Coolant fan for Seat Leon 1M (ARL engine) with air conditioning
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
599dxx
Post23-06-2017, 14:22    Subject: Coolant fan for Seat Leon 1M (ARL engine) with air conditioning Quote
The larger of the two coolant fans is definitely broken. The fuses are okay, and the ground connection is fine. The smaller fan (connected in parallel) is working on both speeds.
"Question: How do I replace the fans? Is there anything specific to be aware of with the ARL (large intercooler in front of the coolant radiator), or is it as straightforward as with other TDI models?"
Thank you very much!
Translated on 11-07-2026, 13:13.
dieselschrauber likes this.
Post23-06-2017, 18:34    Subject: Subject: Coolant fan for Seat Leon 1M (ARL engine) with air conditioning Quote
599dxx wrote:
...or is it as simple as with the other TDIs?
In principle, there's no other way; the ARL has less space due to the FMIC and the large charge air pipe. It's best to remove that pipe altogether. icon_wink.gif
Translated on 11-07-2026, 13:14.
599dxx
Post23-06-2017, 22:19    Subject: Coolant fan for Seat Leon 1M (ARL engine) with air conditioning Quote
Okay, thank you! I was already afraid that half of the front of the car would have to be taken apart again (like it recently had to be when the air conditioning condenser was replaced).
"Working on the ARL is a lot of fun... unfortunately, it's quite cramped in the engine bay."
Best regards from the Westerwald region...
Translated on 11-07-2026, 13:15.
No new posts Seat Leon, 2012 model, LED brake light flickering Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 TDI AC Fan - 1st Speed Problem Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Broken sun visor clip for Audi, Seat, Skoda, VW Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing Belt Replacement BLS Engine - Seat Leon Diesel Engine Technology
No new posts Vag-Com Codes für Seat Leon Diesel Engine Technology
No new posts Seat Leon 1P: Ansteuerzeit Scheinwerferreinigung On-Board Diagnostics (OBD)
No new posts Verbrauchsanzeige anpassen Seat Leon Diesel Engine Technology
