Brake Light Switch & Trunk Release - DIY Repair
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
haithamina
Post14-05-2014, 18:16    Subject: Brake Light Switch & Trunk Release - DIY Repair Quote
Hello everyone!
Yesterday, I saw "mouse movie," ABS warning, a glowing coil, a triangle with an exclamation mark, and an error message indicating an engine malfunction. However, all these warnings disappeared after several trips, and there were no further unusual occurrences.
After the initial scan, I selected the "delete" option and hope that I have cleared the error codes from the memory. The error code related to the brakes was definitely deleted.
Tuesday, May 13, 2014, 18:51:29:26054
VCDS -- A Windows-based VAG/VAS emulator.
VCDS Version: 12.12.0.0
Data as of: 20131116.
Vehicle Identification Number: WVWZZZ3BZ3E410146 License Plate:
Mileage: 238,080 km. Repair order:
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BĂ€ume, und die BlĂ€tter rascheln leise. Es ist ein wunderschöner Tag, um draußen zu sein."
Vehicle type: 3B (3B - VW Passat B5 (1997 > 2005))
Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
Mileage: 238,080 km
Address 01: Engine Control Module
Label file: RKS\038-906-019-AVB.lbl
Part number: 038 906 019 GL
Component: 1.9L R4 EDC G000SG 1495
Encoding: 00002
Operating number: WSC 05314
VCID: 67C374AD05081226359-4B64
WVWZZZ3BZ3E410146 VWZ7Z0C7074532
"One error found:"
16955 - Brake light switch (for models with rear-mounted engine)
P0571 - 35-00 - Implausible signal.
Readiness: 0 0 X X X
Address 03: Brake Electronics Label file: RKS\4B0-614-517.lbl
Part number: 4B0 614 517 G
Component: ABS/ESP front - 3428.
Coding: 04255
Operating number: WSC 05311
VCID: 255F3EA5BF84C036C75-50E6
"One error found:"
00526 - Brake light switch (F)
27-10 - implausible signal - sporadic.
Address 08: Climate Control/Heating. Label file: RKS\3Bx-907-044.lbl.
Part number: 3B1 907 044 H
Component: CLIMATRONIC B5GP 0009
Encoding: 17000
VCID: 265D39A9C282CB2ECEF-515A
No error codes found.
Address 15: Airbag
Label file: RKS\6Q0-909-605-VW5.lbl
Part number: 1C0 909 605 C
Part number: 08 AIRBAG VW61 04 0003.
Encoding: 12344
VCID: 245923A1B4BE393ED0B-515A
"One error found:"
00532 - Power supply voltage.
07-10 - Signal too weak - Sporadic.
Address 16: Steering wheel electronics
Label file: RKS\1J0-907-487-A.lbl
Part number: 1J0 907 487 B
Component: Steering wheel electronics 0002.
Coding: 00008
VCID: 3071DFF1F046959E243-515A
Address 17: Control panel module
Label file: RKS\3B0-920-xx5-17.lbl
Part number: 3B0 920 827 A
Component: COMBINATION INSTRUMENT + SPEEDOMETER VDO V08
Encoding: 05115
Operating number: WSC 00000
VCID: 225525B9AEAA370EA27-515A
Address 19: Diagnostic interface
Label file: RKS\6N0-909-901-19.lbl
Part number: 6N0 909 901.
Component: Gateway K<CAN> 2005
Mileage: 238,190 km
Encoding: 00002
"One error found:"
P0571 - 35-10 - Implausible signal - Intermittent.
Coding: 04255
VCID: 255F3EA5BF84C036C75-515A
"One error found:"
Encoding: 17000
Address 15: Airbag
Encoding: 12344
"One error found:"
Coding: 00008
Encoding: 05115
Component: Gateway K<->CAN 0001
Encoding: 00006
VCID: F0F19FF1B0C6559EE43-515A
Address 46: Comfort System
Label file: RKS\1C0-959-799.lbl
Part number: 1C0 959 799 B.
Component: 7X Comfort Device HLO 0003
Encoding: 00259
VCID: 367DE9E91222BBAE7EF-4B00
Subsystem 1 - Part number: 1C1959801.
Component: 7X TÔrsteuer.FS KLO 0009
Subsystem 2 - Part number: 1C1959802.
Component: 7X TÔrsteuer.BF KLO 0009
Subsystem 3 - Part number: 1C0959811.
Component: 7X TÔrsteuer.HL KLO 0009
Subsystem 4 - Part number: 1C0959812
Component: 7X TÔrsteuer.HR KLO 0009
"One error found:"
01141 - Release switch for tailgate lock (E165)
Address 76: Parking Assist
Label file: RKS\3B0-919-283.lbl
Part number: 3B0 919 283.
Bauteil: Parkingsyst. PA RDW D01
Encoding: 00114
VCID: E5DFFEA57F048036875-515A
Ende.
I assume the brake light switch is probably broken.
Is there a logical connection to the topic of the tailgate release? Is it also likely to be a faulty component or a cable? Or will this error message likely disappear after replacing the brake light switch?
Thank you in advance, haithamina.
Translated on 27-08-2026, 21:30.
Post14-05-2014, 18:29    Subject: Brake Light Switch & Trunk Release - DIY Repair Quote
00532 - Supply voltage.
...All the messages disappeared over the course of several trips...
Is the onboard voltage/battery okay?
Translated on 27-08-2026, 21:49.
Karma: +591 / -0   Thank you, like it!
Post14-05-2014, 18:48    Subject: Brake Light Switch & Trunk Release - DIY Repair Quote
Hi!
