Electric Heater AFN: Parameters & Control Logic
lucky loser
Post24-10-2017, 11:27    Subject: Electric Heater AFN: Parameters & Control Logic Quote
Hi everyone,
I hope I'm in the right subforum.
I'm looking for some information about the switching conditions for the electric auxiliary heater (3 glow plugs in the engine cooling circuit, VW, AFN, 3B2, MJ98, 5-speed, manual climate control).
They are probably only connected to the engine control unit with a 3-stage switching system.
Could someone provide me with some information about the conditions that must be met for the heating system to activate, or how the overall heat management of the auxiliary heater works?
Thank you very much for your help.
Translated on 29-09-2026, 21:47.
Karma: +1344 / -0   Thank you, like it!
Post24-10-2017, 21:02    Subject: Electric Heater AFN: Parameters & Control Logic Quote
The dependencies include:
- Outdoor temperature;
- Engine temperature;
- Charging status.
Please refer to the forum rules for further questions. You are looking for information about the MSG and need diagnostic software for it.
Translated on 29-09-2026, 21:48.
DieselBär30x
Avatar-DieselBär30x
Post26-10-2017, 22:36    Subject: Electric Heater AFN: Parameters & Control Logic Quote
Hello everyone!
In my opinion, for this basic information, diagnostic equipment is not mandatory.
The AFN's MSG stores the temperature of the intake air temperature sensor when the engine is started.
If the measured temperature is below 5°C, either one or two, or one plus two, heating elements of the auxiliary heater are activated. The latter depends on the generator load, which is also transmitted to the MSG via terminal DF.
The cut-off temperature of the auxiliary heater is variable and depends on the measured starting temperature of the intake manifold sensor: The colder it was at the start, the longer the auxiliary heater remains active.
Best regards from Passau!
Translated on 29-09-2026, 21:49.
No new posts Additional coolant heater for the TDI Technical Articles
No new posts Electrical Stability Program Diesel Engine Technology
No new posts Elektr. Heckklappenentriegelung A3 8L Bj.98 nachrüstbar? Transmission, Chassis, Body & Interior
No new posts Mehrere Elektr(on)ik-Probs beim Golf 3 TDI GT On-Board Diagnostics (OBD)
No new posts Electrical. Hidden operation - button or switch? Transmission, Chassis, Body & Interior
