Thank you in advance for your help and contributions. Unfortunately, I've reached the limits of my search capabilities, and I hope you might be able to provide me with the information I need.
My vehicle is a Passat 6B with a 2.0 TDI engine and 170 horsepower (the engine code is CBBB).
After the update from VW was performed, I initially experienced problems with the regeneration of the particulate filter and a significantly increased fuel consumption. The whole story ended with an engine failure that VW doesn't want to cover.
We have already completely disassembled the engine and are now in the process of reassembling it. However, we are missing the torque specifications for the crankshaft itself.
