DieselBĂ€r30x Profi-Schrauber
Joined: 01/17/2008 Posts: 3560 Karma: +101 / -0 Location: MĂŒnchen & Passau
29-07-2016, 15:39 Subject: Re: Seat Ibiza 6L GRA - No function, unlocking not possible |
Hello everyone!
prima5-heitzer wrote: |
Address 15: Airbag
Label file: DRV\6Q0-909-605-VW5.lbl
Part number: 6Q0 909 605 AE.
Part: 0H AIRBAG VW5 0C 0010
Encoding: 12360
Operating number: WSC 06401
VCID: 7AFC3F9866B1C1EE30-5164
"1 error found:"
00588 - Airbag igniter (driver side) (N95)
33-00 - Resistance value too low |
...this likely indicates a crushed component/wire, as it suggests a short circuit rather than a break in the connection.
What's the current status of the GRA and the MWBs?
Is it working now?
Best regards from Munich! 1. S.verlÀngerung: Audi A4 Avant quattro, 1,9 TDi MKB: AFN, BJ98, Vollausstattung, +VP1L
3. T5 1,9 TDI PD (AXC), BJ04 - nur Ărger!
Translated on 05-07-2026, 22:33.
Wiesel Profi-Schrauber
Joined: 04/06/2008 Posts: 896 Karma: +43 / -0 Location: Schleswig-Holstein
DieselBĂ€r30x likes this. |
31-07-2016, 13:48 Subject: Re: Seat Ibiza 6L GRA - No function, unlocking not possible |
DieselBĂ€r30x wrote: | ...more likely indicates a CRUSHED component/wire, as it suggests a short circuit rather than an open circuit.
No
The connectors are designed such that when disconnected, they always create a short circuit bridge towards the spark plug.
close, long before the actual connections are severed.
So, if the plug is not fully inserted -> short circuit.
Micha Touran 5T1 / DFGA / TGV; Fabia 6Y5 / BNV / GGV
Translated on 05-07-2026, 22:35.
prima5-heitzer
Joined: 05/17/2016 Posts: 12 Karma: +0 / -0 Location: köln
03-08-2016, 15:35 Subject: Re: Seat Ibiza 6L GRA - No function, unlocking not possible |
Unfortunately, I haven't had time to experiment with it yet.
I always intend to do it before the end of the workday, but it usually ends up being too late.
I will definitely report back on what I find or what values I get.
Translated on 05-07-2026, 22:36.
prima5-heitzer
10-08-2016, 18:12 Subject: Re: Seat Ibiza 6L GRA - No function, unlocking not possible |
I have found the following:
According to MWB 6, my GRA is enabled but not active.
According to MWB 22, my device only displays the switch position "000000", regardless of the lever's actual position. So, there must be a problem with the wiring, right?
Joined: 04/12/2002 Posts: 18128 Karma: +803 / -0 Location: St.Gallen 2018 Volkswagen T6
10-08-2016, 18:25 Subject: Re: Seat Ibiza 6L GRA - No function, unlocking not possible |
According to MWB 22, my device only displays the switch position "000000", regardless of the lever's actual position. Therefore, there must be a problem with the wiring, right? |
Correct.
Translated on 05-07-2026, 22:37.
Profile PM WWW Garage |
