MyAutoscan: Function and Features Explained
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
Post22-09-2016, 14:36    Subject: MyAutoscan: Function and Features Explained Quote
I want to create a "MyAutoscan" listing for a Volkswagen Golf (model with 4 cylinders) that belongs to a friend, and I want it to be available as an option for potential buyers.
I did that by modifying the "MyAutoscan.txt" file in the VCDS directory, but in the Autoscan window, I always only see the option "Automatic Detection" along with the vehicle types listed in the "Autoscan.txt" file in the dropdown menu.
Question: How do I get my individual vehicles from the list "MyAutoscan.txt" into the dropdown menu? icon_eek.gif
Translated on 18-08-2026, 20:26.
Karma: +438 / -0   Thank you, like it!
Post22-09-2016, 21:07    Subject: MyAutoscan: Function and Features Explained Quote
Hi Ulf,
I've never experimented with MyAutoscan. I always just directly modified the Autoscan file, which worked well.
Sure.
Here is the translation of the text from German to English:
"Guste" means "gust" in English. It can also be used as a verb, meaning "to gust."
Translated on 18-08-2026, 20:28.
Post22-09-2016, 22:18    Subject: MyAutoscan: Function and Features Explained Quote
Hi Ulf,
It worked perfectly for me right away. All the semicolons (icon_wink.gif in the file indicate a comment.
You only need to remove the semicolon from the line that says "Ulfs Auto" and adjust the device addresses (everything after "Ulfs Auto") to your desired values.
The advantage of using MyAutoScan.txt compared to modifying the Autoscan.txt file is that with MyAutoScan.txt, the created file should be preserved during updates (or at least easier to back up), while changes to Autoscan.txt are overwritten without mercy.
 File size:  167.59 KB
 Viewed:  830 times
Translated on 18-08-2026, 20:29.
Post23-09-2016, 8:28    Subject: MyAutoscan: Function and Features Explained Quote
Hi Rainer,
dieselschrauber wrote:
All ; in the file introduce a comment.
You only need to remove the semicolon (`;`) in the line with "Ulfs Auto".
That semicolon was the key issue - I deleted it from MyAutoscan, and now the individual car appears at the top of the dropdown menu. icon_smile_thumb_up.gif
To make the manual a little more user-friendly, I would like to include the following note icon_wink.gif.
Translated on 18-08-2026, 20:30.
Post23-09-2016, 10:21    Subject: MyAutoscan: Function and Features Explained Quote
ulf wrote:
Hi Rainer,
Translated on 18-08-2026, 20:32.
No new posts Document A2 8Z0 MJ 2002, The radio displays "Transport" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Rain Shield" by No Touch: Practical Test General Tips
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Service reminder function with VCDS" On-Board Diagnostics (OBD)
No new posts AGR Function: Questions and Answers Diesel Engine Technology
No new posts Passat 08/01 MKB "AVF" GKB "EYF" Getrieb Diesel Engine Technology
No new posts Driving Too Dumb? A Brave New World Diesel Engine Technology
