ATJ Cylinder Head Washout: Causes & Repair
Matzepatze
Post23-06-2017, 21:52    Subject: ATJ Cylinder Head Washout: Causes & Repair Quote
Hello!
Today, I had to remove the cylinder head (a common issue with AJM/ATJ engines, causing coolant to leak).
On the 2nd pot, it was clearly visible where there was a leak. After cleaning the cylinder head, I'm now wondering whether I should have it re-planed or not. It has slight corrosion, which can be felt with the fingernail, but it also already has a 3mm gasket. How should the corrosion be assessed?
Matzepatze.
3B 4motion ATJ
Translated on 05-10-2026, 23:00.
dieselschrauber likes this.
Post24-06-2017, 11:23    Subject: ATJ Cylinder Head Washout: Causes & Repair Quote
Planning is actually not allowed, but in my experience, it's not critical up to 1/10mm. However, a thicker gasket is not used for this reason!
Translated on 05-10-2026, 23:01.
No new posts Document A6 4B, Fuel Leak at Cylinder Head Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Severe oil leak at the cylinder head, AJM engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AAZ Cylinder Head - Replacement & Repair Diesel Engine Technology
No new posts Bohrungen im Zylinderkopf Diesel Engine Technology
No new posts Head Bolt Torque Specs AWX Engine Diesel Engine Technology
No new posts Cylinder Head Differences: A Comparison Guide Diesel Engine Technology
