Calibrate load pressure sensor and turbocharger, Polo 6C GTI
Linse83
Post19-07-2017, 17:07    Subject: Calibrate load pressure sensor and turbocharger, Polo 6C GTI Quote
hi
Unfortunately, I have a rather silly request.
We upgraded the turbocharger in my Polo 6C GTI from an IS12 to an IS38 (Golf R).
Now, let's move on to the following problem:
We need to recalibrate the boost pressure sensor because the original one only supports up to 1.5 bar, while we've installed one that supports up to 3 bar.
The error code in the fault memory is now 26363 - sensor for boost pressure G31... This is also understandable, as it's providing other incorrect values.
Can someone explain to me how to pair this device?
Here's the translation:
"Also, how do I retrain the turbo?"
It is clear that I still need to have the charger adjusted by a tuner using software icon_wink.gif.
Translated on 13-07-2026, 16:15.
Post19-07-2017, 18:43    Subject: Calibrate load pressure sensor and turbocharger, Polo 6C GTI Quote
There's nothing that can be learned or adjusted through diagnostics.
The chip tuner must take into account the modified components in the data set from the engine control unit.
And without wanting to offend anyone: It's very unwise to install any components without consulting the specific chip tuner, especially if you think those components are great.
Normally, the chip tuner has very specific ideas about what modifications are appropriate for the engine, and they usually achieve this by using their own components to ensure a reliable and high-quality result.
Translated on 13-07-2026, 16:17.
Linse83
Post19-07-2017, 18:50    Subject: Calibrate load pressure sensor and turbocharger, Polo 6C GTI Quote
Don't worry, this has been discussed in great detail with the tuning specialist, who will be installing all the components and taking care of the tuning himself.
but the answer already helps me, I will reinstall the old sensor and then change it on-site, thank you icon_smile.gif.
Translated on 13-07-2026, 16:19.
No new posts Train T90 / T 91 with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Steering Angle Sensor: How to Recalibrate? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Documentary: Programming VW car keys from 1998 onwards Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Turbocharger: Boost Performance and Power Diesel Engine Technology
No new posts AFN Turbo Conversion: Is it Possible? Diesel Engine Technology
No new posts VW Polo TDI Recall: 75hp, 2002 Model Diesel Engine Technology
No new posts Polo 9N 100PS TDI: Owners, share your experience! Diesel Engine Technology
