Problems with Micro-Can on Seat Alhambra
Polyp
Post27-07-2016, 18:31    Subject: Problems with Micro-Can on Seat Alhambra Quote
Hello everyone.
I've been the proud owner of a new Seat Alhambra 7N "diaper bomber" since last week.
I was really looking forward to using my new Micro-CAN diagnostic interface (with the latest software version from the store) to make some coding changes. However, I'm unfortunately experiencing a small problem.
I was able to code the desired adjustments for some individual control units, but in most cases, the message "Vehicle/model not supported" appears.
For example, access to modules STG42 and STG52 works perfectly. The field "Coding - 07" appears, and adjustments can be coded and saved. When accessing modules STG08, 09, 17, etc., the error message mentioned above always appears, and besides the fields "Error Codes - 02", "Extended ID - 1A", and "Single Measurement Value - 09", nothing else can be selected.
I've also tried all the USB ports, but I always get the same result. The LED lights up green, and the Autoscan function works perfectly.
Does anyone have any idea what might be causing this? Am I making a typical beginner mistake?
Thank you in advance for your help.
Best regards from Lake Zurich.
Urs.
Autoscan:
VCDS version: RKS 15.7.4 is running on Windows 10 x64.
Data as of: 20160602.
Wednesday, July 27, 2016, 17:16:33:38306
Vehicle type: 7N (7N0)
Scan: 01 02 03 05 08 09 10 15 16 17 18 19 25 2B 3C 42 44 46 4C 4F
52 53 55 5F 61 62 6C 6D 72 A5 BE BF
Vehicle Identification Number: VSSZZZ7NZHV702210
01-Motor electronics -- Status: OK 0000
02-Gearbox -- Status: OK 0000
03-Brake electronics -- Status: OK 0000
04-Steering angle sensor -- Status: OK 0000
05-Access/Startup Report -- Status: OK 0000
08-Climate control/heating unit - Status: OK.
09-Central Electrical System -- Status: OK.
Parking Assist System 2 -- Status: OK 0000
15-Airbag -- Status: OK 0000
16-Wheel steering electronics -- Status: OK 0000
17-Terminal block insert -- Status: OK 0000
18-Heater -- Status: OK 0000
19-Diagnosis interface -- Status: OK 0000.
Immobilizer system -- Status: OK 0000
2B steering column lock. -- Status: OK 0000.
3C Lane Change -- Status: OK 0000
42-door electric driver -- Status: OK 0000
Steering assist - Status: OK 0000.
46-Comfort System -- Status: OK 0000
4C Tire Pressure II -- Status: OK 0000
4F Main Electrical System II -- Status: OK 0000
52-door electric passenger door - Status: OK 0000.
53-Parking brake -- Status: OK 0000
55-Beam adjustment. -- Status: OK 0000.
5F-Information Selection. I -- Status: OK 0000.
61-Battery regulation -- Status: OK 0000
62- Door, electric, left and right -- Status: OK 0000
6C Rear View Camera -- Status: OK 0000
Rear hatch (6D) - Status: OK 0000.
72- Door, electric, high, right side -- Status: OK 0000
A5 Front/Forward-facing camera -- Status: OK 0000
Rear left sliding door (BE version) - Status: OK.
Rear right sliding door (BF) - Status: OK.
"Die Sonne scheint hell und warm. Die Vögel zwitschern fröhlich in den Bäumen. Ein leichter Wind weht durch das Feld und lässt das Gras sanft wiegen. Es ist ein wunderschöner Tag."
The sun is shining brightly and warmly. The birds are chirping happily in the trees. A gentle breeze blows through the field, causing the grass to sway softly. It's a beautiful day.
Address 01: Engine Control Module (J623-DFMA)
Label file: None.
Part number SW: 04L 906 016 HK, Part number HW: 04L 907 309 K.
Component: R4 2.0L EDC; Part Number: H20 1629.
Revision: 8AH20---
Encoding: 011D003A042401083000
Operating number: WSC 00020 999 00000
ASAM Dataset: EV_ECM20TDI01104L906016HK 001003
ROD: no value.
