vag-driver Profi-Schrauber
26-01-2018, 11:20 Subject: |
matthiasTDI96 wrote: |
I'm keeping my fingers crossed for the golf drama. It sounds like everything is going terribly! |
Ach, where  . My colleague is relaxed. He won't incur any costs. And if it really isn't possible, the camera will be removed, and he will get his money back. What's annoying is the wasted time. Viele Grüße
Andreas
Translated on 27-08-2026, 13:58.
Herbert Profi-Schrauber
dieselschrauber likes this. |
26-01-2018, 14:22 Subject: |
Quote: | | So far, 2 infotainment systems have been damaged. It's probably because more current is flowing through a line than is allowed. This problem has become so severe after VW, through online support, installed what was supposedly the correct software version. |
If excessive current is flowing through the wiring harness and causing damage, wouldn't it be quite strange if the software version was the cause? Can the wiring harness be compared to the expected state (Erwin, current wiring diagram)?
Herbert. Horch A4 8K CJCD
Translated on 27-08-2026, 13:59.
26-01-2018, 15:06 Subject: |
matthiasTDI96 wrote: | The T6 is available, but it's probably simpler because it's not that current in the timeline. @Rainer, if you need an automatic scan for a T6 with a factory camera, I can take care of it .
Thank you for the offer! I'll take a look when the car is here.
Translated on 27-08-2026, 14:01.
Profile PM WWW Garage |
27-01-2018, 12:12 Subject: |
Herbert wrote: |
If excessive current is flowing through the wiring harness and causing damage, wouldn't it be quite strange if the software version was the cause? Can the wiring harness be compared to the "as-designed" state (Erwin, current wiring diagram)?
Herbert |
I have to disagree with you, because my colleague had already correctly installed the wiring harness, and it should have sparked immediately after my coding attempt. It's very possible that this newer software uses different input and output signals.
I believe the specialist will be coming on Tuesday to address the issue. Viele Grüße
Andreas
Translated on 27-08-2026, 14:02.
31-01-2018, 8:00 Subject: |
The error has been found. The wiring harness was incorrectly wired internally. It was obvious from the beginning that two wires were connected to what should have been three. This was also the case with the second one that was installed for testing. Now, we need to determine how this could have happened and how many defective units are circulating.
The camera is now working as it should. Viele Grüße
Andreas
Translated on 27-08-2026, 14:03.
Roger Profi-Schrauber
Joined: 10/11/2002 Posts: 3035 Karma: +88 / -0 Location: Rodgau 2017 Volkswagen Golf Premium Support
31-01-2018, 8:06 Subject: |
Thank you for your feedback.
Are both navigation systems still broken? Gruß
Profile PM Garage |
Roger likes this. |
31-01-2018, 8:52 Subject: |
Roger wrote: |
Are both of the navigation devices still broken? |
As far as I know, yes. In fact, some fuses even blew. Viele Grüße
Andreas
Translated on 27-08-2026, 14:04.
dieselschrauber, Roger and DieselBär30x likes this. |
02-02-2018, 9:38 Subject: |
Here's a summary of everything, compiled after I discussed the facts with my colleague:
What was the reason that the camera didn't work right away?
The two wiring harnesses originate from a known manufacturing defect in a VW production facility in Wolfsburg, located in the Czech Republic. Unfortunately, these cables were not destroyed and have, at least in part, re-entered circulation. Upon opening the wiring harnesses, it was discovered that 12V and 6A are being supplied to the video signal of the infotainment system.
2. Why wasn't the infotainment system corrupted during my coding process?
"Fortunately, my initial encoding was incomplete. It was only the online encoding from WB that enabled the processing of the video signal. In the process, two infotainment systems were damaged because the input was not designed for 12V at 6A."
3. Which cable harnesses are affected?
Obviously, this applies only to the first production run of the Golf 7. Currently, there are no retrofit kits available, as they need to be manufactured. Viele Grüße
Andreas
Translated on 27-08-2026, 14:05.
dieselschrauber and DieselBär30x likes this. |
02-02-2018, 10:09 Subject: |
vag-driver wrote: | | When opening the wiring harness, it was discovered that 12V and 6A were being output to the video signal of the infotainment system.... |
It's not possible to say it that way. Rather, it's likely that the faulty cable is applying 12V from the internal power supply to a video contact (input or output?). As long as this contact has a high impedance, it survives. However, when it's activated by the programming, it probably becomes so low in impedance that the 12V, which is incorrectly applied instead of a video signal, causes an overload.
Translated on 27-08-2026, 14:07.
