Error code 01276 - ABS hydraulic pump (V64) (Solution)
Post16-06-2016, 20:42    Subject: Error code 01276 - ABS hydraulic pump (V64) Quote
Error code 01276 - ABS hydraulic pump (V64), 012 - electrical fault in the circuit within the ABS control unit, often occurs with blown fuses for the ABS control unit.
Of course, the fault could also be due to damaged cables or connectors leading to the ABS control unit, as well as a defective ABS control unit itself.
Most of the time, you're lucky and the corresponding fuse is broken and only needs to be replaced.
Translated on 09-07-2026, 23:59.
Ratings - Error code 01276 - ABS hydraulic pump (V64)
No new posts Error code P1351 General Tips
No new posts ESP function test, error code 01486 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P244B Diesel Particulate Filter Differential Pressure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 01276 - ABS Hydraulic Pump V64 On-Board Diagnostics (OBD)
No new posts Polo 6N Hydraulic Pump Transmission, Chassis, Body & Interior
No new posts Audi A3 Hydraulic Pump Problem - 1996 Diesel Engine Technology
No new posts Error code Diesel Engine Technology
