Tiptronic Problems Audi A4 B5 2.5 TDI
ehc_alex66
Post11-08-2016, 15:41    Subject: Tiptronic Problems Audi A4 B5 2.5 TDI Quote
Hello there,
I've been having significant problems with my Tiptronic transmission for quite some time.
Audi A4 B5, 2.5 TDI, manufactured in 05/1999, engine code: AFB, gearbox code: EFR.
According to the diagnostic software (unfortunately, I don't have VCDS yet):
18152 - P1744 Tiptronic switch, detection (F189) - Short circuit to ground.
17090 - P0706: Gear shift sensor - implausible signal, 35-00.
The following attempts have already been made without success:
Transmission oil flush, multifunction switch replaced, transmission control unit replaced, and switch F189 replaced!
I honestly have no idea what else it could be!
Except for the fact that it's in limp mode, the transmission is running smoothly without any jerking!
Translated on 17-10-2026, 12:49.
Karma: +645 / -0   Thank you, like it!
Post12-08-2016, 14:02    Subject: Tiptronic Problems Audi A4 B5 2.5 TDI Quote
Were new parts installed, or were used parts installed without proper inspection?
Translated on 17-10-2026, 12:51.
ehc_alex66
Post12-08-2016, 14:23    Subject: Tiptronic Problems Audi A4 B5 2.5 TDI Quote
The multi-switch is a brand new part, while the control unit (STG) and the F189 are tested used parts!
Post12-08-2016, 15:01    Subject: Tiptronic Problems Audi A4 B5 2.5 TDI Quote
... then, only the wiring and connectors remain as potential sources of error for the selector switch. icon_idea.gif
ehc_alex66
Post12-08-2016, 17:05    Subject: Tiptronic Problems Audi A4 B5 2.5 TDI Quote
I was afraid of that. So, tomorrow I'll need to jack up the Audi and check the connectors and wiring. While I'm at it, I'll also test the new multiplexer!
"Today, I checked the sensor blocks for the switch position, and there's absolutely nothing coming through. If I'm interpreting the wiring diagram from ELSA correctly, doesn't the transmission control unit receive this information from the multi-switch?"
Translated on 17-10-2026, 12:52.
ehc_alex66
Post13-08-2016, 13:25    Subject: Tiptronic Problems Audi A4 B5 2.5 TDI Quote
Since the error can now only be electrical, I've started from scratch and gone through everything again.
Fuse checked, OK. Disassembled the connector from the multi-switch and initially checked the supply voltage with the ignition on; it was too low (0.03V) or not present at all.
On Monday, I'll be going to the workshop first, where they supposedly tested the multi-switch and then replaced it.
I doubt the multi-switch was defective, because if it's not receiving power, it can hardly send a signal to the control unit indicating which gear is engaged!
I will keep you updated on the progress!
Translated on 17-10-2026, 12:53.
ehc_alex66
dieselschrauber likes this.
Post17-08-2016, 11:10    Subject: Tiptronic Problems Audi A4 B5 2.5 TDI Quote
The solution to the problem was that three cables leading to the multi-switch had been cut. The multi-switch has been repaired, and the timing belt will also be replaced. I will provide the timing belt kit, and the workshop will replace the timing belt at no cost to me, as compensation for the incorrectly replaced multi-switch.
Translated on 17-10-2026, 12:54.
Post17-08-2016, 21:51    Subject: Tiptronic Problems Audi A4 B5 2.5 TDI Quote
Translated on 17-10-2026, 12:55.
ehc_alex66
Post17-08-2016, 22:04    Subject: Tiptronic Problems Audi A4 B5 2.5 TDI Quote
That's the way it should be icon_cool.gif.
No new posts AGR Problems: 1.4 16V Gasoline Engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Cruise Control Installation Problems Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A2 8Z0 MJ 2002, Problems with the Main Control P... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi 2.5 TDI AKE - Issues with dynamic fuel injection timing Diesel Engine Technology
No new posts Audi A6 C6 Tiptronic transmission fluid change Transmission, Chassis, Body & Interior
No new posts Jerky acceleration in Audi S5 V8 with 6-speed Tiptronic Transmission, Chassis, Body & Interior
No new posts Differences in MSG for Audi 2.5 TDI AAT engines On-Board Diagnostics (OBD)
