Quick Rest Current Measurement: Adjustment Guide
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
vag-driver
Post12-10-2016, 8:49    Subject: Quick Rest Current Measurement: Adjustment Guide Quote
The reasoning behind this is to preserve the battery. Does it make sense to enable QRS? Or am I potentially creating problems by doing so?
 File size:  39.46 KB
 Viewed:  2603 times
Andreas
Translated on 17-10-2026, 5:55.
Post12-10-2016, 11:04    Subject: Quick Rest Current Measurement: Adjustment Guide Quote
Hi Andreas,
Unfortunately, this will not extend the battery life. The reality is that after a trip, various control units remain active for a while before gradually "going to sleep."
If you're experiencing problems with excessive idle current and want to measure the cause, you can't wait for all the control units to "fall asleep" before each measurement. This can take several minutes.
To enable a direct measurement, there is the function you mentioned. However, this setting likely represents a one-time "sleep" function, as anything else would not make sense. There's a reason why various control units don't go to sleep simultaneously (e.g., engine cooling, "coming home" function, etc.).
Translated on 17-10-2026, 5:56.
vag-driver
Post12-10-2016, 11:12    Subject: Quick Rest Current Measurement: Adjustment Guide Quote
Hello Rainer,
Thank you for your explanation. The lifespan of the battery is significantly reduced depending on the care it receives, due to the high number of consumers and control units. Since I replaced the original battery after 5 1/2 years, this point became apparent to me in VCDS, and I was hoping to be able to reduce the battery load somewhat.
Andreas
Translated on 17-10-2026, 5:57.
No new posts VW Crafter, Year 2012/2013, High Standby Current Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document startup issues, adjusting initial quantity Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VAG-Com measurement, please provide expert advice On-Board Diagnostics (OBD)
No new posts Tuning Box: Does it Affect Fuel Consumption? Diesel Engine Technology
No new posts Assessing idle current Electrical Systems, Vehicle Electronics, Multimedia
No new posts Power Consumption: What is your idle current? Diesel Engine Technology