VCID: 79D6B4EBF84CF0F639-802C
Vehicle/model not supported.
No ASAM data available: "EV_ECM20TDI01104L906016HK" ().
No error codes found.
Readiness: 0 0 0 0 0
Address 02: Transmission Label file: DRV\02E-927-770.lbl
Part number SW: 02E 300 063 C, HW: 02E 927 770 AL.
Part number: GSG DSG AG6 540 4906.
Revision: 06354004 Serial Number: 00001605150458
Encoding: 0000020
Operating number: WSC 00020 790 00000
VCID: 160C9F5721123F8EB4-8042
Address 03: Brake Electronics (J104)
Label file: DRV\5N0-614-109-V1.clb
Part number SW: 5N0 614 109 CF. Hardware: 5N0 614 109 CF.
Component: ESC-EBC460iV1 H10 0013
Serial number: A017CPR
Encoding: 12F0449A0920C26E0879480122C3904310391700F00B4995
ASAM Dataset: EV_Brake1ESCEPBTRW 006353
ROD: no value.
VCID: 71C68CCBA03CB8B681-8024
No ASAM data available: "EV_Brake1ESCEPBTRW" ().
Address 05: Access/Startup Authorization (J518)
Label file: DRV\5K0-959-434.clb
Part number SW: 5K0 959 434 G, HW: 5K0 959 434 G.
Part number: VWKESSYPQ35GP 092 1305
Revision: 00092000 Serial Number: 0406560436
Encoding: 03300C
Operating number: WSC 00020 999 39850
ASAM Dataset: EV_KESSYPQ35G A02717
ROD: no value.
VCID: 395674EBB8CC30F679-806C
No ASAM data available: "EV_KESSYPQ35G" ().
Address 08: Climate Control/Heating Unit (J255)
Label file: DRV\5K0-907-044.clb
Part number SW: 7N0 907 044 AQ, Hardware part number: 7N0 907 044 AQ.
Part: Clima-Sharan H03 0606.
Revision: 00001K05
Encoding: 021010C549
ASAM Dataset: EV_ClimatronicSharan A01005
ROD: no value.
VCID: 7F225AF3E668DEC607-802A
Subsystem 1 - Part number SW: 7N0 907 049 C, HW: 7N0 907 049 C.
Component: KBT-H 004 0103
Serial number: 20160603000000060879.
No ASAM data available: "EV_ClimatronicSharan" ().
Address 09: Central Electronics (J519)
Label file: DRV\1K0-937-08x-09.clb
Part number SW: 5K0 937 086 T, Hardware part number: 5K0 937 086 T.
Component: BCM PQ35 M, Part Number: 122 0183.
Revision: BC122001
Encoding: 60590A3B892508C4508800C8B400897403D50008676D2DB26484C720A2C1
Operating number: WSC 00020 790 12345
VCID: 45AE081BCC3444160D-8010
Subsystem 1 - Part number SW: 7N1 955 119 B, HW: 7N1 955 119 B, Label file: DRV\1KX-955-119.CLB.
Component: WWS428 030516 024 0644
Encoding: 004DBD
Subsystem 2 - Part number SW: 5Q0 955 547 B HW: 5Q0 955 547 B Label file: DRV\5Q0-955-547.CLB
Component: RLHS 042 0105
Encoding: 0228BB
Address 10: Parking Assist 2 (J791)
Label file: DRV\1Q0-919-475.clb
Part number SW: 7N0 919 475 E, HW: 5Q0 919 298 C.
Part number: PLA 3.0 12KH08 0005
Serial number: 000305183616159
Encoding: 0071167051
ASAM Dataset: EV_EPHVA3CVW428GP00 001005
ROD: no value.
VCID: 3D5E60FBACE40CD655-8068
No ASAM data available: "EV_EPHVA3CVW428GP00" ().
Address 15: Airbag (J234)
Label file: 5K0-959-655.clb
Part number SW: 7N0 959 655 D, Hardware part number: 7N0 959 655 D.
Part number: VW10Airbag10X H15 0016.
Serial number: 003PWPB97DXT
Encoding: 003058
ASAM Dataset: EV_AirbaVW10TS6VW428 A01010
ROD: no value.
