01237 - Kraftstoffabschaltventil - sporadischer Fehler | Posts 16+
Go to page: Previous  1, 2
Karma: +1336 / -0   Thank you, like it!
Post19-11-2017, 23:49    Subject: Quote
I'm asking because you're describing something as the cause of your issue that is actually physically impossible.
H
stiervr6
Avatar-stiervr6
Post20-11-2017, 9:35    Subject: Quote
Physically speaking, there is the law of energy conservation: The electrical energy (battery) provided was converted into thermal energy (burnt-out wires).
What you mean is, there is no direct electrical connection between the VP37 housing and the 3-pin connector to the control unit.
ok, aber das einzige, was er laut Aussage getan hat, war das Entfernen der 6-eckigen Mutter der Lichtmaschine und gleichzeitig das Ziehen am Kabel, das dann aus seiner Hand gerutscht ist und in Richtung VP 37 gerutscht ist...
I will now focus on the relays and perform a 1:1 check...
Why did the ABS block safety fuse fall out?
Corrado VR6 mit ZR2R Kompressor + WAES + NOS 375PS (540Nm)
Passat Variant 1.9TDI 4M (läuft dank Profi Software VAG Com)
Back to top Profile PM Email
Karma: +438 / -0   Thank you, like it!
dieselschrauber and gnasch likes this.
Post20-11-2017, 17:07    Subject: Quote
The thick cable from the alternator directly provides 12V from the battery. According to my knowledge, there is no fuse between the battery and the alternator in this vehicle. In the event of a short circuit to ground/chassis, currents of several hundred Amperes could occur. This is more than what you'd find in a typical welding machine.
The ESP is made of metal and is screwed onto the engine block, which is connected to the chassis with a thick ground wire. Actually, this should be a short circuit, where the current flows through the metal of the ESP, not through it.
Since the ESP control clearly isn't working anymore, a large current must have flowed, resulting in a significant voltage drop across the ground cables, which could have caused further damage.
Regarding current strength, virtually anything can be faulty. In this case, the most likely culprits are probably the ground wires and control units. It's quite conceivable that entire ground wires or ground wire bundles within control units have completely vaporized. This can only be checked piece by piece on-site.
As can already be seen, current is flowing through the blue and gray lines towards the control unit. However, the current does not end there. It must have flowed through the STG and then exited the STG via another line. Since the current has already been sufficient to melt the line, it has certainly also damaged something within the STG. The ground connection of the STG should also be checked. Since the control units are interconnected, more could potentially fail.
The shut-off valve also appears to be completely welded shut. It should also be checked whether the flow meter and the pump of the ESP are still functioning.
That the ABS system has failed, sounds like the power supply there may also have been damaged.
In short: Introducing currents as high as those from a welding machine into electronics can easily cause total damage.
Good luck!
Greetings
Guste
No new posts Caddy Bj 07 BLS AGR Error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Touran Light Fault (FLA, MDF) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P0148 - Fuel Supply Malfunction General Tips
This topic is locked, you cannot edit or reply. AFN glow plug blinking - error code 01237 - ignition timi... On-Board Diagnostics (OBD)
No new posts Engine Power Loss & Intermittent Error 575 Diesel Engine Technology
No new posts Toledo TDI AFN: Error Code 01237 Troubleshooting On-Board Diagnostics (OBD)
No new posts Help!!!! A4 B5 1.9 TDI VAG COM error code 01237 On-Board Diagnostics (OBD)