Sometimes there are problems with the brake light switches.
Sometimes, the contacts can easily get damaged inside.
You can replace the BLS battery; it doesn't cost much.
and it has also been replaced.
But be careful, they have a self-adjusting mechanism with a locking feature.
You only have one attempt.
And pull the brake pedal all the way down.
GrĂŒĂŸe, Steffen!
Translated on 27-08-2026, 21:50.
haithamina
Post14-05-2014, 21:14    Subject: Brake Light Switch & Trunk Release - DIY Repair Quote
On-board voltage / battery OK?
Good point!
"Some time ago, I suspected that the alternator might be failing, as there were error messages related to it, and the voltage often hovered just below 14V (13.6-13.8V) during driving. However, after a period of what seemed like spontaneous recovery, the display has been showing nice voltage readings of around 14.2V for months. I have never observed or noticed any significant drops in voltage. The battery was replaced for the first time about a year ago."
haithamina
Translated on 27-08-2026, 21:51.
felix
Avatar-felix
Post05-07-2017, 10:22    Subject: Brake Light Switch & Trunk Release - DIY Repair Quote
It's been a while icon_wink.gif, but I'm making almost exactly the same mistakes.
Was it the on-board voltage?
Felix.
Wednesday, July 5, 2017, 11:18:37:18980
VCDS -- A VAG/VAS emulator based on Windows, running on Windows XP x86 (using Parallels).
VCDS Version RKS 17.1.3.0
Data as of: 20170505 DS267.9
Vehicle Identification Number: WVWZZZ1JZ3W576816 License Plate:
Vehicle type: 1J (1J - VW Golf/Bora IV (1998 > 2006))
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
76
Mileage: 233,440 km
Label file: DRV\038-906-019-AXR.lbl
Part number: 038 906 019 AT
Part: 1.9L R4 EDC G000SG 1575
Encoding: 00002
Operating number: WSC 01266
VCID: 69DE3EAF1333C6095E-4B33
WVWZZZ1JZ3W576816 VWZ6Z0C0022667
"One error found:"
Label file: DRV\1C0-907-37x-ESP-F.lbl
Part number: 1C0 907 379 M
Component: ESP FRONT MK60 0102
Coding: 0019458
Operating number: WSC 01266 785 00200
VCID: 34609FDB54714BE13D-5179
"One error found:"
01435 - Sensor 1 for brake pressure (G201)
008 - implausible signal - sporadic.
Address 15: Airbag
Label file: DRV\6Q0-909-605-VW5.lbl
Part number: 1C0 909 605 F
Part number: 02 AIRBAG VW61 0101 0003
Encoding: 12338
VCID: 275A7897C5A7307988-5179
"One error found:"
Label file: DRV\1J0-920-xx5-17.lbl
Part number: 1J0 920 806 G
Part: COMBINATION INSTRUMENT + SPEEDOMETER. RB8 V24.
Encoding: 01112
Operating number: WSC 43966
VCID: 2B5284A7D94F14196C-5179
Label file: DRV\6N0-909-901-19.lbl
Encoding: 00006
VCID: 70E853CB30E937C119-5179
Label file: DRV\1C0-959-799.lbl
Part number: 1C0 959 799.
Component: 1F Comfort Device HLO 0002
Encoding: 00259
VCID: 74E05FDB44F10BE1FD-4B19
Subsystem 1 - Part number: 1C1959801A
Component: 1F Throttle Control.FS KLO 0009
Subsystem 2 - Part number: 1C1959802A
Component: 1F Throttle Control.BF KLO 0009
Subsystem 3 - Part number: 1C0959811A
Component: 1F Throttle Control.HL KLO 0009
Subsystem 4 - Part number: 1C0959812A
Component: 1F Throttle Control.HR KLO 0009
"One error found:"
00929 - Door lock module for central locking, passenger side (F221)
End----------------------------(Duration: 06:14)-----------------------------
Gruß Felix
E91 330d, 1/2009
Translated on 27-08-2026, 22:01.
haithamina
dieselschrauber likes this.
Post06-07-2017, 7:31    Subject: BLS Replacement: How to Do It Right Quote
Hello Felix.
So, back then, I replaced the BLS (Brake Light Switch) in about 10 minutes, which solved the brake light problem.
The battery was replaced for the first time after 10 years, as described. The alternator was definitely not in the best condition, but I didn't replace it until I sold the 3BG, around April 2015. The on-board voltage wasn't always perfect, but I'm not sure if that had anything to do with the rear hatch handle... In any case, I didn't have to replace the latter.
haithamina
Translated on 27-08-2026, 22:10.
felix
Avatar-felix
Post06-07-2017, 8:02    Subject: Brake Light Switch & Trunk Release - DIY Repair Quote
Thank you, Haithamina.
The error occurred recently, but it could be cleared, and it was not reproducible for a few days afterward.
Yesterday, the error could no longer be cleared, and after my post, I was smart enough to check the brake lights icon_redface.gif.
I went ahead and ordered the switch.
Sometimes, it's not that complicated icon_biggrin.gif.
Gruß Felix
E91 330d, 1/2009
Translated on 27-08-2026, 22:11.
No new posts Faulty brake light switch F Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Retrofit Electric Trunk Release Audi A3 8L Transmission, Chassis, Body & Interior
No new posts Brake Light Switch On-Board Diagnostics (OBD)
No new posts Brake light switch, AFB engine Diesel Engine Technology
No new posts Brake Light Switch Wiring Diagram AFN vs 1Z Diesel Engine Technology
