Access Permission: Function 16 Not Selectable
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » On-Board Diagnostics (OBD)
Stepho19
Post14-04-2017, 9:26    Subject: Access Permission: Function 16 Not Selectable Quote
Hi!
My colleague replaced the ABS control unit in his Audi A4 B6 2.5 TDI, and I'm trying to code it. The coding keeps resetting to 00000. I read up on it and found out that this is likely because the steering angle sensor also needs to be calibrated with the new control unit. So far so good... However, to do that, I need to enter an access code, but that field is no longer selectable in VCDS; it's grayed out. The same thing is happening with other cars and other control units; I just tried it on my Golf. My question: What am I doing wrong?
Ich habe bereits in den Einstellungen eine passende Werkstattnummer eingegeben. Ich habe auch VCDS und die Firmware des Interface aktualisiert. Keine Änderung. Does anyone have any advice?
Best regards and happy holidays.
Translated on 06-08-2026, 5:27.
Post17-04-2017, 16:16    Subject: Access Permission: Function 16 Not Selectable Quote
Please provide a Screenshot of the relevant control unit information from the device and a vehicle scan.
Translated on 06-08-2026, 5:28.
Stepho19
Post21-04-2017, 6:55    Subject: Access Permission: Function 16 Not Selectable Quote
Reiche ich nach sobald ich wieder bei ihm bin. "Thank you!"
Best regards, Stephen.
Translated on 06-08-2026, 5:29.
Florian320
2004 Audi Cabriolet
Post04-02-2018, 16:57    Subject: Access Permission: Function 16 Not Selectable Quote
I'm also encountering the same problem here: I was trying to enable FIS and GRA for someone who had retrofitted those features.
Unfortunately, I am unable to access the "Coding II" function in the brake control unit, which is required according to my instructions.
"In addition to the error stored in the control unit for the braking electronics indicating that the basic setting for the steering angle (G85) is missing, performing this setting results in 'Steering Angle' being displayed in green in the Diagnostic Information System (DIS)."
Will this go away after a longer drive?
Here is the Autoscan:
Sunday, February 4, 2018, 11:05:59:63257.
VCDS – A VAG/VAS emulator based on Windows, running on Windows 10 x64.
VCDS version: RKS 17.8.1.0
Data as of: 20180112 DS276.7
http://shop.dieselschrauber.org/en
Dealer/Workshop name: Florian320
Vehicle Identification Number (VIN): WAUZZZ8E27A128260
License plate: WI Z 2906
Mileage: 159,510 km. Repair order:
"Die Sonne scheint hell und warm. Die Vögel zwitschern fröhlich in den BĂ€umen. Ein leichter Wind weht durch das Gras. Es ist ein perfekter Tag fĂŒr einen Spaziergang."
Vehicle type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 77 77
Vehicle Identification Number (VIN): WAUZZZ8E27A128260. Mileage: 159,510 km.
"Die Sonne scheint hell und warm. Die Vögel zwitschern fröhlich in den BÀumen. Ein leichter Wind weht durch das Gras. Es ist ein wunderschöner Tag."
"The sun is shining brightly and warmly. The birds are chirping happily in the trees. A gentle breeze is blowing through the grass. It's a beautiful day."
Address 01: Engine Control Module
Label file: DRV\06B-906-018-AVJ.lbl
Part number SW: 8E0 909 518 AQ, Part number HW: 8E0 909 018 B.
Component: 1.8L R4/5VT 0010
Encoding: 0011501
Operating number: WSC 06335 000 00000
VCID: 7F0ABC4C2D0A65BEE8-5164
3 error codes found:
17700 - Thermostat for map-controlled engine cooling (F265).
P1292 - 004 - Interruption - Occasional/Sporadic.
17953 - Throttle control.
P1545 - 008 - Malfunction - Intermittent.
16825 - Tank ventilation system.
P0441 - 002 - Mass airflow control malfunction - Intermittent.
Readiness: 0000 0000
Address 03: Brake Electronics; Label file: DRV\8E0-910-517.clb.
Part number SW: 8E0 910 517 H, HW: 8E0 614 517 BF.
Component: ESP8 FRONT H06 0140
Revision: 00000000 Serial Number: 00000000000000
Encoding: 0004871
VCID: 2C50BB008FFC2E261D-8078
Two error codes found:
01826 - Steering angle sensor (G85); Power supply KL30.
