Drucksensor 1 für Abgas (G450): Kurzschluss nach Plus | Posts 16+
Go to page: Previous  1, 2
Post28-05-2017, 11:24    Subject: Quote
Could the problem actually be due to the excessively high ash content?
In theory, it is conceivable that the new differential pressure sensor could fail due to excessive pressure, but I have not personally experienced this yet.
It would be pure speculation.
Therefore, I would invest in a new differential pressure sensor and carefully begin with a test run, observing the differential pressure.
See also the topic regarding normal values for differential pressure.
Translated on 22-07-2026, 8:16.
William
Post28-05-2017, 19:28    Subject: Quote
Okay, it looks like we're probably going to have to go with a new pressure sensor next.
On eBay, you can find pressure sensors that are compatible with my car for between €20 and €60.
Is there anything I should pay attention to when making a purchase? Should I focus on better quality or a specific manufacturer?
Thank you very much, Rainer, for the tips.
I will provide further information about how this "birth" will proceed.
Willi.
Translated on 22-07-2026, 8:17.
Mpire
Avatar-Mpire
2019 Skoda Octavia
dieselschrauber likes this.
Post28-05-2017, 20:09    Subject: Quote
William wrote:
Okay, it seems like we're going to have to go with a new pressure sensor next.
There are pressure sensors available for my car in the price range of €20-€60 at [Company Name/Location].
Yes, there is icon_biggrin.gif.
...choose an original sensor, because the experiences with durability and the reliability of the values from aftermarket products are often mixed.
The trouble just keeps coming, and it still costs money despite that icon_wink.gif.
Mpire
Translated on 22-07-2026, 8:19.
William
dieselschrauber and Mpire likes this.
Post31-05-2017, 16:03    Subject: Quote
Thanks, Empire! I ordered an original pressure differential sensor.
Installed today, errors fixed. Then calibrated the pressure sensor.
After the initial calibration, the pressure difference was 5 mbar. I then performed a logging sequence, and after approximately the third sensor calibration, the pressure difference was 0 mbar.
I now hope that the sensor doesn't break down again. The previous one only lasted for about 10 days. icon_sad.gif
When the DPF is being regenerated (while idling), the pressure difference should be between 3 and 7 millibars.
The differential pressure in my system is approximately 15 millibars.
However, this was with a loading coefficient of approximately 20%. I suspect that it is related to this.
LOG-01-067-002-xxx.CSV
 Log-Fahrt Differenzdrucksensor (G450)
 File name:  LOG-01-067-002-xxx.CSV
 File size:  27.33 KB
 Downloaded:  415 times
Translated on 22-07-2026, 8:22.
No new posts Error code 005399 / P1517 - Short circuit to ground Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Differential pressure sensor G450 to be calibrated/adjust... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P2453 - Diesel Particulate Filter Pressure Sensor 'A' Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P0471 Exhaust Pressure Sensor 1 (G450) On-Board Diagnostics (OBD)
No new posts Exhaust fumes occasionally smell like water Diesel Engine Technology
No new posts Terminal 58d - Short circuit to ground Electrical Systems, Vehicle Electronics, Multimedia
No new posts Intake air temperature sensor (G72) - Short circuit to gr... On-Board Diagnostics (OBD)
