Brake Booster Vacuum Hose: DIY Replacement Guide
ulfbastel
Post21-03-2018, 10:10    Subject: Brake Booster Vacuum Hose: DIY Replacement Guide Quote
VW Golf 1.9 TDI 4motion, 130 horsepower.
"The vacuum hose likely has a crack on the pump side. I noticed this by wiggling it after turning off the engine, and it made different hissing sounds. The symptom was a rapidly decreasing brake booster effect after stopping the engine. Can I buy the hose (for about 30 EUR) and replace it myself without special tools or knowledge? It seems to have some kind of crimp clamp on the pump side."
Thank you for your help.
Translated on 19-08-2026, 9:40.
Karma: +1336 / -0   Thank you, like it!
Post21-03-2018, 10:23    Subject: Brake Booster Vacuum Hose: DIY Replacement Guide Quote
The simple answer is yes.
If the replacement part is another type of crimp connector (with a "loop"), you will either need a special crimping tool for it, or you can use a pair of pliers and a U-shaped nail as a makeshift solution. The connectors should be present at both ends of the hose ----> parts catalog.
Translated on 19-08-2026, 9:42.
No new posts Glow Plug Replacement: 2.0L TDI 16V Troubleshooting & Guides
No new posts Replacing the Gearbox Seal between the Gearbox and the Dr... Troubleshooting & Guides
No new posts Ignition Switch Replacement VW Golf 3 Troubleshooting & Guides
No new posts Dichtung für Unterdruckschlauch an BKV Transmission, Chassis, Body & Interior
No new posts Vacuum Hose Size: Dimensions & Specs Diesel Engine Technology
No new posts Vacuum Tube Adapter N75: 3.5mm to 4.8mm Diesel Engine Technology
No new posts TDI AFN Vacuum Hose - MSTG Diesel Engine Technology