000 - - - Sporadic
Environmental conditions:
Error status: 00100000
Error priority: 3
Error frequency: 6.
Lost Count: 8
Time: 0.
Hex Value: 0x00C0
Hex Value: 0x4202
Hex Value: 0x0024
Hex Value: 0x0180
Hex Value: 0x0001
00532 - Power supply voltage.
002 - Lower limit exceeded - Intermittent.
Error status: 00100010
Error priority: 3
Error frequency: 1.
Lost Count: 9
Time: 0.
Hex Value: 0x0600
Hex Value: 0x5322
Hex Value: 0x0003
Hex Value: 0x16A5
Hex Value: 0x0001
Address 08: Climate Control/Heating Unit. Label file: DRV\8E0-820-043.lbl
Part number: 8E0 820 043 BJ
Part: A4 Climate Control Unit 2833.
Encoding: 00000
Operating number: WSC 00000
VCID: 6ADC7D181688F0162F-5148
No error codes found.
Address 09: Central Electronics
Label file: DRV\8E0-907-279-8EC.lbl
Part number: 8E0 907 279 N
Component: Internal Load Module NDL 0907.
Encoding: 10012
VCID: 3D7686443786B7AEBA-4B26
Address 15: Airbag
Label file: DRV\8E0-959-655-94.lbl
Part number SW: 8E0 959 655 G, HW: 8E0 959 655 G.
Part number: Airbag 9.41 H12 3730.
Revision: 91H12373 Serial Number: 0036M0G49PCB
Encoding: 0030612
VCID: 3B72885C7A92B99E84-806E
Subsystem 1 - Serial number: 6332DRB404259519I.
Subsystem 2 - Serial number: 6342DRB4042408AAM
Subsystem 3 - Serial number: 6352ARB401BB7211G.
Subsystem 4 - Serial number: 6362ARB401BBE558.
Subsystem 5 - Serial number: 63729RB401BDB279.
Subsystem 6 - Serial number: 63829RB401BDB24D$
"One error found:"
Error priority: 2
Error frequency: 1.
Lost Count: 39
Time: 0.
Address 16: Steering wheel electronics
Label file: DRV\8E0-953-549.lbl
Part number: 8E0 953 549 S
Component: Steering column module 0911.
Encoding: 00002
VCID: 4382F0BC5162C15ECC-4B40
Address 17: Control panel module
Label file: DRV\8E0-920-9xx-8EC.lbl
Part number SW: 8E0 920 901 G, HW: 8E0 920 901 G.
Component: KOMBI+WFS 3 H14 0200
Revision: 0200 Serial Number: AUX6Z0F0080176
Encoding: 0006114
Operating number: WSC 06617 002 1048576
VCID: 295E4214830E3B0EE6-5164
Address 25: Immobilizer
Encoding: 0006114
Address 46: Comfort System; Label file: .DRV\8E0-959-433-MIN.clb
Part number: 8E0 959 433 CC
Component: Comfort Device T85 4135.
Encoding: 07008
VCID: 74E06360444C36E685-4B26
Subsystem 1 - Part number: 8E1959801H
Component: Törsteuer.FS BRM 0606
Subsystem 2 - Part number: 8E1959802H
Component: Törsteuer.BF BRM 0606
Address 76: Parking Assist
Label file: DRV\8E0-919-283-8EC.lbl
Part number SW: 8E0 919 283 E, Part number HW: 8E0 919 283 E.
Component: Parking assist system, 8 channels, part number H06 0010.
Revision: 00H06000 Serial Number: 00067802130629
Coding: 0000014
VCID: 326CA578AED878D657-5164
"One error found:"
00446 - Functionality limited due to undervoltage.
End----------------------------(Duration: 06:39)-----------------------------
 Screenshot, man sieht die ausgegrauten Felder.
 File size:  59.42 KB
 Viewed:  6354 times
Translated on 06-08-2026, 5:49.
Post04-02-2018, 18:02    Subject: Access Permission: Function 16 Not Selectable Quote
There are "instructions" circulating on the web, compiled by various unreliable sources, which are simply incorrect.
