A lot of diesel in the oil
blackblizzard
Post17-06-2015, 9:40    Subject: A lot of diesel in the oil Quote
letzten Herbst habe ich bei einem BMP (8V, 103kW) den DPF gewechselt (incl. Oil).
After 15,000 km, I changed the oil again because there were about 8.5 liters in the engine!
What could be the causes: tandem pump, PD seals?
Translated on 21-07-2026, 15:58.
Post17-06-2015, 12:29    Subject: Subject: A lot of diesel in the oil Quote
You already mentioned it...
See also:
/viewtopic.php?t=25805&highlight=diesel+in+motor%C3%B6l
Translated on 21-07-2026, 15:59.
blackblizzard
Post12-07-2016, 18:29    Subject: A lot of diesel in the oil Quote
Okay, a late reply:
I have replaced the PD seals and the tandem pump because both were no longer working properly.
Now the oil level remains constant.
Here's what else I did:
With this high oil level, it's likely that some oil has been entering the exhaust system, which is putting a strain on the (relatively new) DPF. It was regenerating very frequently and could only reach approximately 25% regeneration.
Then I increased the ash content (which was in the single-digit percentage range) to 30% (which, in my opinion, makes sense if the DPF has been "contaminated" by the oil).
Now I've had some peace and quiet for a few thousand kilometers.
Translated on 21-07-2026, 16:01.
Post12-07-2016, 21:48    Subject: A lot of diesel in the oil Quote
Translated on 21-07-2026, 16:02.
No new posts DPF-Diesel and GSKs, Glow Plug Failure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts The fine particulate matter disaster and diesel engines w... Technical Articles
No new posts Diesel vs. Gasoline: Cost Comparison Technical Articles
No new posts Diesel Emissions: How Clean Should They Be? Diesel Engine Technology
No new posts Very convoluted circuit Diesel Engine Technology
No new posts Very early fuel injection start On-Board Diagnostics (OBD)
No new posts 2.0 TDI: High Fuel Consumption - CGLC Engine Diesel Engine Technology
