A8 D3 einige Steuergeräte ausgefallen auf Fahrerseite | Posts 16+
Go to page: Previous  1, 2
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
beathooven
2001 Audi RS4 Avant
dieselschrauber likes this.
Post13-12-2017, 19:39    Subject: Quote
Finally, the error has been found! It was the thermal fuse S43 that was defective. A friend who is a diagnostician looked at the wiring diagrams and pointed to the S43 – he was absolutely right.
I didn't know there were more fuses there... I had to remove the cover under the steering wheel, and then I found some more large fuses.
Problem with Media 1 and 2 has been resolved by properly logging in icon_smile_thumb_up.gif.
Unfortunately, there are still some errors...
01: observe...
03: Monitor and regulate ESP and ABS.
"08er": I can live with that.
34: Occasional, observe.
47er: I can live with that.
61s: THE NEW MAIN PROBLEM.
65: I don't need the tire pressure monitoring system, so it's turned off. Is it possible to disable the warning light for this?
72s: whatever.
Regarding the new main issue:
Idle current... What do the levels indicate?
Log-13.12.17-WAUZZZ4E07N012263.txt
 File name:  Log-13.12.17-WAUZZZ4E07N012263.txt
 File size:  24.78 KB
 Downloaded:  561 times
Translated on 03-08-2026, 16:02.
Post14-12-2017, 9:11    Subject: Quote
Regarding fault code P2189: If insufficient fuel is reaching the engine, it could be due to low fuel pressure, a clogged injector, or a vacuum leak on the intake side.
However, I would first continue to monitor the situation. At most, I might spray a little bit of brake cleaner around the outside of the suspected intake manifold side. If the engine's running changes after that, it means there's an air leak somewhere.
Translated on 03-08-2026, 16:04.
No new posts EDC15: Updateable Engine Control Unit Software Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Diagnosis: Common Questions & Answers On-Board Diagnostics (OBD)
No new posts A4 TDI AFN: Performance Questions & Tuning (Kassel/G�... Diesel Engine Technology
No new posts VCDS - Some options are missing under Basic Settings On-Board Diagnostics (OBD)
No new posts Intermittent Driver Airbag Malfunction Transmission, Chassis, Body & Interior
