Good evening.
Today, I performed a minor service on the vehicle mentioned above, addressing the following issues:
The service indicator could not be reset as usual (using the button).
Can someone please tell me how to get the priming pump running?
(not possible with "initial fuel system filling" and under "fuel pump electrical system")
I then stopped and didn't complete the data filter (DF) replacement because I didn't want to introduce any air into the system.
Generally, I'm shocked (and I'm used to a lot of things with the V10 TDI) by how many parts (including 2 auxiliary water pumps, an exhaust flap, an intercooler, or whatever that thing is on the intake manifold, etc.) are installed in such a Euro 6 engine!
After 5 years and 150,000 km, you can just throw this car away because a repair to some small, inaccessible part will financially ruin you!
Thank you for your responses...
SG.
Alevuz.
Autoscan:
Tuesday, February 14, 2017, 11:40:57:53341
VCDS -- A VAG/VAS emulator based on Windows, running on Windows 10 x86.
VCDS Version: RKS 17.1.2.0
Data as of: 20170131 DS267.1
Vehicle Identification Number: WVWZZZAUZFP085531
License Plate: GOLF 7 - ROLAND
Mileage: 49229 km. Repair order: G7-Roland.
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BĂ€ume, und die BlĂ€tter rascheln leise. Es ist ein wunderschöner Tag, um drauĂen zu sein."
Vehicle type: AU (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 5F
Mileage: 49,229 km
01-Motor electronics -- Status: OK 0000
03-Brake electronics -- Status: Error 0010.
08-Climate Control/Heating Unit -- Status: Error 0010.
09-Central Electrical System -- Status: OK.
Parking Assist 10 -- Status: OK 0000
15-Airbag -- Status: OK 0000
16-Wheel Steering Electronics -- Status: OK 0000
17-Terminal block insert -- Status: OK 0000
19-Diagnosis interface -- Status: OK 0000.
42-Door Electric Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-door electric passenger side door - Status: OK 0000.
5F-Information Selection. I -- Status: Error 0010.
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BÀume, und die BlÀtter rascheln leise. Es ist ein wunderschöner Tag, um spazieren zu gehen oder ein Picknick im Park zu machen."
Address 01: Engine Control Module (2D2D2-CXXB)
Label file: DRV\04L-907-309-V1.clb
Part number SW: 04L 906 056, HW: 04L 907 445 B.
Component: R4 1.6L TDI, Part Number: H06 8983.
Revision: 22004001
Encoding: 01114032430401092000
Operating number: WSC 00028 028 00073
ASAM Dataset: EV_ECM16TDI03004L906056 002009
ROD: EV_ECM16TDI03004L906056_002_VW37.rod
VCID: 6ADE67C18DAFB4115D-803E
No error codes found.
Readiness: Not Available.
Address 03: Brake Electronics (J104)
Label file: 5Q0-907-379-IPB-V1.clb
Part number SW: 3Q0 907 379 Q, HW: 3Q0 907 379 F.
Component: ESC H42 0610
Revision: 00000000 Serial Number: 60495000002758
Encoding: 01FA62A124280971077C060341C42580462490E06082A4F30040F07AC002
Operating number: WSC 00028 028 00067
ASAM Dataset: EV_Brake1UDSContiMK100IPB 034036
ROD: EV_Brake1UDSContiMK100IPB_034_VW37.rod
VCID: 489AFD49F363A6016B-801C
"One error found:"
16401 - Tire pressure warning.
C102D 00 [008] - -
Sporadically - confirmed - checked since last deletion.
Environmental conditions:
Error status: 00000001
Error priority: 2
Error frequency: 1
Lost Count: 76
Mileage: 39,454 km
Date: 2016.10.23
Time: 12:14:37
Address 08: Climate Control/Heating (J255)
Label file: 5G0-907-044.clb
Part number SW: 5G0 907 044 BD
Hardware number: 5G0 907 044 BD
Component: Climatronic
Part number: H03 1001
Revision: 00001K08
Encoding: 00020104202100011005000000101000
ASAM Dataset: EV_ACClimaBHBVW37X 003018
ROD: EV_ACClimaBHBVW37X_003_VW37.rod
Control unit for the fresh air blower (front).
Refrigerant pressure and refrigerant temperature sensors:
Air quality sensor:
"One error found:"
1048835 - Function limitation due to engine control unit.