Depending on the specific model configuration and year of manufacture, certain features may be available that are not possible in other vehicles of the same type but with different configurations or from a different model year.
Apparently, for my A6 4F alone, there are things that supposedly need to be coded, which might not even be possible. Of the instructions copied together in my example, the intended use is printing them out and using them as toilet paper in more than half of the cases. icon_evil.gif
I'm increasingly annoyed by the mindless posting of copied "coding tutorials" on every corner of the internet. Now, everyone with a website is just copying each other's "coding pages." It would be best to ask them what they were thinking and what the basic requirements are for a particular function.
In very rare cases, you will receive a meaningful answer.
If you want to know what the author of the instructions intended -> the best thing to do is ask them directly. I am not familiar with the specific "instructions" or the thoughts of the creator/copier. icon_idea.gif
Some control units do not support Coding II, but instead offer features like Security Access. VCDS usually correctly indicates which functions a control unit supports and which it does not.
So, if you are supposed to run a function that the respective control unit doesn't actually support, I would start wondering what the purpose of such an "instruction" is. icon_rolleyes.gif
In addition, the control unit for the braking electronics has an error code indicating that the basic setting for the steering angle (G85) is missing; when I perform it, the value "steering angle not initialized" appears in measuring block 1 in green.
Does it go away after a longer drive?
No, if a basic setting fails because something is not working correctly, it usually won't fix itself. In that case, you need to investigate what the problem is.
Translated on 06-08-2026, 6:17.
Florian320
2004 Audi Cabriolet
Post04-02-2018, 18:46    Subject: Access Permission: Function 16 Not Selectable Quote
Hello Rainer,
Thank you for the response.
I'll ask it differently:
How do I reprogram the ESP control unit for an 8E, 1.8T, manual transmission vehicle with brake 1LT after replacing the steering column control unit and installing a new multi-function stalk lever with GRA (Gear Range Indicator)?
How do I perform the basic setup for the G85 camera?
Or: Where can I find a source that describes these specific codings?
The coding for FIS and GRA in the AI seems to have worked, but I'm still missing the two requested steps.
Translated on 06-08-2026, 6:20.
Post04-02-2018, 19:05    Subject: Access Permission: Function 16 Not Selectable Quote
Hi.
How do I re-code the ESP control unit for an 8E, 1.8T, manual transmission with brake 1LT, after replacing the steering column control unit and installing a new multi-function stalk lever with GRA?
usually as before. What does the GRA have to do with the ESP/ABS?
Or: where can I find a source that describes the aforementioned codings?
Is the question really meant seriously? VCDS usually shows the possible codings! And it does so not with such a general explanation like on most "coding websites," but rather specifically for that particular control unit.
ABS/ESP systems should not be modified for safety reasons, but it's true that coding is rarely required in those areas. Therefore, while it might be necessary to code the braking function via GRA within the ABS/ESP system, it must be absolutely clear that the correct settings are being changed!
Here's another tip on how to spot truly nonsensical content in "coding tutorials":
If a document states to modify function X in control unit Y by setting bit 5 of byte 3 to 1, without explaining which function is being activated or deactivated and what byte 3 actually controls, then one would have to be quite naive to do so.
Make only changes that you understand.
"Only make changes where you also explain what those changes do."
3. Does one use their brain to think about whether the changes made make sense?
@Florian320Viewing profile: Florian320: Who is actually liable if you mess around with your friend's ABS/ESP system without his consent, and then he crashes at 100 km/h into a 80 cm thick spruce tree on the way to the disco because his ABS/ESP wasn't working correctly or differently than intended?
Translated on 06-08-2026, 6:24.
Florian320
2004 Audi Cabriolet
Post04-02-2018, 19:28    Subject: Access Permission: Function 16 Not Selectable Quote
I don't know what the two control units are supposed to do together.
However, this specific encoding or relationship is consistently described in multiple sources that are not exclusively aimed at children.
If I knew why, I wouldn't be asking.
"And here's the problem: according to your statement, no coding changes are displayed by VCDS in the ABS/ESP control unit, but according to the instructions I have, I need to make those changes."
Therefore, I repeat my question: where can I find a source that describes said encoding? Or can someone provide it to me?
I would appreciate it if you could suggest a way for me to obtain the GRA code without using the ESP-SG. It seems that simply having it in the AI system is not sufficient.
