Georg_G Profi-Schrauber
Joined: 04/12/2002 Posts: 332 Karma: +6 / -0 Location: Freiburg im Breisgau 2012 Volkswagen Golf Support
23-06-2017, 17:22 Subject: Euro 5 Diesel: MSG Update reveals cheating? |
Hello everyone,
I bought a used 2.0 TDI CFHC model year 2012.
Can I use VCDS to check if the software update for reduced NOx emissions has already been installed?
Here is the excerpt from the Autoscan:
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die Bäume, und die Blätter rascheln leise. Es ist ein wunderschöner Tag, um draußen zu sein."
Address 01: Engine Control Module (J623-CFHC)
Label file: DRV\03L-906-018-CFF.clb
Part number SW: 03L 906 018 AN, Part number HW: 03L 907 309 R.
Part: R4 2.0l TDI H25 9979
Revision: 42H25--- Serial number: 00000000000000
Encoding: 00190012042400080000
Operating number: WSC 51781 186 12345
ASAM Dataset: EV_ECM20TDI01103L906018AN 003012
ROD: EV_ECM20TDI03L906018AM.rod
VCID: 76CCBF79C9A97BF1C3-8022
No error codes found.
Readiness: 0 0 0 0 0
Best regards, Georg. Golf VI Variant (2012) 140 tkm, CFHC Schummeldiesel
Translated on 18-09-2026, 17:14.
Profile PM Garage |
chli1976 Profi-Schrauber
dieselschrauber likes this. |
23-06-2017, 19:53 Subject: Euro 5 Diesel: MSG Update reveals cheating? |
9979 should be the NOx software. VCDS
Translated on 18-09-2026, 17:16.
Wirus
Joined: 07/11/2016 Posts: 9 Karma: +4 / -0 Location: Aschaffenburg
23-06-2017, 22:10 Subject: Euro 5 Diesel: MSG Update reveals cheating? |
You could also simply check the FIN (Financial Identification Number) to see if the update has been applied or not.
http://info.volkswagen.de/de/de/home.html
Steffen G Profi-Schrauber
Joined: 10/26/2006 Posts: 2557 Karma: +591 / -0 Location: bei Zwickau
23-06-2017, 22:17 Subject: Euro 5 Diesel: MSG Update reveals cheating? |
Hello!
I haven't seen it myself yet.
However, in the media, it was reported that a sticker would be attached to the trunk floor with the update. Grüße, Steffen!
Translated on 18-09-2026, 17:17.
matthiasTDI96 Profi-Schrauber
24-06-2017, 6:59 Subject: Euro 5 Diesel: MSG Update reveals cheating? |
Where do you buy your cars? Is there no documentation or service booklet available? That would certainly make me suspicious.
If there's no information available, I would suggest contacting VW to inquire about the vehicle's history, if any records exist.
klahaui Profi-Schrauber
Joined: 08/13/2009 Posts: 1102 Karma: +125 / -0 Location: Vogtland, Land der Berge 2019 Volkswagen Golf Premium Support
24-06-2017, 8:39 Subject: Euro 5 Diesel: MSG Update reveals cheating? |
The stickers for the spare tire compartment are only available from Skoda; VW and Audi no longer supply them.
Normally, a note should be made on the last pages of the service booklet, but unfortunately, this is often forgotten.
As mentioned before, simply drive to the next car dealership with the VIN and they can identify it within seconds. Kaum macht man es richtig, funktioniert es!
Translated on 18-09-2026, 17:18.
Profile PM Garage |
Joined: 04/12/2002 Posts: 18128 Karma: +803 / -0 Location: St.Gallen 2018 Volkswagen T6
25-06-2017, 16:05 Subject: Euro 5 Diesel: MSG Update reveals cheating? |
Quote: | | As a general rule, a note should be made on the last pages of the service booklet, but unfortunately, this is often forgotten. |
This was noted in the service booklet by AMAG (Audi Importer Switzerland).
Translated on 18-09-2026, 17:19.
Profile PM WWW Garage |
25-06-2017, 20:37 Subject: Euro 5 Diesel: MSG Update reveals cheating? |
Thank you all for the many answers.
The link from Wirus.
It provided clarification. My car is registered there with an exhaust treatment measure, which probably refers to the update.
There's no sticker in the trunk in my car.
The service booklet is also blank. The last service was in the summer of 2016 at 120,000 km and was normally stamped.
Here's a summary for the CFHC:
Component: R4 2.0l TDI H25 9979 indicates an NOx update.
The car regenerates energy every 200 km with a 50%/50% mix of rural and city driving, and it can sometimes go up to 400 km on longer highway trips. I found these intervals to be a bit short, so I inquired about them. Based on everything I could find (or not find) on the internet, this seems to be consistent with the new software version.
Translated on 18-09-2026, 17:20.
Profile PM Garage |
haithamina Schrauber
Joined: 05/15/2006 Posts: 666 Karma: +27 / -3 Location: 69221 Dossenheim
26-06-2017, 10:37 Subject: Euro 5 Diesel: MSG Update reveals cheating? |
klahaui wrote: | Hi,
In my B8, all service measures were documented both in the service booklet and with stickers inside the spare tire compartment.
haithamina 3G5, 110 kW, DFGA, TGV, Variant HL 2018-
Translated on 18-09-2026, 17:22.
26-06-2017, 12:37 Subject: Euro 5 Diesel: MSG Update reveals cheating? |
That's surprising, I used to work as a service advisor at Audi until recently. We never received any stickers, and I sometimes forgot to make certain entries. Kaum macht man es richtig, funktioniert es!
Translated on 18-09-2026, 17:23.
Profile PM Garage |
