Audi A8 PIN: Used MSG, WFS3, 2000 Model
Post11-05-2016, 21:16    Subject: Audi A8 PIN: Used MSG, WFS3, 2000 Model Quote
Hello everyone,
"On my father's Audi A8, manufactured in 2000 with the WFS 3 engine, the engine control unit (ECU) has failed. The ECU is still accessible via diagnostics, but it no longer communicates with other ECUs via CAN bus ("Missing message from ECU" in the transmission, ABS, climate control, and instrument cluster)."
To quickly narrow down the source of the problem (wiring vs. MSG), I bought a used MSG for 50€ on eBay and installed it. All the errors are now gone, but the WFS (Vehicle Function System) rightfully blocks the engine. Now, I've researched the issue and realized that I need not only the PIN for our WFS, but also the PIN for the used MSG I purchased. Of course, I don't have either of them.
Can Audi simply determine the PINs based on the vehicle and the now-installed, used MSG, or do I need the VIN or even more information from the donor vehicle from the seller? Is it enough to go to Audi with a car scan, ID, and vehicle registration and get both PINs that way?
"Could someone here in the forum possibly help me so we don't have to tow the car to Audi? I have the car's scan data from both the old and new control modules. I can gladly send you the vehicle registration documents, etc., if needed (or I can even show you via video chat that the ID belongs to my father). "
Guste.
Log-RD-HM 995-WAUZZZ4DZ1N001648-316910km-neues MSG3.txt
 Scan nach Fehlerspeicher löschen mit gebraucht erworbenen MSG. Einziger Fehler: MSG gesperrt.
 File name:  Log-RD-HM 995-WAUZZZ4DZ1N001648-316910km-neues MSG3.txt
 File size:  5.79 KB
 Downloaded:  877 times
Log-RD-HM 995-WAUZZZ4DZ1N001648-316910km-altes MSG.txt
 Scan mit altem, zum Fahrzeug gehörenden MSG.
Fehler: MSG meldet mit keinem anderen STG reden zu können. Getriebe, ABS, Lenkrad und Klima melden, nicht mit dem MSG reden zu können.
 File name:  Log-RD-HM 995-WAUZZZ4DZ1N001648-316910km-altes MSG.txt
 File size:  7.18 KB
 Downloaded:  1105 times
Translated on 08-10-2026, 10:57.
Post11-05-2016, 21:24    Subject: Audi A8 PIN: Used MSG, WFS3, 2000 Model Quote
Previously, the login could be queried, but today, everything runs online/internally through the tester, so they no longer see the login themselves. icon_sad.gif
Therefore, it can really only be done by Audi, or someone who has the appropriate hardware/software to read the data. icon_wink.gif
Translated on 08-10-2026, 10:59.
Post11-05-2016, 21:33    Subject: Audi A8 PIN: Used MSG, WFS3, 2000 Model Quote
Hi Guste,
if it's not easy to adapt (depending on the WFS generation, WFS-2 simply resets the adaptation channel, http://wiki.ross-tech.com/wiki/index.php/Immobilizer), I would simply desolder the serial EEPROM from the old control unit and solder it into the replacement control unit.
It will probably be an 8-pin SMD component, possibly a 24Cxx chip or some other Bosch part.
If you can provide a clear picture of the circuit board, I can tell you which component it is.
Translated on 08-10-2026, 11:00.
Wiesel
dieselschrauber likes this.
Post12-05-2016, 6:19    Subject: Audi A8 PIN: Used MSG, WFS3, 2000 Model Quote
Hi Guste,
That is an EDC15.
Reading the PIN via the K-line shouldn't be a problem.
(regarding old and new).
Micha
Translated on 08-10-2026, 11:01.
chli1976
Post12-05-2016, 7:44    Subject: Audi A8 PIN: Used MSG, WFS3, 2000 Model Quote
It will be easiest if you do it the way Rainer suggests.
You could also access the old PIN through the combination.
Please write me a private message.
VCDS
Translated on 08-10-2026, 11:02.
Post13-05-2016, 9:47    Subject: Audi A8 PIN: Used MSG, WFS3, 2000 Model Quote
Yesterday evening, I received quick and efficient help, like a weasel, which allowed me to solve the problem with the "diagnosis socket" with just a few clicks.
Thank you very much for all your tips and for sending me private messages. Special thanks are due to the person who lent the equipment to the renter.
Greetings.
Guste.
Translated on 08-10-2026, 11:03.
Post13-05-2016, 10:07    Subject: Audi A8 PIN: Used MSG, WFS3, 2000 Model Quote
guste100 wrote:
I was helped very quickly last night, like a weasel, so that the problem with the diagnosis socket could be solved with just a few clicks.
Thank you very much for all your tips and for sending me the private messages. Special thanks are due to the person who lent the equipment to the rental company.
Greetings.
Guste
icon_lol.gif Well, that's good then. To be honest, I didn't recognize the differently-looking metal box as an EDC15, but you could have figured it out based on the engine. icon_cool.gif
Translated on 08-10-2026, 11:04.
No new posts Passat combination instrument cluster 05.99 to 09.2000 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document 1J up to week 38/2000, ABS control light is on. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Draft Test / Performance Test 2000-4000 rpm Technical Articles
No new posts What happens at 2000 km? Diesel Engine Technology
No new posts Engine Knock at 2000 RPM Transmission, Chassis, Body & Interior
No new posts OBD2 Scanner for VW Passat 2000 PD Diesel Engine Technology
No new posts VAG COM and Audi A6 V6 TDI, Model Year 2000 On-Board Diagnostics (OBD)
