Hi everyone,
I'm having a strange problem with my Lupo 3L.
1: It doesn't start in P (Park).
2: I need to put it in "N" (neutral), then turn on the ignition, and then wiggle the clutch slightly at the front, and only then will the clutch engage automatically?
2: Then start the engine, and then do the same thing again – messing around with the clutch, getting in, switching to driving mode, and then it drives "normally."
"If I then put it back in 'P' and turn it off, it doesn't start again, not even in 'N'. It only starts after the procedure of fiddling with the clutch cable."
What is this supposed to be?!
It would be great to get a few answers that could lead to the "perpetrator"
Thank you and best regards to you all.
Sepp.
