Quote: |
| VW Repair Manual: "... engage the ignition key or starter button in position 0 (off)" |
Quote: |
| Guste: "Position 0" comes from the old ignition keys used for turning |
Logically speaking, that might be the case. However, since I am certain that VW did not simply use sloppy wording in the repair manual that corresponds to the vehicle, I have looked into it more closely:
- The (yellow) warning light for steering assistance briefly illuminates when the ignition key is inserted in position "1" (and then turns off again), not only in position 2, "ignition on".
- At the same time, the radio will turn on (if it was on when the key was removed).
- When you remove the key from this position "1", the radio turns off, and (if the engine has been turned off), the interior lights turn on.
So far, so good (and well-known).
My original objection was:
Quote: |
| There is no position labeled "Position 0 (Inventory)" (and the user manual does not mention it anywhere). |
But what's amazing is:
The "0" position actually exists in my vehicle as well (Passat Variant B6 (3C5), 2006).
When removing the ignition key from position "1" (and you can hear a relay sound), it is not immediately released, but rather, before the actual release, there is first another "park position" of the key, which is defined by spring tension.
This will be the "Position 0 (Supplies)" referred to in the repair manual.
Why, and this was my original question, must the ignition key be placed in the "position 0" when removing the comfort control unit? (This position corresponds to the state of "ignition key removed").
My answer:
According to the repair manual, the vehicle does not need to be de-energized when removing the comfort control unit (disconnecting the battery is not required, which is usually strictly enforced and clearly noted). Therefore, the key should be in a position where the buttons on the remote locking system cannot be pressed. (Without the comfort control unit, the vehicle's locking system will not function, so conversely, operating the remote key would send signal voltages to the lines leading to the comfort control unit.)
As I mentioned at the beginning: none of it is very important. (But I always like to understand what I'm reading, and if it doesn't make much sense, I'll make a note of it first.)
For me, the puzzle is now sufficiently solved.
