues: Octavia III 2.0 TDI Range Problem Quote
Are there any other ideas? This is really annoying with the vehicle. It drinks fuel like crazy, and you only have a 44-liter tank (when you run it completely empty).
Hello.
Translated on 27-07-2026, 20:37.
No new posts Audi A4, A5, A6, A7, Q5, Q7 3.0 TDI, Oil in the vacuum sy... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Octavia 1.8T TDI BMM: Power Loss Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.0 TDI BKD/AZV from 2004, Whistling/Squealing noise unde... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Regenerated Octavia 1.9 TDI BMM: Every 400km Diesel Engine Technology
No new posts TFL Scandinavia: What's the Deal? On-Board Diagnostics (OBD)
No new posts Timing Belt Audi A3 8V1 & Golf 7 2.0 TDI Diesel Engine Technology
No new posts Differences between the 2.0 TDI 120hp and 2.0 TDI 143hp e... Diesel Engine Technology
