Fehler EPB Passat 3C | Posts 16+
Go to page: Previous  1, 2
Post22-05-2017, 14:57    Subject: Quote
Completion: HU (general inspection) passed this morning without any noticeable defects.
pfaelzer02
2006 Volkswagen Passat
Post06-08-2017, 23:40    Subject: Quote
The circuit was measured. There are no errors.
In the EPB control unit, within the measurement data blocks, channel 12 displays the status of the parking brake.
The description states that the status must be set to "on" here.
Therefore, I am unable to program the EPB control unit.
How do I get the status of "zu auf auf"? Pressing the brake pedal firmly and pressing the button simultaneously did not produce any result.
Christian
Post07-08-2017, 10:09    Subject: Quote
Wiesel
Post23-11-2017, 7:17    Subject: Quote
Hello, fellow DIY enthusiasts
Code:
                Adresse 53: Feststellbremse       Labeldatei: DRV\3C0-907-801-53.clb
   Steuergerät-Teilenummer: 3C0 907 801 E    HW: 3C0 907 801 E
  Bauteil und/oder Version: EPB  VC8HC003   013 0003
                 Codierung: 0010000
            Betriebsnummer: WSC 05311 000 00000
                      VCID: 24101DF443DBC007691-8070
4 Fehlercodes gefunden:
01087 - Grundeinstellung nicht durchgeführt
            000 - - - Warnleuchte EIN
01042 - Steuergerät nicht codiert
01316 - Bremsensteuergerät
            013 - bitte Fehlerspeicher auslesen - Warnleuchte EIN
00576 - Klemme 15
            012 - elektrischer Fehler im Stromkreis - Warnleuchte EIN
I'm currently stuck on a similar problem.
While attempting to perform the initial setup, it crashes after a few seconds.
disconnect the connection to the EPB/FSB control unit. She only allows it after another...
Re-initialize the call from address 53.
History:
- The rear left FSB (brake stability system) was "defective" and has been replaced.
- No VCDS for learning/activation.
- FSB still didn't work.
- FSB control unit has been replaced.
- The ABS control unit has lost its coding as a result.
- No change in behavior.
Initial attempts at diagnosis (and my first contact with the vehicle):
- FSB control unit (53) not accessible when ignition is on.
- After activating the FSB (via button), the control unit can be accessed:
Code:
   Teilenummer SW: 3C0 907 801 E    HW: 3C0 907 801 E
   Bauteil: EPB  VC8HC003   013 0003
   Revision:   013
   Codierung: 0010000
   Betriebsnr.: WSC 05311 000 00000
   VCID: 24101DF442DBC0071F2-8070
5 Fehlercodes gefunden:
02443 - Bedienungsteil
02435 - Steuergerät rechter Kanal Spannungsversorgung
            009 - Unterbrechung/Kurzschluss nach Masse - Warnleuchte EIN
02434 - Steuergerät linker Kanal Spannungsversorgung
What was particularly interesting was item 00576. The corresponding fuse is okay.
The voltage is present at the connector, but not really reaching the control unit.
The contact itself is missing the contact spring (or is broken, so that it doesn't...).
(Andruck mehr has). After some minor bending, it re-establishes contact.
Code:
                Adresse 03: Bremsenelektronik       Labeldatei: DRV\3C0-614-095-C2.clb
   Steuergerät-Teilenummer: 3C0 614 109     HW: 3C0 614 109
  Bauteil und/oder Version: ESP 440 C4     H018 0001
                 Codierung: 0010000
            Betriebsnummer: WSC 61272 001 1048576
                      VCID: 5BE266083F25BFFF6E8-800E
2 Fehlercodes gefunden:
            000 - -
01423 - Sensor für Querbeschleunigung (G200)
            005 - keine oder falsche Grundeinstellung/Adaption
Remaining in the brake:
Code:
Adresse 03: Bremsenelektronik        Labeldatei:. DRV\3C0-614-095-C2.clb
   Teilenummer SW: 3C0 614 109     HW: 3C0 614 109
   Bauteil: ESP 440 C4     H018 0001
   Revision:  H018       Seriennummer: 0668139734
   Codierung: 0013602
   Betriebsnr.: WSC 61272 001 104857
After I found a suitable coding for the brake control unit...
After I had them, the sensors could be paired and all errors could be cleared.
Code:
   Revision:   013
   Codierung: 0000012
3 Fehlercodes gefunden:
02844 - Lampe für Funktion automatisches Parken
The errors in the FSB control unit could be narrowed down to the following:
The power supply for the right channel is present, and the corresponding connector pins appear to be in good condition.
The two FSB engines have a resistance (measured from the control unit).
in the range of 3 to 4 ohms.
I'm slowly running out of ideas.
Micha
autoscan_2017-10-28.txt
 File name:  autoscan_2017-10-28.txt
 File size:  13.92 KB
 Downloaded:  256 times
autoscan_2017-08-07.txt
 File name:  autoscan_2017-08-07.txt
 File size:  17.37 KB
 Downloaded:  241 times
Post23-11-2017, 8:55    Subject: Quote
Hello Micha,
In my opinion, the error with the warning light is likely just a secondary consequence of the lack of power supply. The initial setup is probably also not possible without the power supply. Therefore, in my opinion, you should only focus on the power supply.
Your control unit says:
02434 - Control unit left channel voltage supply.
You say:
The power supply for the right channel is present.
I suspect it's just a typo, but just to be sure: Are both "Dauerplus" connections definitely connected to pins 13 and 15? Are both masses at 28 and 30?
Possibly, it might even be necessary to measure the values directly in the control unit (STG) to rule out any contact problems.
If it arrives at the control unit (STG), in my opinion, it's only a defective control unit.
Guste.
Post23-11-2017, 8:57    Subject: Quote
Hi Micha,
I haven't encountered that issue before. Do you have a schematic diagram?
The FSB control unit has been replaced.
New or used? Are the motors in the brake calipers working properly and not partially stuck?
Wiesel
Post23-11-2017, 11:13    Subject: Quote
@ Guste: Yes, it's a typo.
Both power supplies are present, and the corresponding fuses are okay.
@ Rainer: The original STG (steuergerät) has been reinstalled, as the replacement unit...
(used, from a recycling center) exhibited identical behavior.
Wiring diagrams are available.
The right motor is working normally (not disassembled), while the left motor...
is new (whether directly from the icon_smile.gif or from the local wholesaler, I would need to inquire).
A measurement in the engine control unit (ECU) will likely be necessary.
Micha
No new posts Document about errors in the start-up lock system of the ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Touran Light Fault (FLA, MDF) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Passat 1.9 TDI: Error Codes G70, G81, G62 Diesel Engine Technology
No new posts Passat ABS/ESP Error: 2002 Model Troubleshooting On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. DSG Problems Passat CC - Solved On-Board Diagnostics (OBD)
No new posts Passat B4 1.9 TDI: Error 00546 Troubleshooting On-Board Diagnostics (OBD)
