Audi A5: 7-Speed S-Tronic Basic Settings Not Working
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
zweimeter
Post02-04-2017, 16:06    Subject: Audi A5: 7-Speed S-Tronic Basic Settings Not Working Quote
Hello.
I'm stuck on the "Counter Start/Stop" reset step when trying to reprogram the S-Tronic.
The error occurs there: Invalid value range.
Error codes were clear.
If I simply go to the clutch valve calibration, it starts the process, but then stops after 1 minute with an "Aborted due to safety...something" error.
I haven't been able to find a solution through Google yet, other than the fact that someone in an English forum is experiencing the same problem.
I would be happy to attach VCDS logs/screenshots.
Translated on 26-09-2026, 13:42.
Post02-04-2017, 17:29    Subject: Audi A5: 7-Speed S-Tronic Basic Settings Not Working Quote
Please provide an Autoscan and a Screenshot showing where the problem occurs.
Translated on 26-09-2026, 13:43.
zweimeter
Post02-04-2017, 18:29    Subject: Audi A5: 7-Speed S-Tronic Basic Settings Not Working Quote
Autoscan.
Sunday, April 2, 2017, 2:34:46:52943
VCDS, a Windows-based VAG/VAS emulator, runs on Windows 7 x86.
VCDS Version: DRV 17.1.2.0
Data as of: 20170113 DS267.0
shop.dieselschrauber.org
Vehicle Identification Number: XXX Vehicle Registration Plate: XXX
Mileage: 174,310 km. Repair order:
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BĂ€ume, und die BlĂ€tter rascheln leise. Es ist ein wunderschöner Tag, um draußen zu sein."
Vehicle type: 8T (8T0)
Scan: 01 02 03 05 06 08 09 10 15 16 17 19 36 42 46 52 53 55 56 5F
69.
Vehicle Identification Number: XXX Mileage: 174,310 km
01-Motor electronics -- Status: OK 0000
02-Gearbox -- Status: OK 0000
03-Brake electronics -- Status: OK 0000
04-Steering angle sensor -- Status: OK 0000
05-Access/Startup Report -- Status: OK 0000
06-Passenger seat adjustment -- Status: OK.
08-Climate control/heating unit -- Status: OK 0000
09-Central Electrical System -- Status: OK.
Parking Assist 10 -- Status: OK 0000
15-Airbag -- Status: OK 0000
16-Wheel steering electronics -- Status: OK 0000
17-Terminal block insert -- Status: OK 0000
19-Diagnosis interface -- Status: OK 0000.
36-seat adjustable passenger seat -- Status: OK 0000.
42-Door Electric Driver -- Status: OK 0000
46-Comfort System -- Status: Error 0010.
52-door electric passenger door - Status: OK 0000.
53-Parking brake -- Status: OK 0000
55-Beam adjustment. -- Status: OK 0000.
56-Radio -- Status: OK 0000
5F-Information Selection. I -- Status: Error 0010.
69 followers -- Status: OK 0000
Address 01: Engine Control Module (J623-CCWA)
Label file: DRV\059-907-401-V1.clb
Part number SW: 8R0 907 401 J, HW: 8K1 907 401 A.
Component: 3.0TDI EDC17 H14 0008.
Revision: 15H14---
Encoding: 0114002C240F0928
Operating number: WSC 46655 133 89066
ASAM Dataset: EV_ECM30TDI0118R0907401J 001008
ROD: EV_ECM30TDI0118R0907401J.rod
VCID: 3940BA32B8975D89E4-806C
No error codes found.
Readiness: 0 0 0 0 0
Address 02: Transmission (J217)
Label file: DRV\0B5-927-156.clb
Part number SW: 8K1 927 156 H, HW: 0B5 927 156 F.
Part number: 0B5 30 TDIRdW H05 0008
Revision: --H05--- Serial Number: 0000000287
Encoding: 000001
Operating number: WSC 06325 000 00000
ASAM Dataset: EV_TCMDL501 A02087
ROD: EV_TCMDL501.rod
VCID: 3A42A53EBD915691ED-806E
Address 03: Brake Electronics (J104)
Label file: DRV\8K0-907-379-V1.clb
Part number SW: 8K0 907 379 BJ
Part number HW: 8K0 907 379 BJ
Component: ESP8 quattro H04 0050.
