1.6 TDI Injector Base Adjustment Small Quantity Deviation
Willi1605
Post06-05-2017, 11:00    Subject: 1.6 TDI Injector Base Adjustment Small Quantity Deviation Quote
I have a VW Polo 1.6 TDI 77kW CAYC. It received the "Pfusch" update 9978 in February. Now, 2 months later, there's a period of inactivity with irregular idling. The VW workshop has replaced the 2-cylinder injector.
Now, I wanted to perform a "small deviation" in the "basic settings" using VCDS.
"Brake pedal must be depressed and accelerator pedal must be depressed." That's exactly how I did it too.
Then the engine speed increased to approximately 2000 rpm, and the message "Keep brake and accelerator pedal pressed" appeared. After about 30 seconds, the engine entered a "sawing mode". The engine speed fluctuated from 1000 to 3200 rpm. The message "Keep brake and accelerator pedal pressed" remained. "That's how I did it too, with the hope that a notification would appear, such as "Match OK" or something similar."
But no, the "Keep Brake and Gas Pedal Pressed" warning light was still on. After 20 minutes, I gave up and pressed the "Stop" button.
My question is, when or after what time is the reconciliation completed?
I hope you can also help me further.
Willi1605
No new posts Injector calibration with VCDS Troubleshooting & Guides
No new posts VCDS: Resetting DSG Transmission Settings Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 1.4 TSI CTHA basic settings not available in the engine c... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Parameter Injector PDE On-Board Diagnostics (OBD)
No new posts Engine Oil on Injector Housing Diesel Engine Technology
No new posts Golf IV, 1J, Injector, Combustion Failure On-Board Diagnostics (OBD)
No new posts CR Injector Failure: Common Causes & Solutions Diesel Engine Technology
