gib8
Joined: 02/02/2003 Posts: 6 Karma: +1 / -0 Location: NÖ
dieselschrauber likes this. |
22-05-2003, 21:20 Subject: OBD2 Pinout: Connector and Wiring Explained |
Hello!
For a 1999 Audi A3 TDI with 110 horsepower (AFH engine), the following pins are connected on the OBD diagnostic connector: 1, 4, 5, 7, and 16.
The reading of the control units functions smoothly via connectors 4, 7, and 16.
What is the purpose of connectors 1 and 7?
I couldn't find anything about that in the forum!
Sure, here's the translation:
"Thank you in advance."
Bernhard.
Translated on 24-08-2026, 6:59.
Gremlin Guest
23-05-2003, 23:34 Subject: OBD2 Pinout: Connector and Wiring Explained |
At Audi, SEAT, Škoda, and Volkswagen:
Pin 1: Terminal 15a (ignition positive, fused).
Pin 2: J1850 Bus+
Pin 4: Ground.
Pin 5: Signal ground.
Pin 6: CAN-High (J-2284)
Pin 7: ISO 9141-2 K-line.
Pin 10: J1850 bus.
Pin 13: Terminal 30a (permanently energized, fused).
Pin 14: CAN-Low (J-2284)
Pin 15: L-line (or 2nd ISO 9141-2 K-line, depending on the vehicle).
Pin 16: Battery (+) voltage.
The main power cables are usually bundled together. Unfortunately, nobody bothers with separate power lines anymore.
CU Gremlin.
Translated on 24-08-2026, 7:01.
raddocki Blaumann
2011 Seat Alhambra Free account, no CAN development support
21-11-2015, 15:30 Subject: OBD2 Pinout: Connector and Wiring Explained |
Hello, has the occupancy rate at VW remained the same in 2012?
Translated on 24-08-2026, 7:03.
Profile PM Garage |
Joined: 04/12/2002 Posts: 18119 Karma: +801 / -0 Location: St.Gallen 2018 Volkswagen T6
09-10-2016, 10:52 Subject: OBD2 Pinout: Connector and Wiring Explained |
Profile PM WWW Garage |