Revision: -------- Serial Number: --------------
Encoding: 1CCD08
VCID: 02321DDE9DC1DE51F5-8056
Address 05: Access/Startup Authorization (J393)
Label file: DRV\8K0-907-064-05.clb
Part number SW: 8K0 907 064 CP
Part number HW: 8K0 907 064 CP
Component: BCM2 2.0 H04 0430
Revision: 00002001
Encoding: 010000
VCID: 003617D693CDCC41E3-8054
Subsystem 1 - Part number SW: 8T0 959 754 D, HW: 8T0 959 754 D.
Component: FBSAUDIB8 IDG H50 0071
Serial number: 0810000113133010
Subsystem 2 - Part number SW: 8K0 905 852 D, HW: 8K0 905 852 D.
Component: J764 ELV MLB H37 0042.
Serial number: 2310000045066005
Address 06: Front Seat Adjustment (J521)
Label file: 8T0-959-760.clb
Part number SW: 8T0 959 760 C, HW: 8T0 959 760 C.
Component: MEM-BFS H10 0074
Revision: AA000000 Serial Number: 00001002169029
Encoding: 00017025002C00000000
VCID: 43BCD8DAC25B1759BE-8016
Address 08: Climate Control/Heating Unit (J255)
Label file: DRV\8Tx-820-043-1Z.clb
Part number SW: 8T1 820 043 AN, Hardware number: 8T1 820 043 AN.
Component: CLIMATE ZONE 1, Part Number H08 0180.
Revision: A1000000 Serial Number: 01031120100870
Encoding: 36120000
VCID: 7DC86E22E43FA1A988-8028
Address 09: Central Electronics (J519)
Label file: DRV\8K0-907-063.clb
Part number SW: 8K0 907 063 P, HW: 8K0 907 063 P.
Component: BCM1 1.0 H30 0392
Revision: 10030001 Serial Number: 00000000843506
Encoding: 260050914034AF010009000300005D5D001C638802010101000000
VCID: 3C4EA326BFA568A1FF-8068
Subsystem 1 - Part number SW: 8T1 955 119 D, HW: 8J1 955 119, Label file: DRV\1KX-955-119.CLB.
Component: WWS 231010 H14 0070
Serial number: SWF10100235349
Encoding: 00FD11
Subsystem 2 - Part number SW: 8K0 955 559 HW: 8K0 955 559 Label file: DRV\8K0-955-559.CLB
Component: RLS H04 0003.
Serial number: 11130705
Encoding: 02532C
Subsystem 3 - Part number SW: 8K0 941 531 AL, HW: 8K0 941 531 AL.
Component: E1 - LDS H08 0090
Serial number: 00000000002110101330
Address 10: Parking Assist 2 (J446)
Label file: DRV\8K0-919-475.clb
Part number SW: 8K0 919 475 R, HW: 8K0 919 475 A.
Part: PARKING ASSIST 8K H06 0070
Revision: 11001001 Serial number: 50901030300228
Encoding: 110101
VCID: 48A6CFF6FB7D34016B-801C
Address 15: Airbag (J234)
Label file: DRV\8K0-959-655.clb
Part number SW: 8K0 959 655 L, Part number HW: 8K0 959 655 L.
Component: Airbag
VW-AU10 H41 0610
Serial number: 003JMD0161BX
Encoding: 30513433363030303030554A304C38543053
ASAM Dataset: EV_AirbaECUVWAUDI010 003010
ROD: EV_AirbaECUVWAUDI010_003_AU48.rod
VCID: 46BAC1CEF969227199-8012
Crash sensor for driver-side side airbag:
Serial number: 6334MSME3D507740C
Crash sensor for side airbag, passenger side.
Serial number: 6344MSME58130928A
Rear side airbag crash sensor (driver's side).
Serial number: 6352QSME0E7A4D36Y
Crash sensor for rear side airbag, passenger side.
