klahaui Profi-Schrauber
Joined: 08/13/2009 Posts: 1102 Karma: +125 / -0 Location: Vogtland, Land der Berge 2019 Volkswagen Golf Premium Support
08-05-2014, 19:55 Subject: Audi 8E RS4 Signal for Engine Immobilizer Short to Ground |
I have a problem where the warning light on the RS4 is on, and the diagnostic system is detecting a short circuit to ground related to the starter motor.
Following advice, the clutch pedal switch was replaced. Unfortunately, the error still cannot be cleared, and the warning light continues to illuminate.
Has anyone perhaps got any ideas what this might be?
Please provide the text you want me to translate. I need the German text to be able to translate it into English, keeping all s exactly as they are.
Monday, April 28, 2014, 19:10:48:10115
VCDS -- Windows-based VAG/VAS Emulator
VCDS Version: DRV 12.12.2.0
Data Status: 20140225
Vehicle Identification Number: WUAZZZ8E86NXXXXXXX Vehicle Registration Number: X-XX-XXXX
Odometer: 56840km Repair order:
Vehicle Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
Vehicle Identification Number: WUAZZZ8E86NXXXXXX Kilometerstand: 56840km
Address 01: Engine Electronics Label file: 079-910-560-BNS1.lbl
Part Number SW: 8E1 910 560 HW: 8E1 907 560
Part: 4.2L V8/4V FSI ™1O1
Revision: --H09--- Serial Number: XXXXXXXXXXXXXX
Encoding: 01040003180F0160
Operating Number: WSC 00191 264 15243
VCID: E3C157A52272BB06665-80B6
1 Error found:
005924 - Signal for Event Closure
P1724 - 001 - Short to Ground
Freeze Frame:
Error Status: 01100001
Error Priority: 0
Error Frequency: 1
Loss Counter: 255
Odometer: 56847 km
Time: 0
Freeze Frame:
Speed: 0 /min
Last: 0.0 %
Speed: 0.0 km/h
Temperature: 81.0∞C
Temperature: 54.0∞C
Pressure: 980.0 mbar
Voltage: 11.938 V
Readiness: 0110 0100
Address 03: Brake Electronics Label file: DRV\8E0-910-517.clb
Part Number SW: 8E0 910 517 G HW: 8E0 614 517 BD
Part: ESP8 quattro H06 0150
Revision: 00000000 Serial Number: 00000000000000
Encoding: 0004534
Operating Number: WSC 06335 000 00000
VCID: 2B517F858A22B3461E5-807E
No error codes found.
Address 08: Climate/Heating Control Label file: DRV\8E0-820-043.lbl
Part Number: 8E0 820 043 BR
Component: A4 Air Conditioner 2833
Encoding: 00000
Operating Number: WSC 00000
VCID: 72EFA2E13E88A28E9D3-5120
Address 09: Central Electrical Label file: DRV\8E0-907-279-8EC.lbl
Part Number: 8E0 907 279 N
Part: int. Last Module ECE 0907
Encoding: 01021
VCID: 3D7541DD37562DF6B01-4B00
Address 11: Engine Electronics 2 Label file: 079-910-560-BNS2.lbl
Address 15: Airbag Label file: DRV\8E0-959-655-94.lbl
Part Number SW: 8E0 959 655 G HW: 8E0 959 655 G
Part Number: Airbag 9.41 H12 3730
Revision: 91H12373 Serial Number: 0036M0G0HH2/
Encoding: 0430712
VCID: 3B714FC57A4223C68E5-806E
Subsystem 1 - Serial Number: 6332DRB4034B45ADX
Subsystem 2 - Serial Number: 6342DRB4034A09A8S
Subsystem 3 - Serial Number: 6352ARB40135FD02L
Subsystem 4 - Serial Number: 6362ARB401325D26F
Subsystem 5 - Serial Number: 63729RB40131F02EJ
Subsystem 6 - Serial Number: 63829RB40131F062C
Address 16: Steering Electronics Label file: 8E0-953-549-T.lbl
Part Number: 8E0 953 549 T
Part: Steering Column Module 0201
Coding: 06021
VCID: 4483343954BC5C3EFFF-4B00
Address 17: Control Panel Module Label file: DRV\8E0-920-9xx-8EC.lbl
Part Number SW: 8E0 920 931 G HW: 8E0 920 931 G
Component: KOMBI+WFS 4 H14 0040
Revision: 0040 Serial Number: 00000000000000
Encoding: 0023021
Operating Number: WSC 27138 126 83636
VCID: 2C537C998C2CB47E17F-513C
Address 25: Immobilizer Label file: DRV\8E0-920-9xx-8EC.lbl
Encoding: 0023021
Address 36: Seat Adjustment Label file: 8E0-959-760.lbl
Part Number: 8E0 959 760 A
Part: Seat Adjustment H01 0020
Encoding: 00001
VCID: 326F62E1FE08E28E5D3-4B00
Address 37: Navigation Label file: DRV\8E0-035-192-RNSE.lbl
Part Number SW: 8E0 035 192 D HW: 8E0 035 192 D
Part Number: RNS-E HIGH EU H72 0650
Revision: 04S Seriennummer: AUZBZ7F1146397
Encoding: 0309713
Operating Number: WSC 02197 785 00200
VCID: 254589BDEFC68536C81-5178
Address 45: Interior, Overrange Label file: DRV\8E0-951-177.lbl
Part Number: 8E0 951 177
Component: Interior Monitoring 0804
Encoding: 00001
VCID: EBD13F8599A2F346DE5-513C
Address 46: Comfort System Label file: DRV\8E0-959-433-MAX.lbl
Part Number: 8E0 959 433 CH
Component: Comfort Device T3B 4035
Encoding: 06720
Operating Number: WSC 67466
VCID: 79FD95CD63FED1D6DC9-4B00
Subsystem 1 - Part Number: 8E1959801G
Part: Door Control. FS BRM 0706
Subsystem 2 - Part Number: 8E1959802G
Part: Door Control. BF BRM 0706
Subsystem 3 - Part Number: 8E0959801E
Part: Door Control. HL BRM 0606
Subsystem 4 - Part Number: 8E0959802E
Part: Door Control. HR BRM 0606
Address 55: Light fixture control. Label file: DRV\4F0-910-357.lbl
Part Number SW: 4F0 910 357 E HW: 4F0 907 357 E
Part: AFS 1 H01 0010
