servusssss Blaumann
Joined: 11/14/2006 Posts: 159 Karma: +12 / -0 Location: Vlbg
18-02-2018, 16:19 Subject: EGR Valve Error 4891 - Seat CFH (N18) |
Hello everyone,
Can anyone tell me if the N18 is integrated into the AGR cooler in this vehicle, or where the AGR cooler is located?
Here is the content of the error memory:
Quote: |
Control unit part number: 03L 906 018 GL, Hardware: 03L 906 018 FJ.
Component and/or version: R4 2.0l TDI H25 9977.
Encoding: 00190012042600080000
Company number: WSC 05891 605 00000
ASAM Dataset: EV_ECM20TDI01103L906018GL 003005 (SE35)
VCID: 7AFE577AFDB2FB96DF-802F
"One error found:"
4891 - Exhaust gas recirculation (EGR) valve (N18).
P0403 00 [232] - Malfunction.
Warning light ON - Intermittent - Confirmed - Checked since last reset.
Environmental conditions:
Error status: 00000001
Error priority: 2.
Error frequency: 5.
Mileage: 106291 km
Date: 2057.14.31
Time: 12:54:51
Motor speed: 2188.00 rpm.
Normalized load value: 72.9%
Vehicle speed: 75 km/h.
Coolant temperature: 80 °C.
Intake air temperature: 11 °C.
Atmospheric pressure: 940 millibars.
Voltage at terminal 30: 14,500 V.
Lost learning cycles via OBD: 40.
Air mass: Actual value (mg/stroke): 938.2 mg/stroke.
Exhaust gas recirculation valve: Control: 15.00%.
Exhaust gas recirculation valve: Actual value: 97.55%.
Exhaust gas recirculation valve: Offset closed: 7.46%.
High-pressure exhaust gas recirculation valve: Status bit 0: 00000000.
High-pressure exhaust gas recirculation valve: Status bit 16: 00000011.
High-pressure exhaust gas recirculation valve: Status bit 24: 00110111.
High-pressure exhaust gas recirculation valve: Status bit 8: 00000111.
Exhaust Gas Recirculation (EGR) High-Pressure Sensor: Actual Value, Raw Voltage: 850.2 mV.
Readiness: 1 1 0 0 0
Certainly. Here's the translation:
"Thank you very much."
Hello!
| Description: |
 Download |
| File name: |
VCDS Fehlerspeicher Ausdruck-VSSZZZ5PZDR014635.pdf |
| File size: |
12.11 KB |
| Downloaded: |
493 times |
Translated on 12-09-2026, 3:53.
Joined: 04/12/2002 Posts: 18118 Karma: +801 / -0 Location: St.Gallen 2018 Volkswagen T6
18-02-2018, 18:07 Subject: EGR Valve Error 4891 - Seat CFH (N18) |
The engine code "CFH" is not complete; there are variations such as CFHA, CFHC, etc.  Therefore, it is best to always include a car scan with the information.
The (electric) EGR valve is located in the "exhaust gas recirculation with cooler" module in these engines. In the CFFB engine, it's located at the rear of the engine, under the turbocharger (it's a bit difficult to access), and I suspect it's in the same location in yours.
Photos and experiences from people who have replaced it would be great, as the AGR valve is known to not last forever.
Translated on 12-09-2026, 3:58.
Profile PM WWW Garage |
brezelmann01 Profi-Schrauber
Joined: 09/14/2002 Posts: 714 Karma: +75 / -0 Location: Niedersachsen
18-02-2018, 23:03 Subject: EGR Valve Error 4891 - Seat CFH (N18) |
Hi!
SW9977 sounds like it might also be a victim of an update, right?
Translated on 12-09-2026, 3:59.
servusssss Blaumann
dieselschrauber and brezelmann01 likes this. |
25-02-2018, 17:13 Subject: EGR Valve Error 4891 - Seat CFH (N18) |
Hello everyone,
Thank you for your answers.
@ dieselschrauber
Unfortunately, I didn't have a charged battery for the car scanner, but it's as you said.
The actuator is integrated into the AGR cooler.
The interior space of this car is quite limited, especially considering that it's an all-wheel-drive vehicle.
Therefore, we requested leniency from the service center, and to my surprise, Seat is covering the entire repair cost.
Perhaps this is because the car requires more diesel after the update and is worse to drive. This answers the question posed by brezelmann01.
"Thank you!"
Hi there!
Translated on 12-09-2026, 4:00.
Hufe Schrauber
Joined: 06/09/2015 Posts: 64 Karma: +22 / -0 Location: Bad Münstereifel 2004 Audi A6 Avant Support
08-03-2018, 9:39 Subject: SEO: Best Practices for Website Optimization |
Hello, greetings!
I also have a CFHC with the update, and it has approximately 125,000 km on the odometer.
The update is about 3 months old, and recently the AGR valve caused the engine check light to illuminate.
VW offered a full goodwill warranty for the replacement of the AGR cooler (including the valve) and a 2-year warranty on the new part.
The EGR valve is triggered more frequently by the software update, which causes it to become clogged even more (than it already was). As a result, the EGR valve no longer closes completely and cannot reach its lower limit. This then leads to an error message.
The estimated cost is around 1,300 EUR. (2.0 TDI CFHC with 4x4).
Beste Grüße,
Hufe
Translated on 12-09-2026, 4:02.
Profile PM Email Garage |
08-03-2018, 13:58 Subject: EGR Valve Error 4891 - Seat CFH (N18) |
Hello!
@ Hufe : Could you tell us the year of manufacture and model of your vehicle? Is the vehicle's service history up to date?
Brezelmann01
Translated on 12-09-2026, 4:03.
Hufe Schrauber
08-03-2018, 15:55 Subject: EGR Valve Error 4891 - Seat CFH (N18) |
Sure...
Skoda Yeti, first registration 2013 (less than 5 years old), 2.0 TDI 4x4, fully documented service history with mobility guarantee.
Beste Grüße,
Hufe
Translated on 12-09-2026, 4:04.
servusssss Blaumann
dieselschrauber likes this. |
13-03-2018, 20:44 Subject: EGR Valve Error 4891 - Seat CFH (N18) |
Hello everyone,
The Seat did not have a manufacturer's warranty because it was purchased from an independent dealer.
Therefore, Seat's generosity is quite impressive.
I already understand that the AGR now has more work to do.
It's being widely reported that the software update improves emissions through the use of an EGR system and multiple fuel injections.
Apparently, the engineers at VAG didn't know that beforehand, which I personally find rather doubtful.
In common-rail engines, multi-stage injection is easier to implement compared to pump-injector engines.
My personal opinion is that they don't want to release any negative press about the software update, so that customers don't get even more upset.
But, as I said, that's just my personal opinion.
SG.
Translated on 12-09-2026, 4:05.
