Clutch Kit with Dual Mass Flywheel for VW Golf 3 AFN
Jaak
Post30-06-2016, 8:29    Subject: Clutch Kit with Dual Mass Flywheel for VW Golf 3 AFN Quote
Good day.
Since I'm in the process of renovating my 1997 Golf 3, I signed up because of the many helpful pieces of information available here. icon_smile_thumb_up.gif
I've been looking into clutches since yesterday, and I'm now confused by the clutch options available. I'm either finding clutches that are 220mm or clutches that are 228mm.
"The following options are available:"
220mm clutch (factory-installed).
228mm clutch (also compatible according to parts suppliers).
Since I found a Sachs 228mm clutch kit (including a DMF) at a good price, I wanted to know if it would fit without any issues. You can't really find helpful posts online because they usually focus more on tuning than on the clutch itself.
I don't want to install an EMS (Engine Management System), nor do I want to do any other major modifications.
Data about the Golf:
Volkswagen Golf 3 Cabrio, manufactured in 1997.
AFN engine / CYP gearbox (5-speed).
Thank you for your help.
Jacques.
Translated on 19-10-2026, 21:23.
RĂźdi
Karma: +645 / -0   Thank you, like it!
Post30-06-2016, 11:05    Subject: Clutch Kit with Dual Mass Flywheel for VW Golf 3 AFN Quote
Sure, here are the numbers of my favorite set.
Translated on 19-10-2026, 21:25.
Jaak
Post30-06-2016, 11:39    Subject: Clutch Kit with Dual Mass Flywheel for VW Golf 3 AFN Quote
Here's a selection:
SACHS 3000 951 005
=> 220 mm => I can't find a clutch master cylinder (CMC) anywhere online for that size.
SACHS 3000 951 790
"That would be the most interesting option in terms of price, BUT 228mm!"
This morning, I also called VW again to be sure, and according to AKTE, my Golf 3 has a 220mm clutch.
Of course, I could let the ZMS do that now, but since everything is open anyway.
With a LUK replacement kit, the torque specifications (NM values) cannot be found anywhere.
LuK Clutch Kit 600 0006 00
Translated on 19-10-2026, 21:26.
MatzeHH
Post12-07-2016, 18:55    Subject: Clutch Kit with Dual Mass Flywheel for VW Golf 3 AFN Quote
Is it possible to convert it to Ems?
Translated on 19-10-2026, 21:27.
DieselBär30x
Avatar-DieselBär30x
Post12-07-2016, 19:16    Subject: Clutch Kit with Dual Mass Flywheel for VW Golf 3 AFN Quote
Is this a question or a statement?
Do you have punctuation marks?
Jaak wrote:
... I don't want to install an EMS, nor do I want to do any other major modifications. ...
Whatever the case: Those who can read are usually at a clear advantage icon_smile_thumb_up.gif.
Best regards from Munich!
PS: Spamming here doesn't really make you more popular, you know *quietly noted*.
Translated on 19-10-2026, 21:28.
No new posts Golf 4 Clutch Slipping - 81kW Fix Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Noise / Clutch Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Clutch Squeal: A3 Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Problem with clutch/starter motor, Golf 4 TDI Transmission, Chassis, Body & Interior
No new posts Golf TDI: Upgrade Clutch for More Power Diesel Engine Technology
No new posts Golf III TD Clutch: Durability & Reviews Diesel Engine Technology
No new posts Clutch Slipping Golf 4 TDI ALH - Fix It! Diesel Engine Technology
