Central Locking: Rear Doors Won't Open?
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
Basti1605
Post18-07-2016, 18:10    Subject: Central Locking: Rear Doors Won't Open? Quote
Hello colleagues,
I have a Golf 5 here. The customer is complaining that the rear doors are not opening with the central locking system. They can be opened manually from the inside, but not from the outside. If the emergency locking mechanism (using the red lever on the lock) is not activated, the doors remain open.
There's an error in the log that I myself caused by disconnecting the connector (door lock, high level). Please disregard this error.
What are your experiences with this error? A colleague said: Replace the body control module and everything will be fine. Can I trust him? icon_smile.gif
Best regards, Basti.
Log-WVWZZZ1KZ5W002167-57800km.txt
 File name:  Log-WVWZZZ1KZ5W002167-57800km.txt
 File size:  17.31 KB
 Downloaded:  570 times
VCDS Support im Raum Hannover & Hildesheim
Translated on 13-09-2026, 2:20.
Basti1605
Post20-07-2016, 6:06    Subject: Central Locking: Rear Doors Won't Open? Quote
Does anyone really have any ideas?
Translated on 13-09-2026, 2:21.
klahaui
Avatar-klahaui
2019 Volkswagen Golf
dieselschrauber likes this.
Post20-07-2016, 7:35    Subject: Central Locking: Rear Doors Won't Open? Quote
I've encountered this problem on other VAG vehicles before.
A change in the door lock has always led to success in this case.
Greetings.
Basti1605
Post20-07-2016, 18:03    Subject: Central Locking: Rear Doors Won't Open? Quote
Here's my feedback:
I think I didn't express myself clearly and didn't describe my issue optimally. I assumed that the central locking system would probably work again after replacing the door locks. However, I was too focused on that stupid single-wire fault in the vehicle's onboard network.
So, I swapped the two rear door locks, and the central locking system is working properly again. The error in the Body Control Module (BCM) is still present, but it's not affecting any other functions.
Translated on 13-09-2026, 2:22.
klahaui
Avatar-klahaui
Post20-07-2016, 21:09    Subject: Central Locking: Rear Doors Won't Open? Quote
Evening.
Single-wire operation doesn't mean that communication has completely stopped.
It's just a bit "slower," and with a bit of bad luck, it might eventually stop working altogether.
Translated on 13-09-2026, 2:23.
Basti1605
Post21-07-2016, 18:40    Subject: Central Locking: Rear Doors Won't Open? Quote
I completely agree with you. However, the error that caused the single-wire operation was unfortunately not related to the door control system.
Finding the error probably won't be easy... However, the car has been picked up and the central locking system is working.
Thank you anyway icon_smile.gif.
Translated on 13-09-2026, 2:24.
No new posts Golf 3: Rear Door Corrosion - Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Roomster Tailgate Won't Open: Remote Button Issue Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Lupo Door Problems: 6X1 MJ 2002 Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Rear Door Problems: Sensor Not Detecting Opening On-Board Diagnostics (OBD)
No new posts How do I get speaker wire into the rear doors? Diesel Engine Technology
No new posts Are rear door speaker wires already pre-installed in the G4? Transmission, Chassis, Body & Interior
No new posts A3 8P: Central Locking Not Working with Key On-Board Diagnostics (OBD)
