Polo 6R Brake Pads: Replacement Guide
Post21-08-2017, 19:52    Subject: Polo 6R Brake Pads: Replacement Guide Quote
When replacing the pads on the FS III disc brake, the caliper is loosened and removed along with the pads. According to the manufacturer's instructions, that's the theory. However, if the pads are worn and have recessed into the disc, the pads need to be separated beforehand. How do you do it? I've managed to do it, but there's no good place to grip either a clamp or pliers. I couldn't push the piston back manually.
Translated on 10-10-2026, 15:50.
Post21-08-2017, 19:57    Subject: Polo 6R Brake Pads: Replacement Guide Quote
Hi Herbert,
Insert a sturdy screwdriver between the brake disc and the pad and pry them apart. This works perfectly. Besides, the pads are being replaced anyway, so it doesn't matter if some material breaks off.
Translated on 10-10-2026, 15:51.
Karma: +645 / -0   Thank you, like it!
Post21-08-2017, 19:59    Subject: Polo 6R Brake Pads: Replacement Guide Quote
I don't follow the RLF (manufacturer's) instructions, but I use my common sense (when I have any). I insert a large screwdriver between the brake disc and the pad and push the piston and the pad back. Usually, I replace both the discs and the pads, so it's not a problem if there are imperfections in the friction material.
Translated on 10-10-2026, 15:52.
Post21-08-2017, 20:05    Subject: Polo 6R Brake Pads: Replacement Guide Quote
Hi Rainer,
Of course, that's also possible, as long as you don't want to work in a non-destructive way.
I will describe the actual error message once I have finished the second page, and hopefully that will be the end of it.
Good evening.
Translated on 10-10-2026, 15:53.
Post21-08-2017, 20:07    Subject: Polo 6R Brake Pads: Replacement Guide Quote
I don't work according to RLF, but rather with my head and common sense (if available)
....if available....
s.i.c.
No new posts Removing and cleaning a diesel particulate filter (DPF) Troubleshooting & Guides
No new posts Passat 3BG AVB - Remove bearing from Visco fan Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo 86c 40 kW, year 1992, 1272 ccm, AAV throttle potenti... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts T6 brake pad warning light Transmission, Chassis, Body & Interior
No new posts Ferodo Brake Pads Transmission, Chassis, Body & Interior
No new posts EBC Blackstuff Brake Pads Transmission, Chassis, Body & Interior
No new posts ATE Ceramic Brake Pads: Review & Performance Transmission, Chassis, Body & Interior
