DPF BWB Polo 9N3 1.4 TDI: Jerky, Wave-like Power
3bAFN
Karma: +33 / -0   Thank you, like it!
Post20-07-2017, 23:24    Subject: DPF BWB Polo 9N3 1.4 TDI: Jerky, Wave-like Power Quote
Hello everyone,
I'm having a small problem with my Polo. It's experiencing slight jerking and a fluctuating power delivery, especially at speeds between 80 and 100 km/h.
Normally, I would have expected a higher LLM (Loan-to-Value ratio), but the loan-to-income ratio and the AGR (Annual Growth Rate) seem quite strange. The AGR appears to be generally very high and, in some cases, remains at 100.3%, seemingly independent of the repayment rate.
It would be very helpful if I could take a look at the file and hear your opinions.
Best regards, Sören.
LOG-01-011-003-01pp0.CSV
 File name:  LOG-01-011-003-01pp0.CSV
 File size:  8.43 KB
 Downloaded:  420 times
Translated on 04-10-2026, 19:12.
Post21-07-2017, 9:54    Subject: DPF BWB Polo 9N3 1.4 TDI: Jerky, Wave-like Power Quote
In the partial load range, if the EGR system is still functioning, the actual air mass is significantly higher than the target air mass, and the duty cycle for the EGR control is at its maximum.
I suspect your AGR valve is sticking, defective, or there are problems with its control (if pneumatic: leaks in the vacuum hose or the solenoid valve is stuck).
Translated on 04-10-2026, 19:14.
No new posts Not LLM: Poor Performance Explained. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts WIV reset on VW Polo 9N TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo Combo Instrument Cluster, 10.99-09.2001 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo 9N: Low Power After Sick Leave & ESP Issues Diesel Engine Technology
No new posts Wave Acceleration on 2.5L V6 6Zyl Engine Diesel Engine Technology
No new posts Jerky Acceleration: Causes & Fixes Diesel Engine Technology
No new posts Volvo V70 TDI with Audi/AEL wave-like acceleration Diesel Engine Technology
