Adding additional instruments
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
Nitram
Post01-12-2017, 14:55    Subject: Adding additional instruments Quote
Hello dear community,
I am a proponent of mechanics, but now I want to work with my vehicle electronics. Specifically, this is a VW Touran (model year 2005) 2.0 16V TDI. I want to install additional gauges for oil temperature and boost pressure. However, I do not want a sporty-looking tuning solution, such as a... Instead of Raid HP, but an original VW solution.
I believe I have also found this: VW also offers optional additional instruments for oil temperature and boost pressure on the Beetle and the Scirocco, at the customer's request. Part number would be: 5C5 919 527B
Furthermore, I found a retrofit plan for these VW gauges on gute-fahrt.de. For this, an adapter cable from Kufatec is still required. This is connected to the ignition positive and the permanent positive, and the other two wires are connected to the motor CAN-BUS High and Low .
My hope is that the instruments will also work in my Touran. However, I am relatively optimistic, as I don't believe that VW has made so many changes to the Touran facelift regarding the electrical system. But, what's the point of hoping? That's the only option: Trial and Error.
My question to you: Where can I find the CAN-BUS high and low wires?
In the schematic, it states: The drive CAN high is frequently found on pin 16 (orange-black) of the diagnostic gateway, and the drive CAN low is found on pin 6 (orange-brown).
According to VW's self-study program, the color of the cables is already correct, but it also does not specify where the cables are located.
My other question: Should I simply plug the adapter cables into the CAN-BUS HIGH and LOW pins, or should I slightly damage the insulation of the two cables and solder the adapter cables in between?
Martin
Post01-12-2017, 15:50    Subject: Adding additional instruments Quote
Does the provider not offer any support for the products they offer? That's a shame... I thought that if you had any questions about an item, you could ask the place where you bought the item. That's how I would have done it. Do you not get an answer there?
When uploading images, please respect copyright and do not simply upload content from the web. icon_idea.gif
Hello, Rainer
Nitram
Post01-12-2017, 16:02    Subject: Adding additional instruments Quote
Hello Rainer,
There is an instruction manual from Kufatec for their adapter cables. However, it is unfortunately only described for the Beetle and not for the Touran. I have already contacted them to see if they could send me the manual, even though I haven't purchased the product yet. Do you actually fundamentally believe that data extraction could work?
Best regards, Martin
Post01-12-2017, 16:14    Subject: Adding additional instruments Quote
Nitram wrote:
Hello Rainer,
Electrically, it should not be a problem, but if the information expected from the auxiliary instruments is not found on the expected CAN IDs, or if the information is not available at all, it will not function.
Best regards, Rainer
Nitram
Post01-12-2017, 16:19    Subject: Adding additional instruments Quote
Everything makes sense to me. I probably have to try it anyway. If anyone is interested, I can also post the result here.
Thank you for your help!
No new posts Retrofitting a tow hitch on a Passat 3C, model year 2007 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Aftermarket Leather Steering Wheel with Airbag Troubleshooting & Guides
No new posts Speed Control Retrofit Seat Ibiza / Polo Troubleshooting & Guides
No new posts TDI B4: Upgrade GRA (1992) Diesel Engine Technology
No new posts Retrofit BT for 9ZF Transmission Transmission, Chassis, Body & Interior
No new posts VW: Retrofitting LDA (Local Differential Analyzer) Diesel Engine Technology
No new posts Retrofit AHK for Galaxy 1999: Installation Guide On-Board Diagnostics (OBD)