Serial number: 6362QSME7C79040AR
Crash sensor for front airbag, driver's side:
Serial number: 63732SME48602814W
Crash sensor for front airbag, passenger side.
Serial number: 63832SME4360103EV
Address 16: Steering Wheel Electronics (J527)
Label file: DRV\8K0-953-568.clb
Part number SW: 8R0 953 568 K, Part number HW: 8R0 953 568 K.
Component: Steering module H06 0156.
Revision: 00000000 Serial Number: 20101104000488
Encoding: 000036
VCID: 49A0CAF2E077CD0974-801C
Component: E221 - MFL H02 0010
Address 17: Control panel module (J285)
Label file: DRV\8T0-920-xxx-17.clb
Part number SW: 8T0 920 931 M, Hardware number: 8T0 920 931 M.
Bauteil: KOMBIINSTR. H40 0258
Revision: 00100000 Serial number: EHX22L4CA
Encoding: 0F07010003000008000000
VCID: 41B0D2D2D8470549AC-8014
Address 19: Diagnostic interface (J533)
Label file: DRV\8T0-907-468.clb
Part number SW: 8T0 907 468 AD, HW: 8T0 907 468 K.
Component: GW-BEM 4CAN-M H09 0117
Revision: EC000056 Serial Number: 5600E10A19001B
Encoding: 00C303
VCID: 033C18DA82DBD759FE-8056
Subsystem 1 - Part number SW: 8K0 915 181 E, HW: 8K0 915 181 E.
Component: J367-BDM H07 0170
Serial number: 10004474021110
Address 36: Seat adjustment for driver (J136)
Component: MEM-FS H10 0074
Revision: AA000000 Serial Number: 00001002169606
Address 42: Door electrical driver (J386) Label file: 8K0-959-793.clb
Part number SW: 8T0 959 793 M, HW: 8T0 959 793 D.
Component: TSG FA, H08 1401.
Encoding: 011002225000120102
VCID: 539CE89A323B87D90E-8006
Address 46: Comfort System (J393)
Label file: DRV\8K0-907-064-46.clb
Revision: 00002001 Serial number: 0137617997
Encoding: 0100068000B900808120003280000000
"One error found:"
01565 - Trunk light (W3)
009 - Short circuit to ground / Ground fault.
Environmental conditions:
Error status: 01101001
Error priority: 2
Error frequency: 1.
Lost Count: 69
Mileage: 174,318 km
Time: 0.
Date: 2017.04.02
Time: 14:15:18
Address 52: Power door lock, front passenger side (J387)
Label file: 8K0-959-792.clb
Part number SW: 8T0 959 792 M, HW: 8T0 959 792 D.
Component: TSG BF H08 1401
VCID: 5292ED9E0D218ED105-8006
Address 53: Parking brake (J540)
Label file: DRV\8K0-907-801-V1.clb
Part number SW: 8K0 907 801 H, HW: 8K0 907 801 H.
Part: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 00000000779607
Operating Number: WSC 00000 000 00000
VCID: 345E8B0697F5A0E137-8060
Address 55: Headlight range control. Label file: DRV\8K0-907-357.clb
Part number: 8K5 907 357 B.
Component: Dynamic LWR, H02 0010.
Revision: 00000001 Serial number:
Encoding: 0000002
VCID: 3940BA3270975D89E4-806C
Address 56: Radio (R) Label file: DRV\4F0-035-0xx-56.clb
Part number SW: 4G0 035 056 H, HW: 4G0 035 056
Component: Radio U STD H52 0134.
Revision: AB001007 Serial Number: 469K30A7605715
Encoding: 010003020100000001
VCID: 267A614E5129C271B9-8072
Address 5F: Information Selection. I (J794)
Label file: DRV\4E0-035-6xx-5F.clb
Part number SW: 8T1 035 666 M, HW: 8T1 035 666 E.
Component: H-BN-EU H49 0187
Revision: -------- Serial Number: 483K$0AB004814
Encoding: 010100020006A1ED41002B1E000000030000
VCID: 44BEDBC6C755106187-8010
Subsystem 1 - Part number: 8R0 060 884 DF
Component: EUR 2016 2204
Subsystem 2 - Part number SW: 8F0 919 604, HW: 8F0 919 604.