Revision: 00000001 Serial Number:
Encoding: 0000019
VCID: 285B80899BD4985EF37-807D
Subsystem 1 - Part Number: 8E0 941 329
Part: AFS Module left H03 0020
Subsystem 2 - Part Number: 8E0 941 329
Part: AFS Module rightH03 0020
Address 56: Radio Label file: DRV\8E0-035-192-RNSE.lbl
Encoding: 0309713
Address 65: Tire Pressure Label file: 8E0-907-273.lbl
Part Number SW: 8E0 907 273 HW: 8E0 907 273
Part: Tire Pressure 3 H04 0110
Encoding: 0022523
VCID: E9DD458DC35EE156AC9-513C
Address 76: Parking Assist Label file: DRV\8E0-919-283-8EC.lbl
Part Number SW: 8E0 919 283 E HW: 8E0 919 283 E
Part Number: Parking Assist 8-Channel H06 0010
Revision: 00H06000 Serial Number: 00067802120611
Encoding: 0000104
VCID: 326F62E1AE08E28E5D3-515A
Address 77: Telephone Label file: DRV\8P0-862-335.lbl
Part Number SW: 8P0 862 335 M HW: 8P0 862 335 M
Part: FSE_255x BT H21 0200
Revision: 00000001 Serial Number: 00000000449214
Encoding: 0010711
VCID: 408B382910A4401EDB7-513C
Ende -------------------------------------------------------------------- Kaum macht man es richtig, funktioniert es!
Profile PM Garage |
guste100 Profi-Schrauber
Joined: 07/27/2004 Posts: 2401 Karma: +438 / -0 Location: Mitte Schleswig Holsteins 2007 Volkswagen Passat Premium Support
09-05-2014, 9:09 Subject: Audi 8E RS4 Signal for Engine Immobilizer Short to Ground |
First of all: I don't know the answer and can only speculate based on the SLP:
The starter appears to be locked by three things:
- Relays for emergency stop J207 (mainly for automatic transmissions)
- Relais 2 for Starter J695 (Position 3, connected to MSG, Pin 52)
- Relays for Starter J53 (Position 4, connected to the MSG, pin 74)
I suspect that if one of the relays fails, this error message in the MSG could appear, because the MSG monitors pin 24 to see if both relays are switching.
Test:
At least, when starting, pin 52+74 must be pulled to ground. Pin 24 must then (through both relays in series) be connected to +12V.
In any case, the car should not be starting at the moment, right?
Greetings
Guste
Profile PM Garage |
09-05-2014, 11:15 Subject: Audi 8E RS4 Signal for Engine Immobilizer Short to Ground |
Hey,
The vehicle is running and starting without any problems.
My assumption is that the "lock" refers to the locking mechanism that prevents the engine from restarting if it has been shut down unexpectedly, thus preventing a second attempt to start the engine.
Could the start button possibly be causing this error? I don't consider replacing it solely on suspicion to be a particularly good idea.
According to your statements, he shouldn't start at all if one of the 3 relays is defective, right?
Greetings Kaum macht man es richtig, funktioniert es!
Profile PM Garage |
09-05-2014, 12:35 Subject: Audi 8E RS4 Signal for Engine Immobilizer Short to Ground |
klahaui wrote: | | According to your statements, it shouldn't start at all if one of the 3 relays is defective? |
Yes, that's correct. However, you will only have two relays working without automation. Therefore, the relays and the control from the MSG are already okay (perhaps only pin 24 is missing, which is the relay's feedback to the MSG, but this is unlikely.)
What else might be missing? Feedback from automatic start-stop relay to the MSG, pin 23 (but should this even be present without automatic start-stop?). There, however, the specific one is connected with the Start/Stop button.
Coupling pedal switch (must connect to ground at MSG pin 39, which you already replaced).
Honestly, I don't really notice anything special about the SLP. Possibly a brake pedal switch?
klahaui wrote: | | Could the start button possibly be causing this error? I don't consider replacing something based solely on suspicion to be a particularly good idea. |
He only switches between MSG Pin 23 and D. But I think the SLP is a bit faulty at this point, because some things are not properly connected. Sorry, I can't help with that.
Have you checked the switches in the data blocks (coupling, BOTH brake pedal switches and the start switch)?
Profile PM Garage |
Audirs47
20-10-2017, 19:24 Subject: Audi RS4 Immobilizer. |
Hello everyone
I have been experiencing the same error with the ignition lock for the past 3 days.
Clutch and brake light switch already replaced without success.
Has there now been a solution klahaui?
Best regards
20-10-2017, 21:07 Subject: Audi 8E RS4 Signal for Engine Immobilizer Short to Ground |
Good evening,
Unfortunately, I cannot provide a solution. I have never seen the vehicle again. Kaum macht man es richtig, funktioniert es!
Profile PM Garage |
Audirs47
20-10-2017, 21:12 Subject: Audi 8E RS4 Signal for Engine Immobilizer Short to Ground |
Okay.
Thank you anyway for the quick response.
I am very grateful for any tips regarding this problem.
