dokky Blaumann
Joined: 11/14/2003 Posts: 67 Karma: +7 / -0 Location: im Grünen 2013 Volkswagen Golf Free account, no CAN development support
19-06-2017, 7:29 Subject: Polo 9N 1.4 TDI - Radiator Fan |
"On our Polo, the radiator fan doesn't switch to level 1 when the air conditioning is turned on; instead, it cycles between level 2. Is it possible to manually activate it to test it? Does it have a resistor connected?" I couldn't find anything, and I don't want to pay a lot to have a new fan installed.
Can the fan be controlled using VCDS? Could I borrow a copy?
Profile PM Garage |
Joined: 04/12/2002 Posts: 18118 Karma: +801 / -0 Location: St.Gallen 2018 Volkswagen T6
19-06-2017, 11:36 Subject: Polo 9N 1.4 TDI - Radiator Fan |
It should be possible to access it using VCDS, but I'm not sure if that works with the Polo 9N.
Level 1 usually runs continuously with the climate control system.
Profile PM WWW Garage |
dokky Blaumann
22-06-2017, 14:15 Subject: Polo 9N 1.4 TDI - Radiator Fan |
Hi Rainer,
I couldn't find any information about "auslesen" or "testen." I'll take a look at the car in the next few days and measure the connections of the fan. It's either the fan itself or the control unit. It's still quite simple technology.
Profile PM Garage |