P1719 00 [008] - -
Error priority: 6
Error frequency: 1
Lost Count: 169
Mileage: 49,171 km
Date: 2017.02.14
Time: 08:07:04
Voltage at terminal 30: 13.5 V.
Auxiliary heating: multi-stage activation for heating operation: activation at level 3.
Auxiliary heating: stepped, setpoint value: 3.
Auxiliary heating: stepped setpoint: 3.
Auxiliary heating: Control system setpoint, stepped: 3.
Address 09: Central Electronics (J519)
Label file: 5Q0-937-08X-HV1.clb
Part number SW: 5Q0 937 084 AJ HW: 5Q0 937 084 AJ
Component: BCM MQBAB H H18 0137
Serial number: 01011504302968
Encoding: 00000846C24102FB4BE44000001C07081000000000000000000000000000
ASAM Dataset: EV_BCMCONTI 013000
ROD: EV_BCMBOSCH_013.rod
VCID: 000A25699BD35E41E3-8054
Control unit for wiper motor:
Subsystem 1 - Part number SW: 5G1 955 119 A, HW: 5G1 955 119 A, Label file: DRV\5QX-955-119-V1.CLB.
Component: WWS 150206 043 0551
Serial number: 150211075636
Encoding: 0E4DDD
Rain and light sensor:
Subsystem 2 - Part number SW: 5Q0 955 547 A, HW: 5Q0 955 547 A, Label file: DRV\5Q0-955-547.CLB.
Part number: RLHS 037 0059.
Serial number: S4Y15M02D20H11M40S45
Encoding: 00A8DD
Address 10: Parking Assist 2 (J791)
Label file: 5Q0-919-298.clb
Part number SW: 5Q0 919 298 F, HW: 5Q0 919 298 F.
Part: PARKING ASSIST PLA H12 0047
Revision: -------- Serial Number: 39431503803451
Encoding: 0031061041
ASAM Dataset: EV_EPHVA2CAU3700000 003019
ROD: EV_EPHVA2CAU3700000_003_VW37.rod
VCID: 428EEF61D55F8C51B5-8016
Address 15: Airbag (J234)
Label file: DRV\5Q0-959-655.clb
Part number SW: 5Q0 959 655 D, HW: 5Q0 959 655 D.
Component: Airbag VW20 014 0385.
Serial number: 003F6R0G8W2N
Encoding: 98CCC000000000005C0000CF004800000065
Operating number: WSC 00028 028 00061
ASAM Dataset: EV_AirbaVW20SMEVW37X 002130
ROD: EV_AirbaVW20SMEVW37X_VW37.rod
VCID: 418CE06DD0599749AC-8014
Crash sensor for driver-side side airbag:
Subsystem 1 - Part number: SW: ----------- HW: 480 001 202 15
Component: SideSensor_Df 001 0887
Serial number: 35767000000C0539231K
Encoding: 2D2D2D
Crash sensor for side airbag, passenger side.
Subsystem 2 - Part number: SW: ----------- HW: 480 001 202 15
Component: SideSensor_Pf 001 0887
Serial number: 35867000000DBAF82316
Encoding: 2D2D2D
Crash sensor for rear side airbag, driver's side.
Subsystem 3 - Part number: SW: ----------- HW: 480 401 202 15
Component: SideSensor_Dr 001 6149
Serial number: 3516502C7198E154F16J
Encoding: 2D2D2D
Crash sensor for rear side airbag, passenger side.
Subsystem 4 - Part number: SW: ----------- HW: 480 401 202 15
Component: SideSensor_Pr 001 6149
Serial number: 3526502C7198E1553226.
Encoding: 2D2D2D
Crash sensor for front airbag, driver's side:
Subsystem 5 - Part number: SW: ----------- HW: 480 400 502 15
Component: FrontSensor_D 001 6149
Serial number: 3556502AB196FF5290D.
Encoding: 2D2D2D
Address 16: Steering wheel electronics (J527)
Label file: DRV\5Q0-953-549.clb
Part number SW: 5Q0 953 507 AB, HW: 5Q0 953 549.
Bauteil: Lenks. Module 007 0070.
