Grinding Noise When Starting? Get Help Now!
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
Arnie-75
Post27-11-2016, 1:43    Subject: Grinding Noise When Starting? Get Help Now! Quote
Sometimes, when I start my Seat Córdoba (TDI, 3-cylinder engine), I hear a scraping, grinding, 'singing' noise that seems to be coming from the direction of the engine compartment. Sometimes it sounds like the noise is more noticeable when I'm starting very gently, for example, when I'm only a few centimeters away from a wall. Because I don't always hear this noise, it hasn't bothered me much so far. Should I take it to a mechanic, or could it be normal?
Translated on 29-07-2026, 9:20.
Post27-11-2016, 11:25    Subject: Grinding Noise When Starting? Get Help Now! Quote
Yes.
Translated on 29-07-2026, 9:21.
Arnie-75
Post27-11-2016, 11:47    Subject: Grinding Noise When Starting? Get Help Now! Quote
Yes = Workshop, or Yes = Could this be normal?
Post27-11-2016, 14:46    Subject: Grinding Noise When Starting? Get Help Now! Quote
Well, that's an answer you can't make any sense of. Fitting for the question. Please read your question carefully again and consider what a meaningful answer might be.
As long as I'm saying "yes."
Translated on 29-07-2026, 9:22.
Arnie-75
Post27-11-2016, 15:02    Subject: Grinding Noise When Starting? Get Help Now! Quote
I was just trying to describe the situation as I see it, and unfortunately, I can't say much more about it.
No new posts A4 1,9 TDI Motor ruckelt beim Anfahren wie rupfende Kupplung Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts How to reset the service indicator on an Audi A3? Diesel Engine Technology
This topic is locked, you cannot edit or reply. OEL Dashboard Light: What Does It Mean? Diesel Engine Technology
No new posts Beim ZR - Wechsel die Muttern mit Loct** sichern? Diesel Engine Technology
No new posts Idle Speed Increases When Starting Engine Diesel Engine Technology
