Passat 3C Project: Next Steps & Details
Manuel26
Post15-08-2016, 21:23    Subject: Passat 3C Project: Next Steps & Details Quote
Hello!
After my Passat (3B) has had its service, I will be focusing on my girlfriend's car. icon_lol.gif
Engine code: CBAB (140 hp common rail).
Year of manufacture: 2008.
Mileage: 179,000 km
A heat pump system combined with a wood-burning stove is definitely being considered.
Since I'm not very familiar with the 3C yet, my question is:
What other changes would you make, or what needs to be changed?
Furthermore: Do I need any special tools?
Sure, here's the translation:
'Thank you in advance.'
Manuel
Translated on 16-08-2026, 15:53.
Post16-08-2016, 22:47    Subject: Passat 3C Project: Next Steps & Details Quote
"Hi,"
Yes, special tools are recommended (e.g., a crankshaft locking tool). There's likely also something to lock the high-pressure pump in place. Also, you'll need a wrench to turn (adjust) the tensioner pulley.
Translated on 16-08-2026, 15:55.
dieselschrauber likes this.
Post05-09-2016, 12:24    Subject: Passat 3C Project: Next Steps & Details Quote
In addition, I would like to add that a few markings on the pulleys made with a marker are not necessarily a defect, especially if you don't have a routine for such things.
We've already seen enough artists around here who ended up in the wrong place with unfortunate consequences.
Translated on 16-08-2026, 15:56.
Basti1605
Post07-09-2016, 8:57    Subject: Passat 3C Project: Next Steps & Details Quote
Okay, as Rainer already mentioned, you'll need a crankshaft locking tool, two camshaft alignment pins, and the fuel pump impeller. Drill bits might also be useful (possibly 8mm?).
"For the tensioning roller, you'll need a 6mm Allen key. Be very careful with the valve timing and make sure the dowel pin can slide in and out of its hole easily."
It's also important to properly bleed the cooling system. We do this using a vacuum pump.
VCDS Support im Raum Hannover & Hildesheim
Translated on 16-08-2026, 15:57.
No new posts Install Parking Heater in VW Passat 3BG Troubleshooting & Guides
This topic is locked, you cannot edit or reply. Passat 3BG 2005 Door Opening Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat B5: Intercooler Hose Special Offer - 74/96 kW Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Project for the winter season Transmission, Chassis, Body & Interior
No new posts Audi A4 B5 ASR/EDS Retrofit: Installation Guide Transmission, Chassis, Body & Interior
No new posts Head-up Display & IR Camera: A Crazy Project Transmission, Chassis, Body & Interior
No new posts Engine Data Display: Project & Key Metrics On-Board Diagnostics (OBD)