Your rules are self-explanatory to me; otherwise, I wouldn't have bought a VCDS.
Edit: After reviewing my documents again, I had an idea: the manual describes an ABS/ESP control unit, and it's also labeled as "ABS/ESP front" in the VCDS Screenshot in the manual. However, for the vehicle I worked on today, the control unit was labeled "ESP8 FRONT."
Since the coding must be done in the ABS module, it's possible that both modules are separate in this model, and I need to select the ABS module specifically, rather than the braking module.
Since it fit the instructions so well, I didn't look for any other solutions.
Translated on 06-08-2026, 6:28.
Post04-02-2018, 19:34    Subject: Access Permission: Function 16 Not Selectable Quote
Therefore, I repeat my question: where can I find a source that describes said encoding? Or can someone tell me about it?
The car manufacturer knows this, who else would? You can ask all sorts of people, but based on my example regarding the issue of liability, I highly doubt you'll find anyone willing to take responsibility for that.
Translated on 06-08-2026, 6:31.
Florian320
2004 Audi Cabriolet
Post04-02-2018, 19:41    Subject: Access Permission: Function 16 Not Selectable Quote
The constant need to go directly to the manufacturer would render forums like these obsolete; that's precisely why they exist in the first place.
But I understand from your reference to the issue of liability that this is probably the limit of what I can find out through the forum.
That's already a statement. Then I'll ask my mechanic.
Florian320
2004 Audi Cabriolet
dieselschrauber likes this.
Post06-02-2018, 21:06    Subject: Access Permission: Function 16 Not Selectable Quote
Okay, problem solved.
Mein Fehler war, dass die Anleitungen die ich hatte nicht fĂŒr den 8E, sondern fĂŒr das Vorfacelift waren, ich aber einen 8E zu bearbeiten hatte. Blod.
With the right instructions (including http://wiki.ross-tech.com/wiki/index.php/Audi_A4_(8E)_Brake_Electronics_(Bosch_8.0)), the necessary programming of the ESP module also worked out.
However, the error memory was only cleared after turning off the ignition and restarting it, at which point the ESP light went out – this wasn't mentioned in the wiki.
My main mistake regarding the GRA (Gasoline Residue Analyzer) was that I hadn't registered it in the engine control unit. Using the appropriate login credentials (Engine Control Unit, Function 11, Login 11463), you can register the GRA there.
Perhaps this will help someone else who also wants to code for the 8E GRA and FIS.
Translated on 06-08-2026, 6:33.
Post06-02-2018, 21:19    Subject: Access Permission: Function 16 Not Selectable Quote
Mein Fehler war, dass die Anleitungen die ich hatte nicht fĂŒr den 8E, sondern fĂŒr das Vorfacelift waren, ich aber einen 8E zu bearbeiten hatte. Blöd.
And unfortunately, this pattern runs through the "instructions," which is why I now view those corresponding copy-spam websites with great skepticism. icon_idea.gif
Thank you for the feedback!
Translated on 06-08-2026, 6:34.
Florian320
2004 Audi Cabriolet
Post06-02-2018, 21:23    Subject: Access Permission: Function 16 Not Selectable Quote
I understand your reservations, Rainer.
But ultimately, experience is what prevents you from making certain mistakes, and no one becomes a master overnight. For me, it was the first time I was coding a GRA/FIS, and that lack of experience showed.
As long as you approach things with respect (as you mentioned, using a "RĂŒbe" - a term for being gentle and patient) and don't just blindly force things when they don't work out the way you want, you will eventually reach a result.
If this small tip helps someone, then it's already been worth starting this thread.
Translated on 06-08-2026, 6:35.
No new posts 4Motion Not Working: Troubleshooting Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts T5 Brake Fluid MIL: No Function Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Needle Valve Actuator: Construction & Functionality Technical Articles
No new posts Access permission, radial dampening On-Board Diagnostics (OBD)
No new posts VAGCOM Scope Not Working: Troubleshooting Guide Diesel Engine Technology
No new posts ECU Access: BKD Engine Control Unit (EDC16) On-Board Diagnostics (OBD)
No new posts Electrical Access Control: Configuration & Setup On-Board Diagnostics (OBD)