VCID: 40A0190FDB16613E3E-8014
Subsystem 1 - Part number: Software: --- Hardware: ---
Component: S.Sens.Fahr.V --- ---
Serial number: 3493ETS60D186A21C9D%.
Encoding: 000000
Subsystem 2 - Part number: Software: --- Hardware: ---
Component: S. Sensor, Passenger Side --- ---
Serial number: 3503ETS606F0FA21CDD3.
Encoding: 000000
Subsystem 3 - Part number: Software: --- Hardware: ---
Component: S.Sens.Fahr.H --- ---
Serial number: 3513ETS60B793A21CDD+
Encoding: 000000
Subsystem 4 - Part number: Software: --- Hardware: ---
Component: Side sensor, passenger side --- ---
Serial number: 3523ETS600D21A71C9DT
Encoding: 000000
Subsystem 5 - Part number: SW: --- HW: ---
Component: F. Sens. Fahr --- ---
Serial number: 35540TS60B836A81CDD.
Encoding: 000000
No ASAM data available: "EV_AirbaVW10TS6VW428" ().
Address 16: Steering wheel electronics (J527)
Label file: DRV\5K0-953-569.clb
Part number SW: 5K0 953 501 DQ, HW: 5K0 953 569 AP.
Component: STEERING MODULE 016 0180
Revision: FF010042 Serial Number: 20160607200898
Coding: 3112240000
ASAM Dataset: EV_VW360SteerWheelUDS A03004
ROD: no value.
VCID: 7CD8ADFFF77EC5DE22-8028
Subsystem 1 - Part number SW: 7N5 919 719, HW: 7N5 919 719, Label file: DRV\3C8-959-537.CLB.
Component: E221__MFL-PR6 H04 0130
Serial number: 000000000B1431180516
Encoding: 011000
No ASAM data available: "EV_VW360SteerWheelUDS" ().
Address 17: Control panel module (J285)
Label file: DRV\5K0-920-xxx-17.clb
Part number SW: 7N5 920 880 D, HW: 7N5 920 880 D.
Component: COMBINATION UNIT H04 1104
Serial number: 00000000000000
Encoding: 110F010800
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
ROD: no value.
No ASAM data available: "EV_Kombi_UDS_VDD_RM09" ().
Address 18: Auxiliary heater
Label file: DRV\1K0-815-007.clb
Part number: 7N0 963 272 E
Component: Portable heater 044 4941
Revision: 00044000 Serial Number: 09028239000000
Coding: 0031142
VCID: 375272D346D826868F-8062
Address 19: Diagnostic interface (J533)
Label file: None.
Part number SW: 7N0 907 530 BL, HW: 7N0 907 530 AN.
Component: J533 Gateway H56 1682.
Revision: H56 Serial Number: 030616F1000604
Encoding: 468232
VCID: 7BDAAEE3FA70C2E62B-802E
Address 25: Immobilizer (J334)
Label file: DRV\5K0-920-xxx-25.clb
Part number SW: 5K0 953 234, HW: 5K0 953 234.
Component: IMMO H04 1104
Serial number:
Encoding: 000007
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
ROD: no value.
VCID: 6AF49BA78DEA4B6EC0-803E
No ASAM data available: "EV_Immo_UDS_VDD_RM09" ().
Address 2B: Steering column lock. (J764)
Label file: DRV\5K0-905-861.clb
Part number SW: 5K0 905 861 D, Part number HW: 5K0 905 861 D.
Component: ELV-PQ35 H22 0240
Revision: 00000000 Serial Number: 16000053405002
Encoding: 4900000000000000
ASAM Dataset: EV_ELVMarquMPVW36X A01001
ROD: no value.
VCID: 31464CCB60BCF8B6C1-8064
No ASAM data available: "EV_ELVMarquMPVW36X" ().
Address 3C: Lane Change (J1086)
Label file: None.
Part number SW: 5Q0 907 686 B. Part number HW: 5Q0 907 686 B.
Component: HRE_Master H12 0071
Serial number: 0405596751
Encoding: 02011102
ASAM Dataset: EV_HREntryHella 001028
ROD: no value.
