Wanninger
15-04-2017, 17:07 Subject: 12V Socket: Constant Power for Cigarette Lighters |
Hello everyone,
Is there a way to use VCDS to access and modify the settings for the cigarette lighter and/or other functions in an Audi A6 4G C7?
Programming 12-volt on-board sockets to be powered by the permanent power supply?
Thank you and best regards.
-Wanninger
Translated on 22-10-2026, 6:27.
17-04-2017, 16:14 Subject: 12V Socket: Constant Power for Cigarette Lighters |
To be honest, I have no idea. If it's possible, it should be programmable in control unit address 09 (body control module).
However, I'm surprised that the outlets don't have continuous power by default, as they do in the 4F model.
Translated on 22-10-2026, 6:28.
Profile PM WWW Garage |
matthiasTDI96 Profi-Schrauber
17-04-2017, 17:41 Subject: 12V Socket: Constant Power for Cigarette Lighters |
Okay, I'm completely unsure about how Audi handles this. With some VW models, it's possible to flip the fuse in the fuse box so that it's connected to permanent power. I'd be very surprised if that's something that can be programmed.
Turbinchen Profi-Schrauber
Joined: 04/10/2008 Posts: 199 Karma: +74 / -0 Location: 95615 Marktredwitz 2014 Audi A4 Avant Support
dieselschrauber and DieselBär30x likes this. |
18-04-2017, 16:22 Subject: 12V Socket: Constant Power for Cigarette Lighters |
My Mercedes has a jumper connector in the fuse box for that purpose.
For 4G functionality, the relay J807 needs to be removed and replaced with a jumper consisting of two 4.8mm flat connectors. However, this will bypass the power management system.
Edit: I forgot to mention that the relay is located in the rear right side panel, inside a relay holder.
Translated on 22-10-2026, 6:29.
Profile PM Garage |
Wanninger
19-04-2017, 22:19 Subject: 12V Socket: Constant Power for Cigarette Lighters |
...thank you all!
I will then do that with the relay.
-Wanninger
Translated on 22-10-2026, 6:30.
haithamina Schrauber
Joined: 05/15/2006 Posts: 666 Karma: +27 / -3 Location: 69221 Dossenheim
20-04-2017, 10:06 Subject: 12V Socket: Constant Power for Cigarette Lighters |
"I also did it by simply changing the fuse on my Passat B8. In theory, I could now drain the entire battery capacity. In practice, everything works fine, mainly because of the large battery (I have a built-in auxiliary heater) and the low power consumption (charging my phone/PC) when the engine is not running."
haithamina 3G5, 110 kW, DFGA, TGV, Variant HL 2018-
klahaui Profi-Schrauber
Joined: 08/13/2009 Posts: 1102 Karma: +125 / -0 Location: Vogtland, Land der Berge 2019 Volkswagen Golf Premium Support
20-04-2017, 19:36 Subject: 12V Socket: Constant Power for Cigarette Lighters |
The battery management system should eventually turn off the igniter, right? Kaum macht man es richtig, funktioniert es!
Translated on 22-10-2026, 6:31.
Profile PM Garage |
guste100 Profi-Schrauber
Joined: 07/27/2004 Posts: 2405 Karma: +441 / -0 Location: Mitte Schleswig Holsteins 2007 Volkswagen Passat Premium Support
21-04-2017, 13:27 Subject: 12V Socket: Constant Power for Cigarette Lighters |
klahaui wrote: | | Shouldn't the battery management system eventually turn off the igniter? |
Sure, in the original configuration: Immediately.
If you bypass the relay, as suggested by Turbinchen, then the BMS (Battery Management System) will no longer be able to shut it off, even if the battery is completely discharged.
Greetings.
Sure, here's the translation:
"Guste" is a German word that means "gust" or "gust of wind." It can also be used to describe a sudden burst of something, such as laughter or anger.
Translated on 22-10-2026, 6:32.
Profile PM Garage |