Revision: -------- Serial Number: 18021504400166
Encoding: 0600
ASAM Dataset: EV_SMLSKLOMQB 009001
ROD: EV_SMLSKLOMQB_VW37.rod
VCID: 76E643B1C91760F1C9-8022
Address 17: Control panel module (J285)
Label file: DRV\5G0-920-XXX-17.clb
Part number SW: 5G1 920 751 Hardware number: 5G1 920 751
Part: COMBINATION INSTRUMENT 304 4270
Encoding: 07A41A002390000800086A001400000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009037
ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
VCID: 65C414FD64B19B6970-8030
Address 19: Diagnostic Interface (J533)
Label file: DRV\5Q0-907-530-V1.clb
Part number SW: 5Q0 907 530 AA, HW: 5Q0 907 530 K.
Component: GW MQB Low, Part Number: 210 2203.
Revision: -------- Serial Number: 21121410801107
Encoding: 030000040F087300EF000248080F000100010500000000000000000000000
ASAM Dataset: EV_GatewConti 011020
ROD: EV_GatewConti_011.rod
VCID: 70EA75A9AB734EC113-8024
Generator:
Battery monitoring control unit:
Subsystem 2 - Part number SW: 5Q0 915 181 G, HW: 5Q0 915 181 G.
Part: J367-BDM, Hella, H04 8050.
Serial number: 3430525603
Address 42: Door Electric Driver (J386)
Label file: 5QX-959-X93-42.clb
Part number SW: 5Q4 959 593 C, HW: 5Q4 959 593 B.
Component: TSG FS 009 0015
Serial number: 0000137155667
Encoding: 00310320D000020000001000
ASAM Dataset: EV_DCUDriveSideEWMAXCONT 006001
ROD: EV_DCUDriveSideEWMAXCONT.rod
VCID: 4584F47DC471BB6990-8010
Rear door control module, driver's side.
Subsystem 1 - Part number SW: 5Q4 959 811 A, HW: 5Q4 959 811 A.
Component: Rear panel FHSG DRV 007 0002.
Serial number: 00000000000007936075
Encoding: 010000
Address 44: Steering Assist (J500)
Label file: DRV\5Q0-909-144.clb
Part number SW: 5Q0 909 144 R
Part number HW: 5Q0 909 144 R
Part: EPS_MQB_ZFLS 126 1061
Encoding: 0302
ASAM Dataset: EV_SteerAssisMQB 012140
ROD: EV_SteerAssisMQB_VW31.rod
VCID: 4380EA65CA458559BE-8016
Address 52: Power door lock, front passenger side (J387)
Label file: 5QX-959-X92-52.clb
Part number SW: 5Q4 959 592 C, HW: 5Q4 959 592 B.
Component: TSG BFS 009 0015
Serial number: 0000136877917
Encoding: 00310120DE00020000801000
ASAM Dataset: EV_DCUPasseSideEWMAXCONT 006001
ROD: EV_DCUPasseSideEWMAXCONT.rod
VCID: 4482E979CF4B826187-8010
Door control module, rear passenger side:
Subsystem 1 - Part number SW: 5Q4 959 812 A, HW: 5Q4 959 812 A.
Component: Rear panel FHSG PSG 007 0002.
Serial number: 00000000000008008755
Encoding: 090000
Address 5F: Information selection. I (J794)
Label file: 5G0-035-MIB-STD1.clb
Part number SW: 5G0 035 846 A, HW: 5G0 035 846 A.
Component: MU-S-N-ER 041 0430
Serial number: V1F01602152788
Encoding: 02730001FF00000011110001000800031F0100840100010045
ASAM Dataset: EV_MUStd4CPASE 002039
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 27585EF55E3D497982-8072
Display and control unit 1 for information electronics:
Subsystem 1 - Part number SW: 5G0 919 605 D, HW: 5G0 919 605 D.
Component: ABT_Std_Nav H60 0030
Serial number: VWZ8Z9RS406QW1
Storage media:
Subsystem 2 - Part number SW: 5G0 919 866 Q HW: -----------
Component: ECE 2015 --- 0045
Serial number: --------------------
"One error found:"
6145 - Display and control unit 1 for information electronics.
B129E 07 [009] - Mechanical fault.
Error priority: 6
Error frequency: 1
Lost Count: 181
Mileage: 43,432 km
Date: 2016.12.13
Time: 07:09:43
Voltage at terminal 30: 14.1 V.
End----------------------------(Duration: 03:44)-----------------------------