VCID: 3C586DFFB7FE05DE62-8068
No ASAM data available: "EV_HREntryHella" ().
Address 42: Door electrical driver (J386) Label file: 7N0-959-793.clb
Part number SW: 7N0 959 793 J, HW: 7N0 959 793 G.
Component: TSG FA H05 0561
Revision: Serial number: 0000201343157
Encoding: 01112F20D000411011
VCID: 49B6042BE02CA076E9-801C
Address 44: Steering Assist
Label file: DRV\5N1-909-144.clb
Part number SW: 5N1 909 144 S, HW: 5N1 909 148 K.
Component: J500__APA-BS Class 325 1501
Revision: 1BH04740 Serial Number: 00161380191901
Encoding: 0000258
VCID: 42A413071D1A732E28-8016
Address 4C: Tire Pressure II.
unavailable
Address 4F: Central Electricity II (J520)
Label file: DRV\1K0-907-532.clb
Part number SW: 7N0 907 532, HW: 7N0 907 530.
Component: EZE_2 H56 1682
Encoding: 050A0100
VCID: 6FC28AB3BE08AE4697-803A
Subsystem 1 - Part number SW: 7N0 959 591 B, HW: 7N0 959 591 B.
Component: J245EE04SKB03 H04 0090
Subsystem 2 - Part number SW: 7N0 959 591 B, HW: 7N0 959 591 B.
Component: J394EE04SKB03 H04 0090
Address 52: Power door lock, front passenger side (J387) Label file: 7N0-959-792.clb
Part number SW: 7N0 959 792 J, HW: 7N0 959 792 G.
Component: TSG BF H05 0561
Revision: Version
Serial number: 0000202298200
Encoding: 01112D20DE00411011
VCID: 48B0012FFB26597EF6-801C
Address 55: Headlight range adjustment (J745) Label file: DRV\5M0-907-357-V3.clb
Part number SW: 5M0 907 357 F, HW: 7L6 907 357 C.
Component: AFS-ECU H05 0111
Revision: -------- Serial Number: --------------
Encoding: 068200000B000000
ASAM Dataset: EV_HeadlRegulVWAFSPt 002016
ROD: no value.
VCID: 375272D38ED826868F-8062
Subsystem 1 - Part number SW: 1T0 941 329 B, HW: 1T0 941 329 B, Label file: 3D0-941-329.CLB.
Part: Left LeiMo, H06 0009.
Encoding: 3B0000
Subsystem 2 - Part number SW: 1T0 941 329 B, HW: 1T0 941 329 B, Label file: 3D0-941-329.CLB.
Part: Right-hand LeiMo H06 0009.
Encoding: 3B0000
No ASAM data available: "EV_HeadlRegulVWAFSPt" ().
Address 5F: Information selection. I (J794) Label file: None.
Part number SW: 7N5 035 680 C, HW: 7N5 035 680 C.
Component: MU-S-ND-ER H30 0351
Serial number: SEZAZ2S5008941
Encoding: 04240801FF00000011111101008808001F0106C40020010086
ASAM Dataset: EV_MUStd4CTSAT 001022
ROD: no value.
VCID: 334A46C39AA0CAA6B3-8066
Subsystem 1 - Part number SW: 6P0 919 866 H HW: -----------
Component: ECE1 2016/17 --- 0635
Serial number: --------------------
No ASAM data available: "EV_MUStd4CTSAT" ().
Address 61: Battery Management (J840)
Label file: DRV\1K0-907-534.clb
Part number SW: 7N0 907 534, HW: 7N0 907 530.
Component: Battery management system H56 1682.
Serial number: 030616F1000604.
Encoding: 030F1873
VCID: 71C68CCBA83CB8B681-8024
Subsystem 1 - Part number SW: 1K0 915 181 L, HW: 1K0 915 181 L.
Component: J367-BDM H07 0270
Address 62: Door electric, left/right (J388) Label file: 7N0-959-794.clb
Part number SW: 7N0 959 794 L, HW: 7N0 959 794 H.
