VW Touareg: 3.0 TDI Problems & Solutions
Brassa
Post14-01-2018, 16:45    Subject: VW Touareg: 3.0 TDI Problems & Solutions Quote
Hello everyone,
I signed up here because we're at a loss and don't know what else to do.
My 2009 VW Touareg with a 3.0 TDI engine, 239 horsepower and engine code CAS, is injecting 5mg of diesel per hour into cylinder number 5.
When idling, a cloud of unburned diesel fuel eventually comes out from the back.
All 6 injectors have now been replaced, but the problem persists.
The injection times cannot be read; they always display 0.0 ms. Therefore, I can only use the mg/H value.
When it's cold, it runs very unevenly, which then decreases as it warms up, but doesn't completely disappear.
What's also surprising is that when using VCDS in German, everything related to the engine control unit is displayed in English. Furthermore, it seems there's an issue with the display showing "Cylinder 1, 2, 3 and then 4, 4, 4" instead of a complete set of readings for all cylinders.
The current assumption is that the previous owner may have had the microchip implanted incorrectly.
Does anyone have any ideas?
Thank you very much.
Greetings.
Michael.
Translated on 20-08-2026, 5:25.
Post14-01-2018, 17:02    Subject: VW Touareg: 3.0 TDI Problems & Solutions Quote
Support for diagnosis-related matters, e.g., in diesel engine technology or gasoline engine technology, is only available to "Dieselschrauber" customers (i.e., customers who have purchased an item from the "Dieselschrauber" shop) or with a support key.
Customer data?
Translated on 20-08-2026, 5:28.
DieselBär30x
Avatar-DieselBär30x
Post14-01-2018, 17:15    Subject: VW Touareg 3.0 TDI Problems & Solutions Quote
Hi Michael!
Brassa wrote:
... everything is displayed in English. In addition, there are only "Cylinder 1, 2, 3 and then 4, 4, ,4".
The assumption now was that possibly... something... was bad...
Please create an Autoscan and post it here related to this topic.
Best regards from Passau!
Translated on 20-08-2026, 5:29.
No new posts Doku Touareg, Transmission in Emergency Mode Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Touareg documentation, clacking sounds coming from the st... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Dacia/Renault Duster, squeaking noises steering column / ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. Solved - Problems with Automatic Transmission Touareg 5R On-Board Diagnostics (OBD)
No new posts Touareg GRA.... On-Board Diagnostics (OBD)
No new posts Touareg R50 V10 Diesel Engine Technology
No new posts Touareg 2.5 TDi Idle Speed Diesel Engine Technology
