PD Golf V starts very poorly
Tommy122
Post28-07-2016, 18:30    Subject: PD Golf V starts very poorly Quote
I'm having a problem with my Golf V PD 105 hp (manufactured in 2007).
The car, when left standing overnight, usually takes about 30 seconds to start! This problem doesn't always occur, but it happens most of the time!
He's revving it up completely, and then after about 30 seconds, it starts! It's like he's missing his diesel!
Since the tandem pump was leaking, I thought that must be the problem! I've just resealed it, but the problem still persists!
Does anyone have any idea what that might be?
Possibly the pump in the tank? I was told that this has a check valve, and it's possible that the valve is open, which could allow fuel to flow back into the tank.
Post28-07-2016, 20:19    Subject: PD Golf V starts very poorly Quote
Perhaps the pump in the tank? I was told that this
has a check valve, and it's possible that this valve is open, which could cause the fuel to flow back into the tank ?????
If that were the case, the problem should be less noticeable when the tank is full.
Based on my gut feeling, I would say the PD units are leaking.
Tommy122
Post28-07-2016, 20:30    Subject: PD Golf V starts very poorly Quote
Okay, I've never observed that behavior with a full tank. I'll test it, though!
Thank you.
Tommy122
Post02-08-2016, 15:27    Subject: PD Golf V starts very poorly Quote
Hello!
Okay, I tried what you suggested about the tank, but it doesn't change anything!
I've now replaced the seals on the tandem pump, and it's leak-free!
It still doesn't start properly if it sits for a day!
I'm about to lose it with this car!
Post03-08-2016, 10:30    Subject: PD Golf V starts very poorly Quote
Check the idle speed (using VCDS)!
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 5 1.4 BUD Misfire 2. Cylinder Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. Audi A6 2.5 TDI: Starting Problems, Won't Start Diesel Engine Technology
No new posts Tacho Golf 3 an 6-GangGetriebe aus Golf 4-> kein Signal ? Diesel Engine Technology
No new posts Golf 2 GTD/16V: Brake Caliper & Wheel Bearing Mount Transmission, Chassis, Body & Interior
This topic is locked, you cannot edit or reply. Golf 3 TDI: Install 6-Speed Golf 4 Transmission Diesel Engine Technology
