Audi A3 8L AC Not Working - Repair Guide
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
Zylus
2001 Audi A3
Post29-12-2016, 13:06    Subject: Audi A3 8L AC Not Working - Repair Guide Quote
Hello.
I'm having a problem with my A3; the air conditioning isn't working.
The gas has been refilled, the compressor has been replaced, and the diagnostic device shows no errors.
The three fuses on the battery, leading from the control unit to the compressor, are only showing around 10 volts. I replaced the control unit, but the problem is still the same! When I supply the compressor directly with 12 volts, the clutch engages. I tested the wiring harness by piercing it after the connector to the control unit, and I'm still only getting 10 volts.
And the second fan is running constantly, even at the low temperatures. I think it should only turn on when the air conditioning is on.
Has anyone else experienced a similar issue, or can someone help me?
Sincerely,
Translated on 09-09-2026, 9:18.
Post29-12-2016, 13:16    Subject: Audi A3 8L AC Not Working - Repair Guide Quote
In this case, you really won't be able to make much progress without VCDS.
Translated on 09-09-2026, 9:20.
Karma: +646 / -0   Thank you, like it!
Post29-12-2016, 14:56    Subject: Audi A3 8L AC Not Working - Repair Guide Quote
Are you aware that the compressor doesn't start below +5°C?
Post29-12-2016, 19:16    Subject: Audi A3 8L AC Not Working - Repair Guide Quote
However, if the fan is running, the temperature must be above 5 degrees Celsius, or...or...or. VCDS would be helpful in this case.
Colorado
Post01-01-2017, 18:08    Subject: Audi A3 8L AC Not Working - Repair Guide Quote
So, if the fan for the air conditioning condenser is running constantly, to me that sounds very much like a kind of emergency mode from the air conditioning control unit.
What kind of "diagnostic tool" did you use?
But, as mentioned before, VCDS is the right tool to use to move forward with this.
I would suggest, in your place, simply checking the connections of all the sensors for the climate control system to see if the sensors, such as the refrigerant pressure sensor, are providing plausible values, etc.
Translated on 09-09-2026, 9:21.
No new posts Audi A3 TDI AC Fan - 1st Speed Problem Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A4 B6 Rear Door Won't Unlock Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Audi A4, Engine not starting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Climate Change: Urgent Action Needed! Diesel Engine Technology
This topic is locked, you cannot edit or reply. LMM Replacement at Audi: Not Possible? Diesel Engine Technology
No new posts Audi A8: Start-stop system doesn't always work Diesel Engine Technology
No new posts Audi A5: 7-Speed S-Tronic Basic Settings Not Working Transmission, Chassis, Body & Interior