Component: DU7 High, H43 0098.
Serial number: 9466K$0A0246654
Subsystem 3 - Part number SW: 8T0 919 609 F, HW: 8T0 919 609 F.
Component: E0380, Used. H08 0100.
Serial number: 00000000668492
Subsystem 4 - Part number: 8R0 060 961 A
Component: CD Database 2712.
"One error found:"
03276 - Verify software version management.
000 - -
Error status: 01100000
Error priority: 6
Error frequency: 1.
Lost Count: 69
Mileage: 174,318 km
Time: 0.
Date: 2017.04.02
Time: 13:26:26
Voltage: 12.30 V
Address 69: Trailer (J345) Label file: DRV\8K0-907-383.clb
Part number SW: 8K0 907 383 E, Part number HW: 8K0 907 383 E.
Component: Trailer H07 0100
Revision: 1A001001 Serial Number: 00000134001742
Encoding: 010D000000000000
Operating number: WSC 25381 000 00000
VCID: 365AB10E8189B2F109-8062
End----------------------------(Duration: 02:56)-----------------------------
Address 02: Error codes cleared.
Translated on 26-09-2026, 14:19.
zweimeter
Post02-04-2017, 18:30    Subject: Audi A5: 7-Speed S-Tronic Basic Settings Not Working Quote
gear scan
Sunday, April 2, 2017, 1:18:04:52943
License plate: XXX
Address 02: Transmission.
Control unit part number: 8K1 927 156 H.
Component and/or version: 0B5 30 TDIRdW H05 0008
Encoding: 000001
Company number: WSC 06325
Enhanced Identification / CONCLUSION
Serial number: 0000000287.
Identification: TFK-030.
Revision: --H05---
Date: 10/15/2010
Manufacturer part number: 0903.
Test item number: 0287.
Flash Status
Programming attempts (application): 1/1.
Successful attempts (application): 1/1.
Programming status: 00000000
Flash Date: 2008-12-05
Flash Date: 0000.00.00
Flash Tool Number: 00000 000 00000
Software.
UDS: 02/01/2013
ISO15765: 02/01/2016
CAN: 01.07.00
HiSpd Net: 01.06.00
Miscellaneous.
Hardware number: 0B5 927 156 F
System abbreviation: J217
ASAM Dataset Revision: A02087
Vehicle Information.
VCDS Info:
Translated on 26-09-2026, 14:23.
floundso
Post11-07-2017, 12:34    Subject: Audi A5: 7-Speed S-Tronic Basic Settings Not Working Quote
Same issue here. Was there a solution for this?
Translated on 26-09-2026, 14:27.
Post11-07-2017, 12:41    Subject: Audi A5: 7-Speed S-Tronic Basic Settings Not Working Quote
floundso wrote:
Same error here. Was there a solution for this as well?
Best regards
Autoscan? Is the latest version of VCDS being used, specifically version 17.1.3?
zweimeter
Post14-07-2017, 21:19    Subject: Audi A5: 7-Speed S-Tronic Basic Settings Not Working Quote
I have version 17.1.2.
But shouldn't that be unrelated? The car/data version is certainly much older than this VCDS version, right?
I'll do an update if it's easy icon_biggrin.gif.
Or, it's possible that I've done this before.
Translated on 26-09-2026, 14:28.
No new posts Problem: Electronic Parking Brake (S-Tronic) in Audi A4, ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 1.4 TSI CTHA basic settings not available in the engine c... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A4 B6 Rear Door Won't Unlock Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts DSG: No 6-Speed Default Setting Possible On-Board Diagnostics (OBD)
No new posts Audi 4-Gang Automatic Transmission (097, CEB) Initial Setup On-Board Diagnostics (OBD)
No new posts Gear Shift Problem: 5th Gear Not Engaging Transmission, Chassis, Body & Interior
No new posts New Beetle TDI: 5. The gang can't go out anymore Transmission, Chassis, Body & Interior
