P1495 Error Code: Causes and Fixes
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » Diesel Engine Technology
Alltimelow
Post12-02-2018, 23:17    Subject: P1495 Error Code: Causes and Fixes Quote
Hi there,
I'm new here and looking for some good advice regarding a problem I'm having.
Volkswagen Passat 3C, 2006, 2.0 TDI, 170 horsepower, common rail injection, manufactured in 2006.
First, the check engine light came on. The error was cleared, but it reappeared after starting the car 2-3 times. Finally, the DPF (Diesel Particulate Filter) issue also appeared. Initially, everything was read out using a diagnostic tool:
Bluetooth Dongle.
Error P2425 (Exhaust Gas Recirculation Cooling Valve Control Circuit/Open).
After that, use VCDS to check for any error codes and see if the fault is reported there.
Coolant Radiator Diverter Valve (N345) - Fault Code P1495-009: Short to ground / Open circuit - Warning light illuminated.
I've now read in several forums that it could be the magnetic valve (which one are we talking about?). Am I correct in assuming this?
The DPF is likely full, according to VCDS. A picture is attached.
Thank you for any advice.
 File size:  3.2 MB
 Viewed:  4128 times
 File size:  2.11 MB
 Viewed:  5897 times
Translated on 12-08-2026, 2:25.
Post12-02-2018, 23:53    Subject: P1495 Error Code: Causes and Fixes Quote
We cordially invite you to participate. The requirement for posting in diagnosis-related topics (everything that requires a vehicle diagnostic system) is...
a diagnostic tool from a diesel mechanic's shop, or...
our software, including KDataScope and KPower, or the Diesel Mechanic license.
a vehicle diagnostic support key.
Diesel mechanic customers receive enhanced support (expert assistance) and full access.
Translated on 12-08-2026, 2:28.
No new posts Faulty solenoid valve for turbocharger pressure regulation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Touran Light Fault (FLA, MDF) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts G28 Where is the error? Diesel Engine Technology
No new posts AGR errors On-Board Diagnostics (OBD)
No new posts 3C0-937-049-30-H Error: Troubleshooting Guide On-Board Diagnostics (OBD)
No new posts G71 Error: Troubleshooting & Solutions Diesel Engine Technology