Component: TSG HL H03 0561
Revision: Version
Serial number: 0000196160828
Encoding: 01006D200000411001
VCID: 4CB83D3FEF5EB55ED2-8018
Address 6C: Rear view camera (J772)
Label file: 5Q0-907-441.clb
Part number SW: 7N0 907 441 B, Hardware part number: 7N0 907 441 B.
Part number: VW428 RVC Mid H04 0040.
Encoding: 012408012201000700
ASAM Dataset: EV_CamSysRearPANAVW428 002002
ROD: no value.
VCID: 304049CF6BB6F1BECE-8064
No ASAM data available: "EV_CamSysRearPANAVW428" ().
Address 6D: Rear door (J605)
Label file: DRV\7N0-959-107.clb
Part number SW: 7N0 959 107 G, HW: 7N0 959 107 A.
Component: HDSG Module H11 0250.
Revision: 41011001 Serial number: 134600817
Encoding: 0733334002
ASAM Dataset: EV_HDSGVW428 201138
ROD: no value.
VCID: 3B5A6EE3B2F002E66B-806E
No ASAM data available: "EV_HDSGVW428" ().
Address 72: Door electric strike, high, right (J389) Label file: 7N0-959-794.clb
Component: TSG HR H03 0561
Revision: Version
Serial number: 0000201187412
Address A5: Front/Forefield camera (R242)
Label file: DRV\3Q0-980-654.clb
Part number SW: 3Q0 980 654 F, HW: 3Q0 980 654.
Component: MQB_B_MFK H04 0220
Serial number: 31051611K10840.
Encoding: 030402080000040100261302C080400090000E100020
ASAM Dataset: EV_MFKBoschMQBB 001001
ROD: no value.
VCID: 3A546BE7BDCA3BEE70-806E
No ASAM data available: "EV_MFKBoschMQBB" ().
Address BE: Rear left sliding door (J558)
Label file: 7N0-959-244.clb
Part number SW: 7N0 959 244 B, HW: 7N0 959 244 B.
Component: Sliding door_l 005 2414
Serial number: 16191309.
ASAM Dataset: EV_AST A03704
ROD: no value.
VCID: 385071EF83C629FE86-806C
No ASAM data available: "EV_AST" ().
Address BF: Rear right sliding door (J731)
Component: Sliding door _ 005 2414
Serial number: 16191096
ROD: no value.
End----------------------------(Duration: 03:43)-----------------------------
Translated on 12-07-2026, 15:12.
Post27-07-2016, 19:48    Subject: Problems with Micro-Can on Seat Alhambra Quote
Dein Fahrzeug ist zu neu, bitte auf das nächste VCDS Release warten. icon_idea.gif
Your vehicle is a 2017 model year, and today is July 27, 2016.
You can't expect that your device will suddenly be released and that a company called Ross-Tech, which has nothing to do with the VAG group, will magically provide complete support for your car overnight.
Translated on 12-07-2026, 15:13.
Polyp
Post27-07-2016, 20:28    Subject: Problems with Micro-Can on Seat Alhambra Quote
Hello.
Thank you for the quick feedback.
"I'm sorry, I wasn't aware that so much changes with a model year update."
I thought it was just minor details and that the majority would be the same.
Best regards.
Urs.
Translated on 12-07-2026, 15:14.
Post27-07-2016, 20:41    Subject: Problems with Micro-Can on Seat Alhambra Quote
Polyp wrote:
I thought these were just minor things and that the majority would be the same.
A newer software version on the identical control unit is already enough. icon_wink.gif
No new posts Electrical problem in wet conditions, Seat Ibiza 6L ASZ Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Broken sun visor clip for Audi, Seat, Skoda, VW Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Speed Control Retrofit Seat Ibiza / Polo Troubleshooting & Guides
This topic is locked, you cannot edit or reply. Seat Alhambra, MSG disabled (RESOLVED) On-Board Diagnostics (OBD)
No new posts Seat Alhambra 2.0 TDI constantly regenerating Diesel Engine Technology
No new posts Seat Alhambra: Sliding Door Auto Close Coding On-Board Diagnostics (OBD)
No new posts Fixing a car with a corrupted system / Seat Alhambra 2014 On-Board Diagnostics (OBD)
