Replace battery?
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
Hp2
Post23-07-2016, 13:04    Subject: Replace battery? Quote
I've been getting this error for a while now.
"Der schnelle braune Fuchs springt über den faulen Hund."
Address 09: Central Electronics
Label file: DRV\7H0-937-049.lbl
Part number: 7H0 937 049 AD.
Component: BORDNETZ SGVER 1.0 2101
Encoding: 0000103
Operating number: WSC 12345 123 12345
VCID: 74E0630F14A83E9E6A-5148
"1 error found:"
01598 - Battery voltage.
002 - lower limit exceeded.
Post24-07-2016, 11:50    Subject: Replace battery? Quote
The decision would also depend on the driving profile and the age of the vehicle.
Before that, however, I would use a battery tester (MWB), a starter generator tester (STG), and a multimeter to directly check the battery and ensure there is no excessive voltage drop.
PS: I've moved the topic. icon_wink.gif
Post24-07-2016, 14:38    Subject: Replace battery? Quote
Is that possible with your vehicle?
Hp2
Post25-07-2016, 10:04    Subject: Tax software not responding... Quote
So, is that not possible, or do I have a problem with my laptop?
T5 2009, 2.5L 5-cylinder, BNZ.
 Replace battery?
 File size:  8.35 MB
 Viewed:  1129 times
Post25-07-2016, 11:51    Subject: Replace battery? Quote
Your vehicle doesn't have a control unit with address 61 (battery management).
I would recharge the battery, clear any error codes, and check how the voltage behaves. Depending on the usage profile, it wouldn't be unusual for the battery to start losing performance after 7 years.
Post25-07-2016, 13:24    Subject: Replace battery? Quote
Alternatively, disconnect the battery and use the refresh function with a modern charger. That often helps, and it costs almost nothing (if such a charger is available), it's done quickly, and of course, it protects the environment. icon_smile.gif
No new posts Battery Drain: Audi A2 8Z0 MJ 2002 Doc Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Battery Care: Tips for Checking and Maintenance Technical Articles
No new posts Turbocharger Replacement: How to Replace It Diesel Engine Technology
No new posts Replace V6 Injectors: Guide & Parts Diesel Engine Technology
No new posts Replace T4 Dual Mass Flywheel Diesel Engine Technology
No new posts Replace Hands-Free System Diesel Engine Technology
